Question about Manitowoc QY0215W Self Contained 220Lb Compact Ice Machine
My manitowoc ice machine keeps tripping the breaker when it goes into ice making mode,what could be the problem
It starts up but when it starts pumping water and compressor is suppose to kick on the breaker trips. im thinking maybe compressor but not sure
  • Mike Lange Dec 09, 2014
    Sounds like you have done all the troubleshooting you can do. If the power supply/breaker is good, there are no other loads on that circuit and the breaker pops every time the compressor is supposed to start. Then I would say its the compressor
    Director Badge:
    Uploaded 100 video answers.
  • Manitowoc Master
  • 489 Answers
Compressor or condenser fan motor bad, very rear problem, or check wires on physical damage.
Posted on Aug 23, 2015
    Scholar:
  • 136 Answers
Which breaker? Something on the Freezer or the house power to the outlet?
Posted on Dec 08, 2014
Testimonial: "main panel"
  • 5 more comments
  • Mike Lange Dec 08, 2014
    More than likely you have to many amps being drawn by that circuit and the Ice maker motor is what exceeds the amp set by the breaker Check what else is plugged into the same circuit as the fridgerator. Try to spread out some of the load to other circuits. If all else fails you might want to see if the breaker itself is getting worn out and tripping prematurely Keep in mind the motor for the Ice maker is probably pretty small. which means it shouldn't be drawing very much power.
  • jim dipronio
    jim dipronio Dec 08, 2014
    this is just an ice machine and is only thing on circuit. it has been working,just started doing this
    Mfg says max for this unit would be 15 amp breaker. Do you know what you have now?
    If you think your breaker is ok. Then based upon the design of this unit the most likely thing will be the compressor motor could be stuck.
    When you said it just started doing this.... Did you mean. It worked fine then started popping the breaker and has done that ever since? No intermittent service, works sometimes and trips sometimes?
    This unit could have one of two different compressors either a TEC or a Danfoss. You will need to know which one you have to troubleshoot it any further
  • jim dipronio
    jim dipronio Dec 09, 2014
    Yes it starts filling with water and circulates it but as soon as the relay kicks in to freeze the water it trips the breaker. Already tried switching breaker
Manitowoc QY0214A starts up and in about 1 min. goes into heating cycle. What's my problem
The ice thickness probe is a plastic and metal piece hanging from the water distribution area at the top of the ice making plate. It is probably touching or really close to touching the plate. It should be about 1'4" - 5/16" from the plate. It is adjusted by turning the screw located on the top of the sensor facing out at you. turn it clockwise to thicken the ice. the ice should come off in one large piece linked together by a roughly 1/4" sheet across the front. You can get a 1/4" drill bit and lay it on the plate behind the metal tip of the sensing probe and use it as a feeler gauge. Turn the screw until the probe just makes contact with the bit. Remove the bit and try again.
Sep 17, 2014 | Manitowoc QY-0214A Self Contained Ice...
We have ice maker which shows off /on mode
Make sure it's not in clean mode... needs to be in ice mode
Aug 24, 2014 | Manitowoc ID1202A-261 Dice Cube Air Cooled...
How can i fix my manitowoc qm45a runs water but won't freeze the water?
The thickness sensor is shorting, making the machine continually harvest. Clean it and dry it. If it still happens, replace the sensor.
Aug 05, 2014 | Manitowoc Compact Undercounter Ice Machine...
Manitowoc q270 ice machine won't make ice .. It doednt sound like its turned on?
unplug and plug back in or turn breaker of and on to reboot the computer
Mar 07, 2014 | Kitchen Appliances - Others
My manitowoc ice maker keeps tripping the gfi
A lot of times I have found this is usually just a bad gfi I recommend never installing any refrigeration using a gfi. If it is not prone to water being splashed on it and code does not require it, I would change it to a standard receptacle. I would start by replacing the GFI as my first solution.
Jan 27, 2013 | Manitowoc QD0452A Ice Machine
I have a Manitowoc QD0212A 120v. It makes ice, but after the bin gets full, it appears that the compressor does not run to cool the ice box. Is there some type of relay or solenoid that could be bad?
Try cleaning the radiator for the ice box compressor it could be tripping it's thermal overload switch, if that doesn't work check to see if the termostat setting is in the range for the compressor to turn on when the ice starts melting.
Jun 29, 2011 | Manitowoc - QD-0212A/115-1
I have a Manitowoc s-450 with a AuCS-SI installed and it is set to not clean at this time. The machine is stuck in cleaning mode and is partially refrigerating. I disconnected the AuCS and it works fine....
When a Manitowoc goes into clean mode,It stays in clean mode until it finishes.If you turn it off and then on again,it just keeps cleaning.Let it run in cleaning mode until it finishes
Aug 24, 2010 | Manitowoc 450 Lb Ice Cube Machine Self...
Ice machine starts on harvest mode and will not go on to production
you will have to find the main board unplug the connector for about a mintue plug back in. This should reset unit
Aug 05, 2009 | Manitowoc MAN-CVD2075 Condenser Unit...
Manitowoc QY0215W Self Contained 220Lb Compact Ice Machine Logo
1,141 people viewed this question
Top Manitowoc Kitchen Appliances - Others Experts
John Tripp
John Tripp
George Merkley
George Merkley
jasbo
jasbo
Are you a Manitowoc Kitchen Appliances - Other Expert? Answer questions, earn points and help others
