Question about Electric Eyeware Milwaukee 5" / 6" Angle Grinder 12 Amp (w/o lock) 6123-31
How do I replace gears milwaukee 6123-31 angle grinder?
Trying to remove using hands
    Sergeant:
  • 213 Answers
Dear Ion,
Here is a video worth viewing. Angle Grinder And Its Bearings .
This site offers almost all you need. I offered the link to show and tell how to get there. Research your device onward.
Milwaukee 6148 30 SER B71A 4 5 Angle Grinder Parts
To remove the gears, it is helpful to borrow or purchase bearing pullers. Here are on examples.
A Neiko 19 Piece Automotive Bushing Bearing Driver Tool Set
B Amico 75mm Length Center Bolt Two Jaws Bearing Gear Puller
C Wilmar W137P 6 3 Jaw Gear Puller
D ATD Tools 3056 Bar Type Puller Bearing Separator Set in Molded Storage and...
If you have a vice, soft jaws , are placed on an outside bearing racing fit to be held. A Brass hammer or drift pin may be used to strike the armature without damage to move the bearing for clearance. Another person may be needed to catch the shaft from falling. In the case of a internal bearing care must be observed,however, Sockets that fit in the area make great devices to drift the bearing should there be room to employ the repair process.
Fare. Well.
Posted on Dec 13, 2014
How do I remove the bearing from the drive end of the armature from an AEG WSE802 Angle Grinder?
Dear Michael,
Here offered is a video by Taimo T that offers the entire process. Close attention is needed to absorb his procedure. The foundation is the basis for angle electric grinders.
Please watch the entire presentation.
A small bearing puller works best. Here is examples of one to buy or borrow.
A
ATD Tools 3056 Bar Type Puller Bearing Separator Set in Molded Storage and....
B
Pump Pulley Remover Straight Type Two Claws Bearing Puller
Hand Tool
C
D
The alternative is to squeeze the old bearing in a vice with soft jaws . Then move the end shaft with a brass hammer or punch to remove with an internal fit.
Fare. Well.
Dec 12, 2014 | Saws
Milwaukee 6153-20 grinder is running extremely hot.
Your grinder is either working too hard because of broken or seized bearings or the fan is broken or detached from the armature. Take the brushes out then remove the four screws holding the gear housing on the motor housing. Remove the armature and check the fan and both bearings. If the armature bearings and fan are OK check the bearings and gear teeth in the gear housing.
Jan 31, 2013 | Milwaukee tools Milwaukee Tool 6153-20
Replacing the gear on makita angle grinder
Are you replacing both gears? The armature gear (pinion) is usually held on with a nut or else is pressed on. The spindle gear is also pressed on. Most spindle gears will come as an assembly with the gear and spindle and housing all together.
If yours doesn't, then the spindle will need to be pressed out of the housing, and then the gear pressed off of the spindle. (Always replace the grease as well when replacing gears.)
Mar 31, 2012 | Makita Saws
Intermediate gear and armature gear stripped on Milwaukee 6082. Is the armature gear replaceable? How do I remove both gears? How do I remove armature from motor housing?
No the armature gear is made as part of it. the intermediate gear is replaceable but you need a press. to remove the armature first unplug tool and remove brushes, then remove the 4 screws that hold the gear housing to the motor housing and pull out. the intermediate gear is pressed onto the shaft.. Let me know if you need more assistance before voting and thank you
Feb 20, 2011 | Milwaukee Saws
How do I remove the 1/4 - 28 hex locking nut so I can remove the Spiral bevel gear?
you need to remove the gear housing with the armature attached, remove brushes first. then "GENTLY" the metal stack in a vise or hold with a rag and using a good open end wrench loosen the hex nut and after a bit you will need to tap the gear housing away from armature to get enough clearance to completely remove the nut. sounds hard but quite simple
Dec 18, 2010 | Milwaukee Electric Tool Angle Grinder 7"
Black & Decker 4 1/2 grinder gets very hot when in use
You will see vents near the head of the grinder. Make sure your hands are not blocking when in use. Also another thing I like to do with my grinders is removed the head cover (gear box) and replace the lube with a good grade of grease. I suspect if you open yours it will look like an orange wax substance. Clean and re-lube. They do run on the warm side.
Jun 09, 2010 | Black & Decker 4 1/2" Small Angle Grinder
Replacement cord
you should be able to look in the phone book yellow pages under tools,electric repair to find one or you can buy them direct. Let me know the brand and model number with a zip code location and I will try and find an original one locally for you.
Jan 23, 2010 | Milwaukee Tool Milwaukee Angle Grinder -...
I cannot get off the abrasive cutoff wheel I put on the grinder
I believe the thread is left hand, but close inspection should verify. Also you should never over tighten cutoff wheels or grinding wheels. You should be able to remove with a gloved hand while holding button on top with the other hand
Dec 26, 2009 | Milwaukee Tool Milwaukee 6" Right Angle...
How to replace main bearing in a Makita GA5000 5'' angle grinder. I removed the clip in the gear head but can't remove the gear to pull the armature. The main armature bearing in the gear head is shot.
i used to grab the armature and tap the housing off with a rubber hammer...
try tapping in opposite corners every time....
when it does fall have a cushion ready on the bench or floor to catch it...
Jul 10, 2009 | Makita GA7020 Angle Grinder
Something wrong with the armature
If the armature is shot, it will spark a lot where the brushes are touching the armature comutator. To remove the armature:1 Remove brushes. 2 Remove 4 screws holding the gear box. 3 Pull away gear box from the body. The armature may come with the gear box or not, it's only pushed in, so you should have no problem to disassemble it. If the armature stay in the grinder, use two skrew drivers to pray it out. You may not see anythink wrong with it, but it may be no good . That's Makita special, they don't make it good as they used to. The price for new grinder is about $130, for armature $65. field $40
Mar 06, 2009 | Makita 9005B 5" Electric Angle Grinder
Electric Eyeware Milwaukee 5" / 6" Angle Grinder 12 Amp (w/o lock) 6123-31 Logo
235 people viewed this question
Top Electric Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you an Electric Saw Expert? Answer questions, earn points and help others
