Question about Toshiba Televison & Video
My toshiba is only operating in squares of four and it doesn't show the whole screen
Tried searching for channels but I couldn't managed to have the tv on its only showing four boxes on the screens which are not clear
    Top Expert:
  • Toshiba Master
  • 74,136 Answers
Do a reset to this TV and check. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
If this do not help you, contact the authorized service center.
Posted on Dec 09, 2014
What antenna works on Toshiba 20VL43U? I purchased Mediasonic Homeworx HW110AN Super Thin Indoor HDTV Antenna - 25 Miles Range.
I recently went through a whole song & dance about HDTV antennas for my RV. I bought two different directional high-gain antennas, only to find that they wouldn't even receive signals at my home! When I'd reorient the antenna and initiate another channel search, I would sometimes get ONE or TWO channels... then I'd lose them when I'd try to reorient the antenna.
What I figured out is that DIRECTIONAL HDTV ANTENNAS ARE, ESSENTIALLY, WORTHLESS. There is really no way of knowing precisely which direction the broadcast towers are and, even if you knew, they will not all usually be clustered in one small area... they may be scattered here & there around your area.
What I eventually did is bought an OMNIDIRECTIONAL HIGH GAIN ANTENNA, which was no more expensive than the DIRECTIONAL antennas I tried. Did a channel search, and got almost all of the channels in my area!
Any omnidirectional HDTV antenna will work with your television, but I'd recommend buying the one with the highest GAIN (expressed in "dB" or "dBi" with the highest number being best). Try to find a POWERED antenna with an internal SIGNAL AMPLIFIER.
Also, if you live far away from broadcast towers as I do, you may wish to consider adding an additional SIGNAL AMPLIFIER as well.
May 21, 2015 | Toshiba Televison & Video
Toshiba satellite c855-s5315 reset help please
This sounds like you have corrupt files in storage.
If you have made a boot disk or flashed a usb flash drive with the operating system, you may be able to recover your disk integrity.
If not and you cannot complete the steps below, contact TOSHIBA
Hope this helps
1. Type in the words "recovery media creator" anywhere on this screen. As you start typing the Windows 8 Search box will open.
2. As you type the name of the app you will see an app list show up onthe left
3. Click on the "recovery media creator" app
. Select [Yes] to allow the Toshiba App to make changes to this computer
5. Insert a DVD in your disc drive and select [Create]
6. You will prompted to insert a disc after each one is filled until the completion message below appears
7. Select [OK]
This completes you backup media recovery set!
H
Hope this helps
HH
Apr 14, 2014 | Toshiba Satellite L355D-S7813 Notebook
No channel set up
Hi, try pressing the "closed caption" button on the remote. I hope that works. If this doesn't work try getting your TV's SE-R0305 Operating manual and reading through it and it might be able to help you. You will be surprised at how much information is in the TVs manual.
Oct 07, 2012 | Toshiba SE-R0305 Remote Control
I have a Toshiba 32a33 TV, I have tried to program channels into the TV but it doesn't work. I tried to do it both manually and using the automatic channel tuner but it doesn't work. What should I...
Either the tuner or the video IF stage circuit of your TV is faulty. Tuner has no repair, can be replaced as a unit. If the fault is with video IF stage, it can be repaired. But, both the work is skilled one. You must have through knowledge in electronics, and work experience to do this work.
Jul 21, 2012 | Televison & Video
Why is my Toshiba Satellite L505D-GS6000 Wifi driver not found?? After resetting, checking device manager, trying fn+f8, and dowloading the driver it still doesn't show up!!!
Sounds like a bad wireless card or the card slot.I would try replacing the wireless card.When wireless cards go bad they either cause the laptop to not boot,low or no signal reception or the card isn't seen at all by the motherboard or operating system or .both.If it isn't showing in device manager either with a caution sign or installed the card is most likely bad
Mar 08, 2012 | Toshiba Satellite A135-S4727 Notebook
My apex gb43hd10 has a black screen square only on cbs.
it is your captions turn captions off how old is you tv is it analog or digital tuner
Jan 19, 2009 | Televison & Video
Large black square blocks screen
Most likely it's the closed captioning has been turned on. From your post I assume you have the remote control and able to access the menus so try to turn off the closed captioning. I'll be notified if you post something new.
Nov 27, 2008 | Toshiba 32A33 32" TV
Toshiba TP50G60 Big Black Square Covering the screen?
try the closed caption adjustments. i had a tv that did the same thing and the captiong did it. turn caption off nd try.
Oct 09, 2008 | Toshiba TP50G60 50" Rear Projection...
Black Box appearing on my screen
Shut off the closed captioning and your problem will be gone.
Jun 26, 2007 | JVC AV-27F702 27" TV
Black Square Covers 80% of screen on most channels on TV
have your tv checked by a tech.probably your chip the eprom needs to be reset by lifting it up from the board and resolder back.some one could have put in a code for those channel.good luck.
Dec 27, 2006 | Toshiba CF35E50 35" TV
Televison & Video Logo
63 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
