Question about Samsung HL56A650 56 in. TV
IA THIS RVICE FREE I HAVE BEEN UNEMPLOYD FOR 2 YEARS AND IHAVE RIEND THAT I THNK AN D TEWORK IF I CAN DETERMINE THE PROBLEM
UNPLUGGED WAITED 10 SEC HELD IN START BUTTON...RED LIGHT STAYS ON,2GREEN ANS THBLUE START BUTTON COME ON 1/2 SEC AND WHEN TRY TO TURN ON IT CLICKS THEN IN 5 SEC CLICKS AGAIN
    Master:
  • 373 Answers
Sounds like the power supply capacitors have failed. If you can't replace capacitors on a circuit board on your own, it's time to take in to a repair shop.
Posted on Dec 08, 2014
Panasonic the genius prestige problem:::: it will run for about 10 secs then shut off, turn it on again real quick it will run another 10 secs...everything else works on it, the broiler,bake, but when the...
Before spend $$ on replacement boards, make sure anything attached to it is powered off. Unplug TV for 5mn to 15min. Plug back in and it should power on. If not leave unplugged overnight before spending on a replacement board. We have to do this 2-3 times per year when someone forgets to turn off auxiliary components (receiver, DVD, cable box, etc) first. It has always come back on.
Mar 16, 2013 | Panasonic NN-SD797S Microwave Oven
Ihave dmr-e55 it records advd for 5 minutes and it goes to self check
1) Press and keep [POWER] button on the unit for more than 10 seconds
to turn off the power of the unit.
2) Unplug power cord and wait for approx. 1 minute.
3) Plug power cord in.
4) The display shows [RECOVER] or [SELF CHECK] and it becomes under
recovery. Wait till the message on display disappears.
*When the unit does not recover after taking above procedures (1 to
4), it is needed to be checked and repaired.
Mar 25, 2010 | Panasonic DMR-E55 DVD Recorder
Rt164 reset button does not work to default
Hi friend
I hope it will work for you,please follow the steps:
1) Give the router power,then with a pen press the reset button for 10 secs,after that unplug the power cable from the router for 10 secs and wait
2) After 10 secs plug the power cable back,and press the reset button for another 10 secs,after that unplug the power cable again for 10 secs. and wait.
3) After 10secs plug the power cable back and press the reset button for 10 secs, after that unplug the power cable again for 10 secs and wait.
It will bring the router back to default settings.
now if your ethernet ports have limited connectivity,please follow the steps:
If you have windows XP try this
1) connect the computer with a wire to the router
2) click start menu>contrlo panel>to your left you will see switch to classic view,click that
3) Double click and open the icon named network connection
4) right click the icon named local area network connection,click properties
5) Now click the tab named "configure" under the general tab
6) Click the tab named "Advanced"
7) Under that tab you will see something named "Property"
8) Inside that white box you will see either "Speed/Duplex" or "Link Speed/Duplex", select that
9) To your right just beside property you will see 10 mbps half duplex,select that and click OK
10)Click Ok if you find any or click Close,whicever is there.
Restart the computer and enjoy working without any limited connectivity.
warm regards
Chiranjeet Mitra
Oct 08, 2009 | Computers & Internet
My wrt300n power led is blinking and the rest of
Hi Friend
Please follow the steps to reset the router in a different way
1) Press the reset button for 10 secs and after that unplug the power cable from the router and wait for 10 secs
2) Plug the power cable back and press the reset button again for 10 secs and after that unplug the power cable from the router and wait for 10 secs
3) Plug the power cable back and press the power button for 10 secs again and unplug the power cable from the router for 10 secs
After trying these steps if you see the power light still blinking then you need to replace the router. Please call the customer care of linksys 1800 546 5797,they will let you know how to replace the router
warm regards
Chiranjeet Mitra
Oct 06, 2009 | Linksys WRT300N Wireless Router
89 regal won,t start but after 5 or 10 min. runs great
sounds like your fuel pump is going out. One thought might be that the fuel filter is causing enough resistance to over heat the pump. I would check the fule pressure to determine a free flow of fuel.
May 01, 2009 | 1990 Buick Reatta
Regional code for dvd player
Reagrding unlock of samsun ht-x715.
Found this
http://www.amazon.com/review/R2FMHKVOZYF6HX/ref=cm_cd_NOREF?%5Fencoding=UTF8&cdPage=&cdERR=noPurchase#CustomerDiscussionsPost
Worked for me with a small change
1. Remove disc from tray.
2. Switch off player and unplug from mains.
3. Wait 30 seconds, then reconnect mains.
4. Turn on player with remote. press the 'Repeat' on the remote for 10 sec'.
5. Press enter on remote. (There will be no on-screen response.)
6. Press 8, 4, 2, 6, 9 on the remote. (There will be no on-screen response.)
7. Press enter on the remote. Player will automatically shut off.
8. Turn player on.
9. Turn off.
10. Turn player on then off again.
11. Player is now region-free.
Dec 30, 2008 | Samsung HT-X715T Theater System
Blue light
Okay, I found a fix! Called JVC, spoke to somebody there, here it is:
1)unplug the TV completely, no wall no power strips, completely
2)wait 10 sec
3)plug TV back in and Turn it on, the light will still be doing the same thing
4)wait 30 sec
5)ON THE TV, not the remote, locate the menu, volume (-) and power button.
6)while simultaneously holding down the menu and volume (-) button, pressed the power button ONCE and continue to hold the other 2 for 10 sec.
7)on the remote control, go to menu>settings>system info
*** now this I know as a FACT will work on systems that display: JVC - ver.5.32FO001, but I don't know of any other versions***
8)press the mute button on the remote twice
9)unplugg TV again and wait 10 sec.
10) plug TV in and turn on
It SHOULD be working normally now... Thanx to the guys a JVC support for this one, I know it seems like an obvious first place to look, but sometimes it isn't. I for one checked online forums first.
Nov 27, 2008 | JVC LT-42X579 42 in. LCD TV
Built in dvd player will not let me insert dvd
The LCD/DVD may need a reset. Unplug the unit for 10 sec then plug back in. Instead of power button, push eject button. The blue DVD screen should appear. This worked on my unit which I had for only 2 months. If not call customer service.
Oct 23, 2008 | LG 32LG40 32 in. LCD HDTV
Dell Dimension 4400 Won't Turn On
inside the pc there should be a green light. called flea light. if its not on.. then id say motherboard or power supply are bad.
take power cord off. and hold power button down for 10 ecs. then reconnect and retry. i think its abad psu.
Oct 09, 2008 | Dell Dimension 4400 Power Supply ** FREE...
Open Questions:
Samsung HL56A650 56 in. TV Logo
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
