Question about Frigidaire Kitchen Ranges
Frigidaire electric stove (ES200/300) was on (all elements and over) last night, then shut down by itself...won't turn back on, nada, dead, not even the clock...can I fix it?
Unplugging, then plugging it back in...shut down the circuit breaker in the basement, turned back on. Doesn't work, still everything is dead even the clock.
  • Official Brand Answer
  • 2,267 Answers
Thank you for your inquiry, Jim Riley!
From the information you have provided your Frigidaire range is no longer operating. It could be a faulty EOC (Electronic Oven Control) or wiring harness. This is not a simple DIY job. I would highly recommend having a professional technician come out to properly diagnosis your range because they would have the tools needed to review each component to locate the problem. Additionally once the faulty part has been located they will be to properly exchange it without creating any future issues. Best of luck! -Matt
Posted on Dec 10, 2014
Broke Frigidaire Stove
Looks like you have a blown thermal fuse. If you have electrical knowledge you can open up the back, locate the thermal fuse and test it with a continuity tester.
Apr 23, 2013 | Camping, Backpacking & Hiking
We have a Frigidaire electronic ignition range about a decade old. The stove works fine. But lately we've noticed if we're using any stove elements the oven won't ignite and heat up. Conve
Sounds like the pressure regulator on the stove is going bad. The pressure regulator is located in the back. Your gas supply line should connect directly to it.
Dec 23, 2012 | Kitchen Ranges
I shut the tv off last night and now it won't turn
If total dead (no lights on blinking etc) follow power cord into the set and find and check the main fuse--in this set it usually is a glass 5 amp fuse.
Dec 19, 2012 | RCA P52926 52" Rear Projection Television
Last night, we were using our Frigidaire oven to heat some salmon. My wife openned the oven door and there was a bright flash with sparks and a crackling noise, and a 1/2 inch portion of the element caught...
Kill the power to the stove. L2 is always hot to the element. If it welded itself to the frame whats left of the element stays hot. Easy fix but power needs to be OFF
Apr 17, 2010 | Ovens
My stove has started to beep random--why
WE used the broil button last night and our stove started beeping nonstop.It also say F1 three hrs of beeping we unpluged it for the night.When we turned it back on today same thing happened with the beeping and F1.hOW CAN WE FIX THIS?
Oct 28, 2009 | Frigidaire FEF336BC Electric Kitchen Range
Oven shuts off
It possibly incompatible heating element installed on the oven that's why it pops up when you try to turn on and heat it..
Feb 24, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Stove top and oven will not heat
first check your voltage, and the pigtail connections at the stove, then check your elements inside the oven something has shorted
Oct 27, 2007 | Frigidaire FEF366DC Electric Kitchen Range
Kitchen Ranges Logo
111 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
