Question about Poulan Pro Chain Saw 46cc 20"
Chain saw starts after 10 seconds stalls
Clean the plug and the filter, check the fuel, when it starts it stalls can't pull the trigger and let it run open it stops
  • 743 Answers
You should feel a little bit of bucking when pulling the rope. If you don't, there is a chance the compression isn't up to par... there is one more thing that should be considered before going too far; some of the carburetors used a vacuum line from the bottom of the cylinder that goes to the top of the carburetor. If that cracks, it can cause this problem.
Posted on Dec 08, 2014
    Master:
  • 706 Answers
It sounds like from your description that it's time to rebuild the carb. The other thing you can try to get you by for a while is turn the low side adjustment out a 1/4 turn CCW and re-try. If turning out the low side adjustment doesn't help, it's time to rebuild the carb and change fuel lines and filter.
    Sergeant:
  • 322 Answers
Sounds like a stiff diaphragm in the carburetor. With the cost of carburetors it can sometimes be easier to just replace it but it definitely needs a kit
dennisgladx
  • 52 Answers
SOURCE: poulan Super 1800 16" chainsaw .
Hi dortfran,
My name is Dennis and I hope to be of assistance.
This sounds like a kink in the chain and I would try a new chain because this can be a very small kink and very difficult to find and straighten out. If you must put the chain saw in a vise by clamping the bar and run the chain back and forth from the sprocket to the bar grove under operating tension and locate the misalignment at the bargrove. Now you have located the problem but the fix is still sweat away, and with some luck you may be able to spring the chain straight and have the link flexable to opporate without a hitch.
Glad to be of assistance. Please rate the solution because i can learn from your rating.
Thank you
Dennis
Posted on Nov 09, 2008
  • 9 Answers
SOURCE: Poulon Wildthing 18" Gas Chain Saw
Some Poulans vent thru a fuel line going from the tank to the carburetor. Some vent thru the cap but eventually the duck bill valve starts leaking fuel. Then I suspect some people change that cap to one without a vent, which causes the problem you are describing.
Posted on Oct 26, 2008
  • 205 Answers
SOURCE: Stihl chain saw won't achieve max rpm
Crank seals are leaking, causes lean or low vacuum for the carb to work properly
Posted on Mar 26, 2009
Fog Horn
  • 17 Answers
SOURCE: Have a Poulan Gas Powered Chain Saw, I haven't started in 10 yrs.
Not used in 10 years. Was there gas left in the tank? If so the carb is likely gummed up and may need to be taken apart and soaked in "Gunk" solvent and a new kit installed.
Posted on May 26, 2009
mark24354
  • 776 Answers
SOURCE: I have a poulan pro pp4620avhd chainsaw. I can get
The best thing you can do to these engines it take them completely apart - take piston out and everything. Believe it or not, my 12-year-old son was able to do it - very few parts in these little 2-stroke engines. He polished the carbon off of the piston with a drummel tool and cleaned everything with carb-cleaner. Put it back together and it ran like a champ. Still does. It was a great learning experience for him too. The worst that can happen is you have a bunch of parts that you will throw away.
Posted on Mar 19, 2010
Chainsaw stalls
Not sure what to say other than its fuel starvation, if not already done replace the fuel filter in the tank, if no better i would suspect a massive air leak, so replace the crank seals, if there is no primary compression in the crankcsae fuel will not pull through the engine, good luck.
Feb 05, 2013 | Echo CS400 18" Chain Saw
I have a 345 e Series 18" (I think it's 18). It's a couple of years old and probably no more than 3-5 total hours usage. Normally starts and runs perfect. Today it won't run, seems to be starving for gas....
If stale fuel has been left in the saw then try draining the tank and re filling with fresh fuel, also hook the fuel line out of the fuel tank and replace the filter on the end.
Apr 15, 2017 | Husqvarna 18" 502cc Prosumer Chain Saw ...
The saw starts but not easy runs for about 5
Either the throttle is stuck wide open, or there is a large air leak behind the carburetor to cylinder connection. Make sure the carburetor is securely fastened. If it has a flexible connection to the engine, remove the connection and inspect it for tears or holes. Watch the throttle arm on the carburetor which should move from the idle speed screw to the full throttle limit casting/post when the trigger is pulled and released. If it hangs near full throttle, then remove the trigger mechanism (make notes of the parts positions) and clean out any dirt/sawdust. Check the air cleaner and muffler for plugging. Check the H needle adjustment after repairs by running the engine at full speed after warm up--the engine should 4-stroke unloaded, but immediately 2-stroke when cutting. Check the condition of all of the fuel lines including the line to the filter in the tank looking for decay or other damage. Use original rubber lines for replacement, not plastic substitute. Hope some of this helps!
Jun 29, 2010 | Electrolux Poulan Pro Gas Chain Saw...
My husqvarna 61 starts fine and runs great for about 15 seconds and the it flat out stalls. Over and over this happens. what can i do?
Make sure the chain can be turned by hand and is well oiled. Check the muffler, fuel filter, and air cleaner for plugging. Check the condition of the fuel lines and primer button--does the primer pull fresh fuel into it when pumped? Check the carburetor fasteners for tightness including the mounting to the cylinder. If there is a rubber isolator between the carburetor and cylinder, check it for cracking or any holes. Make sure you are using modern synthetic saw oil in the fuel, not boat motor petroleum based oil. If still acting up, clean and re-kit the carburetor. Hope this helps!
Jun 09, 2010 | Husqvarna Chainsaw Piston Kit for 61...
I have a poulan pro pp4620avhd chainsaw. I can get it to start and stay running as long as I have the choke on. I can even run it at high speed using the choke control. When I pull the trigger to feed it...
Check the fuel filter and muffler for plugging. Check the fuel lines for condition. Check the carburetor fasteners for tightness. If the saw has a lot of hours, remove the lower section of the carburetor and check the condition of the diaphragm--it should not be hard/cracked. If everything seems to check out ok, Turn both jet screws CW to stops (lightly), then CCW each 1-1/2 turns. The engine should start and run--allow the engine to warm up. Pull the throttle full on and adjust H needle CW til the engine speeds up, but still 4-strokes. Proper adjustment is when the engine 4-strokes, but immediately 2-strokes when cutting. Let idle and adjust L CW so that the engine runs fairly well, but allows the engine to 'follow the throttle'. Adjust the idle speed screw so that the chain stops turning, but the engine continues to run. Hope this helps!
May 11, 2010 | Poulan Pro Chain Saw 46cc 20"
Chain saw won't start
Check the fuel filter for plugging (which is common when fuel is left in the machine over winter storage). You should run the carburetor dry after emptying the fuel tank for storage.Hope this helps!
Apr 14, 2010 | Poulan Pro Chain Saw 46cc 20"
Chainsaw will start but will not keep going.
May need to overhaul the carb. I suggest that you replace the fuel line and fuel filter too.
Apr 08, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Saw stops when i give it gas.
  • plugged fuel filter
  • cracked/loose fuel line allowing air (instead of fuel) into the carburetor.
  • poorly fitting fuel cap
  • plugged or disconnected/broken pumper line
Feb 16, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
345 husqvarna chain saw will not run
If it idles it is not flooding out as it it most vulnerable to flooding at idle if the stalling is happening as you try to throttle it up it is likely starved for fuel. Start by changing the in tank fuel filter, and the spark plug. good chance that will solve your problem. If it does not Turn the high idle screw out in 1/8 turn increments try running the saw after each adjustment. Keep track of the amount that you turn the screw. you might have to put it back to its original position. Some times adjustment screws will vi berate out of adjustment and other times crud will cause fuel restriction opening the screw allows for a larger port for any restrictions to pass through. After you use the saw for a short time turn screw back in if it starts to stall at idle or you notice increased smoke.
Jan 05, 2009 | Husqvarna Forest & Garden No.967012396 345...
Husqvarna mod 41 chain saw wont start
If checking spark make shore the out side if plug is earthed to chain saw.
Fresh clean fuel, clean fuel filter filter pull exhaust off and check piston is ok. Than check for flooding. start there.
Jan 03, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Poulan Pro Chain Saw 46cc 20" Logo
89 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
