Question about Cycling
How to connect front wheel on 16 inch Princess kids bike?
The fork is too narrow to accept wheel bolts
    Master:
  • 706 Answers
Fork must be spread. I use brute force by putting fork on its side on the payment, then pull on other side.
Posted on Dec 10, 2014
Testimonial: "This is bad advice. The fork is one(1) inch too narrow and there is no way the fork can be spread without damaging it."
  • jfbgm1
    jfbgm1 Dec 11, 2014
    Then wheel is not correct for this bike. Find a wheel that is an inch smaller between the axle nuts.
Front forks on a 1987 Honda Goldwing motorcycle how to change them
Place bike on center stand.
Jack the front of the bike to raise the front wheel off the ground. Be careful!!!
Remove the front wheel.
Remove the front fender and cross brace.
Disconnect the brake calipers from the forks.
Remove the air connections from the fork tops.
Loosen the fork leg clamp bolts on the triple tree.
Slide each leg out of the bike. Twisting while pulling often helps.
This can also be done without removing the front wheel but you will have to elevate the front of the bike another foot or so - just disconnect the air fittings and brake calipers, loosen the clamp bolts and drop the whole front assembly.
Jul 22, 2014 | Motorcycles
Huffy 12' bike front wheel doesn't fit
Mine had the same problem and there was no way bending the fork was going to work. It turns out they had installed an extral washer and nut on the axel. Take one off and retry fitting it. It may only go on one way. Make sure, before you tighten it, that the wheel turns freely.
Dec 25, 2012 | Huffy Disney Princess 16 in. Girls Bicycle
I need a replacement front wheel for a 16" Disney Princess bike. I cannot locate in local stores (ie, Walmart) or on line.
You need to search on-line for the size of wheel, not by the model of the bike. Look at the tire, it will be labeled with the wheel size.
Sep 02, 2011 | Huffy Disney Princess 16 in. Girls Bicycle
I just took the parts out of a box 16" princess
The black plastic caps on the axle are just to protect the threads during shipping. You can throw them away. There may also be a plastic spacer on the front fork that keeps the fork from becoming bent together during shipping. This can be discarded too. good luck. Al K
Dec 31, 2010 | Huffy Disney Princess 16 in. Girls Bicycle
I bought the huffy 16"
It's pretty hard to know how to help you exactly. But this may help--- if you have (or can borrow) a digital camera, take close-up pictures of your parts then take the camera with you to a Wal-mart or wherever this bike is sold. Compare your pictures to one on display. Or better yet, take the whole bike with you. Or just take close-up pictures of the bike on display. It might also be useful to know that the front fork (that is the two metal bars about 10 inches long that point toward the ground that the wheel attaches to) sometimes have to be spread apart just a bit to fit the wheel's axle in place. I'm talking about maybe 1/4 inch or so. If it's a lot more than that the fork may have gotten bent in shipment and you should take it back.
good luck, Merry Christmas. Al K
Dec 23, 2010 | Huffy Disney Princess 16 in. Girls Bicycle
I cant the handlebars to turnh the wheel doesnt seem to grasp am i missing a part
Tighten the 7/16 inch bolt that goes down into the neck where the front wheel attaches to the frame.
Jun 26, 2010 | Huffy 26 in. Cranbrook Cruiser Bike
Fork is too narrow for front wheel
One solution, is a large, wedge shaped piece of wood.
Try hammering that into, or the forks onto it.
That should open them up, without damaging the finish.
Good luck with that.
Jul 22, 2009 | Dynacraft Girls 16" Barbie Bike
Kids huffy bike
well forks might be bent loosen the nuts all the way off the rim now try squeezin the forks or pullin them apart depends on the problem...maybe this will help
Dec 14, 2008 | Huffy Disney Princess 16 in. Girls Bicycle
Cycling Logo
91 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
