I am getting a F1 code in my washer which causes it to stop several times during a wash cycle, what do I need to do?
  • Washing Mach... Master
  • 744 Answers
Hello;
My name is Peter. I am a retired field service appliance technician.
If you own a Whirlpool Cabrio and are experiencing an F1 error, you're unable to finish or start a load of clothes. When the Whirlpool Cabrio displays an F1 error, this means the the control board is having difficulty communicating with the motor.
To fix your F1 error, you can first try to unplug your washing machine for 15 minutes and then plug it back in. If this doesn't work, you will need to replace the control board. The only tools that you need to replace the control board is a Phillips screw driver and a 1/4" hex head driver. Be sure to unplug the machine from the electrical outlet before performing any repairs.
After unplugging your Whirlpool Cabrio washer, carefully pull the washer away from the wall (Watch your drain hose and the two inlet hoses.) Next unscrew the 3 screws located on the back of the Whirlpool Cabrio. Next, take a picture or make note of where each plug connects to the control board. Next, unplug each plug and the pressure tube. Lastly, unscrew the 1/4 screw then remove control board. Replace with new control board and reverse your steps to install. The new board will fix the Whirlpool Cabrio F1 error.
Posted on Dec 08, 2014
  • 6 Answers
SOURCE: Water level issues on the Whirlpool washer.
It's overfilling If your washer is overfilling, check these:
Water-inlet valve
Water-level switch
Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve.
Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
It's underfilling The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
The water temperature is incorrect The temperature of the incoming water determines the temperature of the water in your washer. You get either hot, cold, or a mix of the hot and cold water that's currently available to the machine. So if the cold water that enters the machine is very cold--or if the hot water entering the machine is very hot--the warm water is affected.
If you live in a Northern climate, unless you adjust the hot and cold water taps that supply water to your washer, the warm water supplied to your washer is usually hotter during the summer months and colder during the winter months.
Posted on May 08, 2009
SOURCE: How do you open a Kenmore Elite Oasis top-loading washer?
I just finished installing my new control unit for my Kenmore Oasis and my F1 problems are GONE! I ordered it from Sears Direct Parts. With shipping and taxes it came out to about $174 for the part, but our issues are gone and now we can wash a load of clothes without having to reset it several times.
Posted on Dec 14, 2008
lenwest
  • 150 Answers
SOURCE: F1 error code on Kenmore Oasis He
Moister can get in between the contacts,is it in a high moister environment? Try using a hair dryer on the panel to dry it out.Also unplug it to reset.
Hope this helped.Let me know by rating me
For more help go to live chat.
lenwest
Posted on Jan 31, 2009
SOURCE: maytag bravos washer stops cycle "f" code flashes
This isnt really a solution because Im having the same problem. The repair man that came said that is buildup of soap in the water line. I use my own powder soap, not h/e, and its not desolving and getting built up in the lines. Im not sure what to do to get it to stop doing this. He suggested cutting back on the amount of soap and running hot water through the lines which I have done for the last couple of days but I still have this problem.
Posted on Jul 03, 2009
emissionwiz
  • 76109 Answers
SOURCE: F1 error
there is a factory defect in the control circuit board of this washer, read and call the number. post is from another owner.
I called 800-659-7026, which seems to be a 3rd party "recall" center for appliance companies, for my F1 error code. All Kenmore HE Elite Oasis machines with Serial Numbers beginning with CS48-CT49 are in the process of being recalled; however the mailings haven't gone out to customers due to hold-ups in legal with wording. Machines with these serial numbers require an upgraded control board and it takes about 10 business days for the part to come in. They ordered it with no questions asked and are coming out July 14th to replace it free-of-charge
Posted on Jul 15, 2009
Error code F1 on Kenmore Elite "Oasis" clothes washer
Instructions Press "Stop" to clear the current cycle on the washer.
  1. 2
    Press the "Power" button to turn off the washer. Unplug the washer from the power supply.
  2. 3
    Wait several minutes. Plug the Oasis washer back into the power supply and press the "Power" button to turn on the washer.
  3. 4
    Select the desired wash cycle and press "Start."
Dec 12, 2010 | Washing Machines
Washer stops several times in the middle of cycle
possibly it could be your un-balance switch getting very sensitive to any type of movement of the machine, normally they only actuate during the spin cycle when you have a very off balanced load of clothes
Oct 03, 2009 | GE Profile Prodigy WPSE4200A
Machine stops several times shows F1 code
this is a main control board failure and needs to be replaced
Sep 16, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
I think there might be a recall on your washer call to see. I am not for sure that there is a recall but I a m pretty sure there is. So don't quote me on that. the f1 error code usually means that you have a bad board. f1 means that your pressure switch line is failing and this is all in your board. check your owners manual if whirlpool is not going to pay for this repair sometimes there are extended warranties in your manual
May 29, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis HE shuts off during wash cycle and gives F1 error
F1 error means the main control computer board. see other posts in this section as there are many who are complaining about the same problem. buying the new board (revised) will solve the F1 problem, but other problems will soon crop up on this POS washer. if you have the chance to return it to sears, return it immediately!!!!
Mar 10, 2009 | Kenmore Oasis HE 27082 Top Load Washer
lenwest
Jan 31, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Washer stops with an F1 Code during rinse cycles.
Well I have the same problem the only way I have found that my washer works is that on the soiler level make sure you put that on the heavy. And that should work I know its a pain but thats what I do and my washer washs with out stopping
Dec 04, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer stops immediately into cycle
f1 is the code for primary control failure cod be a bad connection at the primary control under the control console or a faulty primary control if its still under warranty id have a tech look at it
Jan 12, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing Machines Logo
183 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
