Question about Astoria Divina SAE-1 Espresso Machine
How do I drain the machine
Opened the value in front of the small drain under the area where the coffee is made
    New Friend:
  • 26 Answers
If this is made like most commercial machines, you have to drain the boiler. Either take out the element or take off the pressure relief valve and turn it upside down. Why are you wanting to drain the machine? If you have contaminated water, best to open up the boiler and clean it out. You will most likely have a lot of sediments in there as well.
Posted on Dec 11, 2014
Gaggio syncrony, water leaking from bottom after coffee is made
Remove the brew unit and clean the small hole under the white plastic valve make sure the little drain from it leads into the drain tray is clear.
Jun 25, 2011 | Gaggia Syncrony Compact Coffee...
Tip
ACCESSING THE DRAIN PUMP ON A FRONT LOADER
Today I will be showing you how to drain & clean your Drain Filter on a Front Loading Washing Machine.
Be sure to unplug your machine, before doing anything beyond this point.
THE DRAIN FILTER COMPARTMENT
Most washing machines have a already accessible compartment for your convenience at the front of the machine.
Common compartments can be found here:
Compartments can be opened by any small flat object, insert it at the top and flip it out downwards.
DRAINING THE WATER
Ready a small bowl, and position under the drain filter compartment. Position towels by the compartment
You now need to drain the water, there should be a small pipe with either a plastic cork / small tap which you can open. Let it drain all the water to the bowl:jedemeyer1_16.jpg
Not all Washing Machines have this pipe fitted, if that is your case, get some more towels, and a low dish for the next step.
CLEANING THE FILTER
Now the filter is the round compartment you can see, it is taken out by turning it anti-clockwise. Once loose, more water will be streaming out (a small amount, if drained adequately in the last step).
Once this filter is out, you can clean the filter cap, which should be out of the machine (In your hand, sir) - Wash it of under a running tap.
Insert your fingers into the Pump Compartment, and remove any gunk (coins, toothpicks, small stones etc), if you push your fingers in deep enough you will feel the drain pump's impeller, make sure this can be moved with no obstruction, by turning it with your fingertips.
Re-insert the filter, close the compartment and plug in your machine again.
It is recommended to clean your filter at least once a week, to avoid build-up that could harm your drain pump.
I hope you have been helped with this Tip.
JEDEMEYER
on Jul 12, 2011 | Washing Machines
I am Trying to Service a Vienna Saeco Coffee machine. I have removed the top covers and am trying to access the wiring under the heater and other parts for which I need to remove the chassis from the body....
-2 Phillips screws on the front (left and right under the fascia)
-1 torx in the back of the machine, under the water tank
-Hot water/steam knob that has to be removed: There is a clip that can be pressed with a tiny screwdriver (with the front door opened) which will let you pull the knob out.
Once this is all removed, you need to push with a screwdriver in a small whole from under the machine, beside the power cord. Pushing hard from one hand and pulling the whole thing up with the other should do it.
Jan 12, 2011 | Saeco Vienna SuperAutomatica Coffee...
Water leaks into side small reservoir, under the grinder.(normally there is only a bit of dry ground coffee. I need to empty it twice a day, because it fills up to the edge. Big water Reservoir at bottom...
Hi
Sounds like your drain is getting plugged with coffee residue. Remove your brw unit. There is an injector that has 2 orange o-rings in it in the back. That pocket below it is filling with water. There is a drain that is to the bottom left that goes into the drip tray in front. Use a prob of some kind that is about 12" long that you can stick down and forward in the drain pocket. Work it towards the fron and you should open the drain again. it fills with oils, so use some hot sudzy water and clean it out.
Oct 30, 2010 | Saeco Royal Digital Plus Coffee...
Water is coming from under the machine when coffee is dispensed from the beans
Remove the brew unit and check the small chamber under the white plastic valve, make sure it is clear and the small discharge chute from chamber to the drain tray is not blocked.
Aug 09, 2010 | Gaggia Syncrony Compact Coffee...
When making coffee, the machine has begun to leak water/coffee from under the machine. I removed the plastic assembly above the drain pan, cleaned some crud from the angled plate, mopped and cleaned the...
The chamber is fill with coffee grounds again and the water cannot make it to the drain tray, you can replace the O-rings on the white plastic valve and piston gasket on the brew unit, and clean out the small chute to the drain tray from that chamber.
Apr 16, 2010 | Gaggia Syncrony Compact Coffee...
I need to drain the boiler and winterize the machine for storage
The boiler drain is in the drain box, under the drain tray hidden beneath the black safety cover with the 4 small screws. There is a plug in the box, using a 17mm open end wrench you can open the plug to drain machine. It is also a good idea to drain the exchangers by disconnecting the fitting and letting it drain out, you will notice the 2 pipes going up at an angle to the exchangers.
Oct 07, 2009 | Nuova Simonelli Program VIP Coffee Maker,...
Water below brew unit in excess coffee tray. Over flows to counter top. Can I fix this and what will I need. Thanks, Jim
Remove the brew unit there is a small chamber under the white plastic valve, clean chamber of coffee grounds and water, there is also a small discharge to drain tray make sure it is not blocked.
Aug 22, 2009 | Saeco Magic Comfort Plus Espresso Machine
Water not getting through
If you look under that white nozzle you will notice a small hole that leads to the drain tray, clean out hole and the area or small enclosure around the white nozzle (clogged with coffee grounds), and make sure that if you pour a little water in that enclosure it goes to the drain tray. That will solve the water under machine problem.
For the amount of water from the coffee nozzle, check brew unit, you will have to remove the shower screen and clean, make sure that the unit is not clogged in one of the tubes.
May 19, 2009 | Solis Master 5000 Espresso Machine
Astoria Divina SAE-1 Espresso Machine Logo
135 people viewed this question
Top Astoria Coffee Makers & Espresso Machines Experts
Charles T Nevin
Charles T Nevin
J.D. Browning
J.D. Browning
obsteiner
Are you an Astoria Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
