Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
I have a liftmaster fromula 1 GDO. The lights do not come on when the dorr opens. The lightbulbs are good. Any help?
Wiggled sockets and sometimes worked. Now it does not. Aside from this problem (no lights), the GDO works fine.
  • 31 Answers
I have noticed on my most used opener that one of the bulbs center pin is corroding away and intermittently worked. Try to clean up the connection in the bulb base after making sure power is off at the breaker. Then apply liberal amounts of bulb grease (which can be found at any auto parts store) in socket threads before screwing new bulb in. So far that solved my problem, maybe yours too.
Posted on Dec 13, 2014
    New Friend:
  • 130 Answers
The above comment about the switch on the wall, this switch won't keep the light from coming on when the door is operated. If the bulbs are good then take them out and unplug you opener. In the bottom of the socket is a metal tab put your finger in and lift the tab up a little bit. Then plug it back in and try the bulbs. Sometimes the new bulbs like the CF's won't seat deep enough into the socket.
Posted on Dec 08, 2014
    New Friend:
  • 3 Answers
There may be a switch up by the lights, it may just not be set to turn on when the door opens. Also I found on mine, the opener attached to the wall in the garage has a button that turns the lights on and off.
  • 3197 Answers
SOURCE: My garage door opener works
Make sure you are using standard 60 watt bulbs. Some newer type bulbs are causing a problem. If you have a multimeter and are handy it should be no problem to check for 110 volts at the socket and trace the wiring back to the circuit board. There may be burnt or missing traces on the board itself. The click you hear is the relay that controls the lights so you know that is working but there is always the possibility the points are bad.
Posted on Jan 17, 2011
Testimonial: "That was it!!! My lights now work just fine!! Thank you, Thank you! "
  • 3197 Answers
SOURCE: I have 2 Chamberlain Liftmaster
Unplug the openers and remove the light bulbs. Using a small screwdriver pull out on the center contact in the light socket.
Posted on Sep 28, 2010
SOURCE: Liftmaster 1/3 HP - humming, but does not open.
It's the gear drive. There are kits online for about $40, if you're semi-handy you can replace it yourself. Search for liftmaster replacement parts.
Posted on Dec 16, 2008
  • 244 Answers
SOURCE: Remote Garage Door Openers won't work
Does your wall console have a LOCK or VACATION setting. Turn off.
Posted on Jan 15, 2009
  • 3197 Answers
SOURCE: Liftmaster Keypad problem
First thing to do is make sure it has a good battery installed. If this doesn't take care of the problem then the keypad is going bad and needs to be replaced. It is important that you get the same keypad as there are others out there that look the same but will not work.
Posted on Jul 23, 2009
Liftmaster GDO goes up 1/2 way and stops,springs are fine.
The Liftmaster openers have 4 movement switches, a )opening and b) closing limit and c) opening and d) closing force. First check the door for smooth operation by opening the door by hand (disconnect from the opener with the release cord). Any binding should be felt this way. It is possible for a binding hinge, roller or torsion springs to add too much drag and cause the force switch to shut off the motor. Hinges, roller shafts and torsion springs should be lubricated at least annually with a non oily spray (silicone or teflon spray). Not WD-40 or 3-in-1! A light band of lube should be applied to the torsion spring coils. If the door can be operated smoothly by hand, then adjust the closing force switch 1/4 turn at a time. This is a safety device do not use it to overcome another problem!
Aug 15, 2014 | liftmaster Garage Door 1/2 Hp
Garage doors work but the light on one of the inside opener keeps flickering, What do I do?
disconnect the power and try to pry the prong in the socket of the light outwords,check the connection in the unit itself
Jun 11, 2011 | liftmaster Chamberlain Garage Door Opener...
My clicker wireless keyless keypad won't open my liftmaster garage door
First, check the battery inside the keyless entry. It may have died and that is the whole problem. Replace it if necessary. If it has never been replaced previously, you might want to do that now anyway..
On the GDO there is a "smart" button located by where the wires are connected.
Press and release the smart button. Enter your code slowly and press enter. The light on the GDO should flash off and on to let you know the GDO has memorized the code.
Good Luck..
Jan 04, 2011 | Sears Craftsman LiftMaster Chamberlain...
The lightbulb in the unit burns out quickly, every 4-6 weeks. I have Lift Master 1/3 H.P. FCC ID #HBW1127, Part #41A4252-7D
You can buy bulbs designed for garage door openers. They are heavier duty. Also you should unplug the unit and remove the light bulb. Pull out on the center contact of the socket. Replace the bulb and plug the unit in.
Oct 17, 2010 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Liftmaster GDO just clicks, no lights no open/close
Pull the logic board and check it for burnt or missing traces on the printed circuit. Thunderstorms love logic boards.
Apr 25, 2010 | Sears Craftsman LiftMaster Chamberlain...
1/2 HP Craftsman Garage Door Opener works but lights don't
I think you are saying that normal incandescent bulbs do not work. If that is correct you should unplug the unit and using a small screwdriver reach into the socket and pull out slightly on the center contact.
Aug 07, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman GDO - Remotes not working
I think this is an easier way to program. Press and hold the button on the remote and then press and immediately release the smart/learn button on the rear of the motor unit. Do this for each remote you have.
Jul 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
My chain drive GDO will only work if i help it...
The motor will need rewinding, and the condensor will probably need replacing.
That should do it:)
Jul 27, 2009 | liftmaster Chamberlain Garage Door Opener...
Liftmaster gdo won't operate with door or remote
Hi there, when the problem first started was the door being used frequently? If your GDO was used quite a few time's in a short period of time the "overload" may have triped. The makers of all GDO's now adays install an overload witch is an electrical safety device protecting the motor. This prevents over heating in turn burning up the motor. To rectify unplug for 15-20 mins. If you have Model number 1270 turn to pg. 7 in owners manuel. Insure all door locks are free. Insure power to electrical outlets by pluging desk lamp in same out as GDO. what model do you have?
Mar 17, 2009 | liftmaster Chamberlain Garage Door Opener...
Red light/stuck GDO Sears 139.53600
is it locked. does door lift manually. are springs/cables ok?
Jan 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
103 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
