Question about Garden
Remove plastic shroud off shaft from pto - Garden
  • 2,760 Answers
Never defeat a safety device like a safety cover on a pto , and allways connect small chains on cover to solid non moving parts to keep cover from rotating with shaft , so many folks i know have been really hurt even killed doing just that, removing the covers or leaving them unhooked , pto's are nothing to not be serious about
Posted on Jan 06, 2015
Pto won't disengage, unable to start tractor. pto attached to post hole digger in ground
It could be gear bound and not allowing it to disengage, i experienced that a few times in my farming days, we dug a lot of postholes with a PTO driven digger. What usually happened is i ended up getting caught on rocks and stalled out because i had the engine speed to low. What i generally had to do to fix it was remove the PTO shaft from the digger, disconnect from the tractors output shaft, then get it started and everything moving, then disengage the PTO and reconnect the post hole digger, then give her hell and get the engine speed up before re-engaging the PTO, that would generally shock it loose. If not then i would have to disconnect the PTO shaft again and spin it backwards by hand to rotate the digger in the opposite direction to remove the hangup.
Nov 25, 2015 | John Deere 670 770 870 970 1070 Compact...
Change seal for PTO kubota f3680
Remove the PTO shaft extension from the shaft put a drain pan under to catch the oil Tap a chisel or other tapered tool in behind the seal flange and work the seal out install a new seal an re-install oil up to full level
Jun 13, 2015 | Kubota Garden
Where on this unidentified fan do you put the oil?
remove the blade cover ,remove the blade, remove the large plastic lock nut , remove the screws to the shroud , now you have access to the oil points on the shaft bearings still wont be easy to git to.
Apr 18, 2015 | Dryers
How do you remove a pto from a 1042 cubcadet
If bolt broke in crank shaft - you'll need to get some professional help to get it removed. The PTO slides down off the shaft - but you'll probably need a wheel puller to get it off. I had to clamp the upper and lower halves of the PTO together to pull them off as a unit.
Jun 02, 2014 | Cub Cadet Garden
Remove clutch
I'm assuming you're referring to the PTO clutch on the bottom of the engine shaft. There's a 5/8" bolt that goes up through the clutch into the shaft. Remove it, but then turn it back in about 10 turns and use a wheel puller to start getting it off. You might have to c-clamp the PTO/clutch top and bottom together to get both pieces off. Once the assembly starts coming down the shaft, you can probably remove the wheel puller, remove the bolt completely, and pull the PTO/Clutch off by hand. Be sure to unplug the PTO/clutch before removing it. Also, many of these have a spacing washer on top of the PTO/Clutch that comes off in the process. BE SURE to put it back on before replacing the PTO/Clutch. DO NOT hit anything with a hammer to try to break it loose - you'll most likely NOT get the part off and most probably WILL damage necessary parts.
Jul 29, 2013 | Cub Cadet Riding Lawn Garden Tractor 25hp...
How do i remove the fan and pulley on a 1987 ford ranger 2.9 v-6?
The question is: How remove clutch in order to remove fan mounted on its engine-side face.
  • Generally, the clutch drive half shaft must be uncoupled from coolant pump (impeller drive) half shaft using special wrench kit available as loaner from AutoZone (free with $79 approx deposit).
  • Best done after shroud & radiator remove after coolant drained.
  1. Uncouple coolant pump and fan clutch drive shaft(s) as follows:
    1. span across combo-pulley-sheaves-unit mounting bolt heads with large tool kit wrench, and
    2. span inline clutch coupling nut with small tool kit wrench. Then,
    3. turn small wrench (and coupling nut) CW while resisting with large wrench (CCW) to turn coupling nut until disengaged from coolant pump drive shaft.
  2. Remove fan/clutch assembly.
  3. Note direction of mounted fan hub and fan blades orientation to ensure proper re-assembly.
  4. On rear of clutch assy, remove 4 bolts to disengage and remove fan.
  5. Assemble new fan to clutch (or, preferably, new clutch and new fan) using new bolts and washers provided with fan.
  6. Couple fan-clutch assy to coolant pump drive shaft as per opposite of uncoupling step 1, above. (Turn inline nut CCW to tighten...30 ft-lb.
  7. Check that fan can be hand turned...CW.)
  8. Rest shroud over and onto fan.
  9. Replace radiator; remount shroud; reclamp hoses, and refill and air purge cooling system.
Aug 12, 2012 | 1987 Ford Ranger
Briggs&straton all the oil leaked out from under the engine. the engine oil
hi there donald77
provided you have not got any cracks in the sump plate and the sump plate bolts are tight
sounds like you have a worn out pto seal ( please check pto for bend or wobble ) as this could have caused this from hitting something solid
it it is bent have it straightened before proceeding
remove the blade carrier and hub and key - clean up the pto with emery tape , drain oil , use a straight shaft flat blade screwdriver and lever the seal out of position
obtain a new seal place some thin plastic sheet ( from say a thin walled plastic container )
cut into a size that you can wrap around pto , then slide the seal over it up to the opening ,
the drive the seal into the housing squarely until the seal is flush with the housing ( on a non stepped pto ) 7/8 shaft
but on a stepped pto 25 mm drive it in further until its about 3 mm below the housing
reassemble and refill with oil
cheers hope it helps
pauly46
May 30, 2011 | Garden
I have a pto shaft that has boke in my case david brown 885 and i have it torn down to the pto shaft right now i just need to know how to get the shaft out
Take the gears out.Bell housing side of pto shaft, insert punch in hole and use allen wrench to remove plug on shaft end. use punch in allen screw hole to drive shaft out of housing (don't mess up the threads!!)
Aug 16, 2010 | Milwaukee Tool Case Heat Gun
John Deere 445 pto will not start Smoke from
If smoke is coming from solenoid on rear top side of trans then internal windings are bad but usually it will blow the fuse.Remove plastic nut from solenoid,slide solenoid off shaft then engage PTO.If solenoid does not smoke slide screwdriver or something like it into solenoid and see if there is any Magnetic force.If smoke comes from deck check idlers and spindles for movement.Be sure to ckeck gearcase oil level on the deck.
Aug 09, 2009 | Garden
Garden Logo
60 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
