Question about Kenwood MX270 Patissier Food Processor
No turning of motor in my Kenwood MX270 Patissier
I've opened the case and checked the speed microswitch on the side. That worked (made contact when necessary) . Didn't see any blown components. Tried a new TRIAC on the PCB but that didn't help either. Also the brushes are still good of the motor. Where do i have to look into?
  • nader
    nader Apr 18, 2015
    Sir, I have this issue too the rotor ok, stator ok, brush ok, switch ok, how did you fix it sir , changing the Motor PCB ?
  • Kenwood Master
  • 1,309 Answers
Follow the power, start looking wherever the power stops. Sometimes it can help to reverse phase & neutral to track where the power stops from the other side too. You are only doing this for testing purposes and need to put it back as it should be when you're done.
Posted on Dec 14, 2014
My Kenwood MX270 patissier doesn't work anymore. I've opened it and checked the brushes (still enough length) ; micro switch also is working. Which component on one of the two prints are suspicious?
Brushes are long enough but it there enough pressure on them to press against the armature? What about the armature? Did you use a meter to check the windings?
Dec 07, 2014 | Kenwood MX270 Patissier Food Processor
Moter is working but dooh hook not working
hi if you still have problems email me and i will try and talk you through,
it may be the belt (teeth worn out) or the pulley (same problem).
the info given in your post is very vague.
if its the teeth on either the belt or pulley there is a simple fix.
remove bottom of base with screwdriver there should be screws under the feet of machine. use a bike valve screwdriver to remove the two remaining screws(depending on make and model)
remove belt, put RUBBER BAND
Jan 24, 2013 | Kenwood MX270 Patissier Food Processor
Kenwood KM336 no power to beater or slow speed outlet
Hi. You have a broken gear in the gearbox either the first motion gear is loose on its shaft or less likely the vertical big gear is loose on its shaft. independent spares for the gearbox are available or complete gearbox
Aug 02, 2012 | Kenwood KM336 Chef Food Processor
I need a service manual for the MX270. Don't know how to open the machine.
How far have you come? There are covers in plastic that cover the screw heads.
Have you got any other information, I have an electrical problem. Need help with electric troubleshooting.
Jan 03, 2011 | Kenwood MX270 Patissier Food Processor
Why is smoke coming from Kenwood chef A901
sounds to me like you may have burnt up the motor probaby by mixing to heavy of a load or running it too long, or by just being older. I would replace it as fixing it would be costly
Jul 13, 2010 | Kenwood Food Processors
Sunbeam LC6200 won't turn off. Only runs at full speed unless the bowl lid is disengaged (the safety swtich still works). Have opened it up and the Pulse microswitch seems ok, as does the rotary speed/off...
OK this is the fix for the LC6200 that worked for me. Unscrew top cover (2 screws) then another screw holding internals to external case. Carefully remove safety switch lever (use long nose pliers from the top next to lever to squeeze plastic barb that holds the levers in to the plastic body). Remove all screws on the bottom. Open and undo the drive shaft pully nut clockwise. Pull out shaft and remove belt. Unscrew motor from chassis plate. From the bottom push out the plastic speed control dial with screwdriver. Remove motor and component boards. Check microswitches. Then remove diac DB3 and replace. Remove triac BT137 600v and replace. PS I used a 800v motorola MAC228 instead. Assemble in reverse. Good Luck.
denisprod
Feb 20, 2010 | Sunbeam Food Processors
Kenwood a710a mixer suddenly lacks power
sounds like the motor armature is burn. Dissemble the unit, remove the motor. Loosen the bolts running from end to end of the motor and with emery cloth, clean the small metal plates on the ehd of the armature. They should be bright copper colour. I the armature is burnt, they will be dull brown. The other thing is to replace the brushes in the motor.
Feb 04, 2010 | Food Processors
Kenwood MX270 Patissier Food Processor Logo
225 people viewed this question
Top Kenwood Food Processors Experts
Ross Keen
Mitch Vass
Mitch Vass
Are you a Kenwood Food Processor Expert? Answer questions, earn points and help others
