Question about Intellicode Building Materials
Have a genie 2024, wall console, remote, and intellicode from vehicle will not operate door open or close, sensors are in line, limits have been set
Product is only 2 1/2 years old
    New Friend:
  • 130 Answers
Check and make sure the lock button on the wall switch isn't turned on
Posted on Dec 09, 2014
Garage door will not close
if you can hear the motor running but nothing is happening then the internal gears may be stripped. if the motor does not run then it is electrical and could be several things.
Mar 07, 2015 | Genie Company Genie Gictd3 Three Button...
HOW TO RECONNECT INTELLICODE GARAGE DOOR CHAIN TO SAFETY CAM
please read carefully your owner manual, if you do not have a recommend to download from www.fitness.manualsonline.com or
www.manualsfactory.com
and proceed according with common sense
God bless you
Sep 09, 2012 | Genie Company IntelliCode GICT390-1BL...
GT3-R -can
This is a dual frequency transmitter. (315/390) You need to select one button to program the TYPE 1 frequency of 390 MHz. Here's how:
Backwards compatable programming instructions for GT3-R dual-band remote: This is a 3 button remote, which can be used to operate up to 3 garage doors using IntelliCode radio controls. This remote is defaulted to operate the new IntelliCode 2 Genie garage door openers, but you can also program individual buttons to operate other IntelliCode 1 (pre 2011) models of Genie garage door openers made from 1998 to present. To change a button to operate a pre 2011 IntelliCode opener, the default IntelliCode 2 setting must be changed to IntelliCode 1. An LED light on the remote displays which mode the remote button is in: Red = IntelliCode 1 / Green = IntelliCode 2 To set one of the 3 buttons to be IntelliCode 1 (red), follow the instructions below:
  1. Select a button on the remote that has not been programmed.
  2. Press and hold that button for 10 seconds. Both Red and Green LEDs come on and stay on.
  3. Press the same button twice to toggle IntelliCode selection from IntelliCode 2 to IntelliCode 1.
  4. Press the same button again to confirm toggle. the LED should be Red. The IntelliCode selection for this button is set to IntelliCode 1.
You are now ready to program the remote to your garage door. Follow accompanying instructions for "Programming to IntelliCode 1 Genie garage door opener," or see below instructions: Programming Instructions: Gently press the Receiver Learn Code button on the power head receiver of your Genie garage door opener (motor head on ceiling in garage). This small, black, unmarked button is located behind the light lens at the motor head and is nearest the floppy 6 inch antenna wire that protrudes from the motor head. When pressed, a radio signal indicator light will start blinking red for 30 seconds. After pressing the Learn Code Button, press your transmitter button twice for your system to grab the frequency and code it in. (Keep the transmitter you're tuning at least 2 feet away from the power head while tuning.) Press the transmitter button once more to test the system and start your door moving.
Jan 06, 2012 | Video Game Consoles & Games
GARAGE DOOR DOESNT CLOSE COMPLETLY UNLESS I KEEP THE BUTTON PRESSED!
There are probably two photo sensor near the ground at either side of your garage door. They are there to stop the garage door from closing if there is something in the path of the door. Likely one of the sensors got bumped or moved and it is not lining up correctly. Adjust the sensors until they line up and allow you to close the door by pressing the button on your remote once.
Jun 11, 2011 | Genie Company IntelliCode GICT390-1BL...
Genie Garage door will not close. Receiver Model: ACSR3 FCC ID: BBQ ACSR3
If you hit the button on the remote and nothing happens then you may need to code in the remote. On the motor head press the learn button and then press the button on the remote 3 times.
If it looks like the remote will work the opener or it opens the unit but not close it you are experiencing safety sensor problems. Make sure they are aligned. There will be a light on each and each should be on. Check the wiring to them too. They are not polarized. Thanks BB
Aug 20, 2010 | Genie Company Genie Intellicode 1-Button...
How to set acsctg type 2
There is a button on the motor head you can press. Press it then press the button on the remote 3 times and try it. If not try it again. Genies are bad for not coding in the first time. Make sure there are new batteries in it. Thanks BB
Jul 19, 2010 | Genie Company IntelliCode GICT390-1BL...
Genie Compact 3-Button Remote control will only open 1 door/not 2
On some of the remotes you will find a toggle switch to change frequencies, this might help. Note all new openers are operating on a different frequency than slightly older ones due to military interference. Even though both might be intellicode they might not work together on the same remote. Sometimes some openers are harder to program than others. So lets try to program the harder one. You need to find and press the learn button on the motor head. Then press the button on the remote once. The led light by the learn button should not flash. If so try it over. The light should either stay lit or go out after the first press. If it does press it again and then a third time. If it ever flashes during the program process try again. The third or fourth time the motor should operate. If not you either have a bad remote or more than likely a bed logic board. Thanks BB
May 15, 2010 | Genie Company IntelliCode GICT390-1BL...
I need to replace the battery on a Genie GICT-390 garage door opener. How do I open the case?
If its a lighter grey colored intellicode remote: There should be a small slot on the side of the remote. Use a coin such as a dime or a penny, stick it in the slot and twist. The remote should split in half and you'll see the coin-shaped battery. After you replace the battery, you can snap the 2 pieces of the remote back together.
If its a dark grey/black intellicode remote: The back cover should partially flip open to reveal the battery. This remote takes a 12volt N-size battery.
If its a keypad remote you are referring to: The bottom half of the keypad's face should slide straight down to reveal the battery (you should see and arrow and some thumb grips). All Genie keypads take 9volt batteries. Source(s): I am a genie technician
Oct 24, 2009 | Genie Company IntelliCode GICT390-1BL...
Building Materials Logo
127 people viewed this question
Top Intellicode Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you an Intellicode Building Material Expert? Answer questions, earn points and help others
