I am running 3 sr40s at the same time one of the units goes oj mute on a regular basis any ideas how to fix
My screen goes in/out and blank a regular basis, is there any way this can be fixed?
JUST AND MAKE SURE ALL THE CABLES GOING FROM AND TO THE CABLE BOX ARE INSIDE CORRECTLY AND IF THEY ARE IS YOUR SRCEEN ISSUE.
Sep 28, 2014 | Olevia LT42HVi 42 in. LCD Television
Ice maker making loud noise for exrended times on fridgidaire
water will condense and then freeze in the fan area. Need to remove freezer inside back panel and remove ice from fan area. Fan is located abot @/3 down on right side. No permanent fix I have to do it about every three months.
May 11, 2014 | Frigidaire FRS26R4A Side by Side...
Where can I buy this item with an extra sensor
Don't think you can buy the sensor by itself. Just purchase another "pair" on Amazon or some place similar. A single receiver (the powered unit inside the house) can pair to multiple sensors and it is a good idea to have a spare as these can be troublesome in my experience (some units lose contact with the sensors and have to be paired again on a regular basis, support says this is "normal").
Feb 07, 2014 | Chamberlain UNIV GARAGE DOOR MONITOR
Audio muffled when playing back video tape
Have you tried using a wet type head cleaning tape? If not, run one thru at least 3 times.
Feb 05, 2009 | Sansui COM3101 13" TV/VCR
Unit runs but no water in storage tank
Make sure conditions are not too cold or too dry already.
Is the compressor running?
Set the unit to the continuous run setting or the dryest setting
compressor should start.
If compressor runs but the evaporator doesn't get cold the freon has
leaked out.
If compressor doesn't run no matter what you do the board may be bad.
Also the fan must blow air.
Sep 30, 2008 | LG DH30 GoldStar Dehumidifier
Toshiba e800 freeze ups...
ctrl q will close the program
Oct 24, 2007 | Toshiba e800 Pocket PC
Flashing lights
Hi, I work on these on a regular basis and have seen the problem many times. Almost every single time it's caused by a faulty fuser (fixing) unit. They are fairly easy to replace but they run in the 2-300$ range in cost. Good luck.
Aug 29, 2007 | Brother HL 5250DN Laser Printer
Monitor pulses and resets the screen on a regular basis
OJ I am fairly sure that the Power Supply is failing, try replacing ALL Electrolytic Capacitors in the Power Supply section that often "Fixes" any problems. Oh use Higer Temperature and quality ones, when doing it..
Jul 02, 2007 | Dell E173FP 17" LCD Monitor
50 people viewed this question
 Grubhead
Grubhead
