Question about Alaris Ivac Vital Check Monitor With Stand Cords & Basket Model 4415 Free Shippi
Where can I get the adapters for the blood pressure cuff. I have a cuff but need the adapter to connect to ivac
Looking on internet with no success
My Blood Pressure comes up with E1 - what does this mean?
An E1 error can mean a number of things depending on the brand of your monitor and the way that you are trying to take your blood pressure. The general reason for E1 errors is to announce for whatever reason that the machine could not get a blood pressure reading.
Some common causes:
You did not let all of the air out of the blood pressure cuff before trying to take your blood pressure. Make sure that there is no air in the cuff by squeezing it or rolling it, prior to use to let out excess air.
Your blood pressure cannot be taken at this time. Sometimes this occurs if you are very nervous, overly excited, or have a fast heart rate. You can try sitting down and relaxing prior to taking your blood pressure.
You are using the wrong size cuff. If you are taking blood pressure on a small child, someone with a tiny arm, or someone with a large arm, the blood pressure cuff might not get an accurate reading. Many blood pressure monitor manufacturer's offer blood pressure cuffs ranging in size from small to extra large, and you should use the cuff that is most appropriate for the size of your arm.
You didn't line up the blood pressure cuff correctly on your arm. You can't just slap the cuff on your arm and expect it to work, it has to be lined up properly. Many companies put an arrow on the cuff to give you an idea with positioning.
You need to try a different spot on your arm. Occasionally some people cannot give a blood pressure reading on their upper arm for a variety of reasons, and you should try getting a reading on your lower arm.
If you are still having trouble with your blood pressure cuff, take your monitor with you to your next doctors appointment so that your doctor can show you how to use the monitor correctly.
Mar 27, 2017 | Health & Beauty
I urgently are looking for a mikrolife blood pressure cuff to buy. I am situated in the port elizabeth area.
You can get a new blood pressure monitor online, at walgreens, Walmart, lots of places:
Google bp mon
if you only want areplacement cuff look here:
Google cuff
Mar 26, 2017 | The Health & Beauty
Replacing leaky cuff
blood pressure monitor replacement cuff, links below are to replacement cuffs and are fairly self explanatory to install
press the helpful button and follow me on fixya for more tips
Blood Pressure Monitors Parts and Accessories
Blood Pressure Monitor Replacement CuffWalgreens
http://www.walmart.com/c/ep/blood-pressure-cuffs
OMRON Healthcare Blood Pressure Monitoring
Feb 03, 2016 | Health & Beauty
Have HEm-780 and the cuff is too big. how does that effect my readings. Can I order smaller cuff?
  1. You can buy a smaller cuff. Pressure may be wrong also. Most local stores have them.
Feb 10, 2015 | Omron HEM 780 Automatic Blood Pressure...
What does error 3 on my microlife blood pressure monitor
Repeat measurement keeping arm still. If inflation of the cuff takes too long, the cuff is not correctly seated or the hose connection's not tight. Check connections and repeat
Jan 10, 2015 | Microlife Health & Beauty
Dear sir/madam , i have an blood pressure monitor with this model;SBM 07 but when i want to take my blood pressure it is showing error and not going up just going 45 how i can solve this problem and ,
Look fo leak in tubing or cuff. Probably pinhole in cuff (watches or rings and stuff can puncture it sometimes).
put the tubing under water and pump up, looking for bubbles... My suggestion. If no bubbles, pump one-way valve is probably failing or has a dirt all stuck in it holding it open and so leaking to cause not pumping correctly.
Oct 19, 2014 | Health & Beauty
Error 3 is showing on my monitor ... What does it mean ?
On other blood pressure monitors from Life Source, the error 3 means that the blood pressure cuff isn't inflating properly. The cuff could be incorrectly fastened or the air connector is backwards or not connected to the cuff or the monitor. Check this on your monitor.
I hope this helps.
Jul 08, 2014 | Health & Beauty
Err code 3
From manual at pag.3:
err code 3Appears when pressure value did not increase during cuff inflation: 1) cuff is not fastened 2) air connector is not connected properlMake sure cuff tube is properly connected to monitor, cuff is securely fastened and exhaust rate is between 2 mmHg and 5 mmHg. Make sure air connector is inserted properly into tube and monitor.
refer to manual
Mar 05, 2012 | Lifesource UA 767 Plus Digital Blood...
My blood pressure machine starts then stops and restarts quite a few times
It sounds as if there's a leak somewhere in the system. Make sure all the lines are well-connected, and that the cuff isn't leaking.
Jul 10, 2011 | Sunbeam DIgital Blood Pressure Monitor...
Looking for replacement arm cuff for my sunbeam blood pressure monitor model 7652
To get a replacement arm cuff call sunbeam at 1-800-394-2326
The cuff will cost you 12.95 there. If you need you can get the manual and order sheat on the link below. Page 10 of manual.
http://www.foodsaver.com/manuals/HAH/Manuals/7652.pdf
Good Luck
May 24, 2010 | Sunbeam Health & Beauty
Alaris Ivac Vital Check Monitor With Stand Cords & Basket Model 4415 Free Shippi Logo
51 people viewed this question
Top Alaris Science & Laboratory Experts
Gareth Cockram
Gareth Cockram
William McMath
ray gallant
Are you an Alaris Science and Laboratory Expert? Answer questions, earn points and help others
