Question about mid M9100 9" Dual Camera Android 4.0 ICSOS 1.2Ghz Capacitive Mu
I can' get my tablet to stay on, it is charged and the only thing when plugged in that comes up is kocaso then android.
Charging and turning it on by pushing the the power on.
I charged my tablet up but it won't stay on. I do't use it a lot,
Sounds like battery to your tab is weak. [Charge holding problem], Check it with an other new battery. Electro help
Dec 08, 2014 | Kocaso M M9100 9-Inch 8 GB Tablet
Kocaso comes on but only shows the word android
It is not loading the operating system, only the Linux starter program. try power resetting it.
you can try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
Support Troubleshooting Guide
Jun 04, 2014 | Kocaso M M9100 9-Inch 8 GB Tablet
My Kocaso M736 tablet is not fully turning on. If it is not plugged in, the screen will stay black and won't turn on. If I have it plugged into the charger and press the power button and hold it, the
Sounds like your battery is shot. If it goes to far past dead, it will not power up even plugged in. Go to a battery store/Best Buy etc. and see if they have one you can use to try. Certain battery types can not go under 25% of a charge or they will not charge again correctly and vice versa. Just a short in the dark but hope that fixes your problem
Mar 07, 2014 | Kocaso BRAND NEW M736 7" High Resolution...
Kocaso m766 cannot charge
You have damaged the USB socket in some way.
Feb 27, 2014 | Kocaso M766 Dual Core 1.5Ghz Dual Camera...
We need a plug
The charging on the tablet depends on the model.
Most including the Kocaso 776 charge via the micro USB port, and this is a standard USB port.
So all you do is purchase a micro USB to standard USB cable and plug it into the standard USB port on the charger or a PC.
Feb 07, 2014 | Kocaso 7" Capacitive Touchscreen Tablet...
How to factory reset
Try this power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it.
Feb 06, 2014 | Kocaso M1050 10.1" Android Tablet PC with...
Can i charge my kocaso tablet wirelessly
No, the only to charge it is via the USB socket.
Feb 05, 2014 | Kocaso M730W 1.2GHz 4GB 7 Capacitive...
Tablet wont turn on
My Xelio P1001A tablet wont come on
Jan 02, 2014 | Kocaso M860W 1.2GHz 4GB 8" Capacitive...
Android tablet m750b KOCASO problems loading
Turn it off completely. Either by reset or shutdown.
Leave it off.
plug in charger and leave it alone for 4 hours.
Power it back on.
Jun 03, 2013 | Kocaso MID-M750B MID-M750B 7-Inch Tablet...
mid M9100 9" Dual Camera Android 4.0 ICSOS 1.2Ghz Capacitive Mu Logo
606 people viewed this question
Top mid Computers & Internet Experts
David Payne
David Payne
Are you a mid Computer and Internet Expert? Answer questions, earn points and help others
