Question about Kocaso M M9100 9-Inch 8 GB Tablet
I charged my tablet up but it won't stay on. I do't use it a lot,
Charging it, but the only time it comes on is if I plug it in, then only kocaso will appear and then android then it goes blank.
    Top Expert:
  • Kocaso Master
  • 75,169 Answers
Sounds like battery to your tab is weak. [Charge holding problem], Check it with an other new battery. Electro help
Posted on Dec 08, 2014
My RCA tablet wont charge I have to lean it against something to charge WHY??
Help! My tablet won't turn on! what do I do?! - Asus - Android ...
www.tomsguide.com/forum/id-1869519/tablet-turn.html
Oct 17, 2015 - 50 posts - ‎43 authors
We often get questions such as " My tablet has stopped charging & I have .... Maybe the case was designed badly and the power button won't ..... Something must havelocked the Memopad open and ran the battery completely down. ..... I had RCA send a replacement tablet after it happened the first time.Missing: lean
Why can't I get my RCA tablet rct6077w2 charge or turn on ...
forums.androidcentral.com > Get Help & Give Help! > Ask a Question
Oct 8, 2014 - 4 posts - ‎1 author
Screen will not light up at all. Took it to store, got brief charge there. At home, now, no indication of power.....Missing: lean
How to Calibrate Your Mac, iPhone, or iPad Battery ...
www.macblend.com/how-to-calibrate-your-mac-iphone-or-ipad-battery/
Mar 14, 2012 - The iPad and other tablets draw more current to charge quickly then a lot of other USB devices ..... Also, it's not something you should have to do frequently. ... iPad 2 will not charge shows battery in red with electrical symbol and plug symbols flashing on ..... I'd lean against trying to restore if it won't stay on.
My samsung galaxy tab wont charge at all, why? - Ask Me Fast
www.askmefast.com > ... > Charge
Dec 06, 2015 | Tablets & eReaders
Tip
Power Cable Popping Out on Versus Chinese Tablet
Versus Tablets (sold mostly in the UK and Ireland until 2014) have some great features (like HDMI out and Bluetooth), but power is a problem. They do not charge through the USB port, but through a 3.5mm barrel jack plug (specs are 5v 2000mA).
The power cable on my Versus Android Tablet keeps popping out (and therefore the tablet won't charge). Lately it got so bad that the plug simply wouldn't go in at all. I did a bit of research and came up with a fix.
There's a small plastic ring at the top of the plug. Take a precision pliers and pull the ring off the plug. BE CAREFUL! - If you damage the plug it simply won't go in at all, and your tablet will be useless.
Without this ring the plug stays in and the tablet charges. It still pops out occasionally, but a lot less than it did before.
NB: I do see some replacement power adapters with these plugs available on eBay and Amazon, so you may be able to try out a replacement power supply too.
Versus Tablet
on Feb 01, 2015 | Tablets & eReaders
I have an Asus Memo Pad HD 7 which I purchased 3 months ago. It worked wonderfully until one evening while using the pad plugged into the wall, it stopped showing the charge icon in the upper left hand...
the more programs you install and run in the back ground the more the battery is drained. It comes to a point where there are so many programs running the gadget cannot run & charge at the same time. It might charge better if you uninstall a lot of programs or do a factory reset but that is drastic
Oct 30, 2013 | Tablets & eReaders
Mid model m729b
I have similar problem, my buttons on the right side including yjr start button have slipped inside the case and I can not restart the charged device, Can you help?
Pat Green, pgrex@hotmail.com, 409-782-2572, thanks if you can help.
May 07, 2013 | mid Archos M729B Android Tablet
7" touch andoid tablet won't charge
It may be the charger has a loose wire. In that case a new charger would fix the problem. Mine has a problem with the charging port itself. I am fortunatly that my tablet is under warrenty they are going to replace the tablet for me.
Dec 27, 2012 | Nextbook Premium 7 Capacitive Touch...
My tablet won't come on I've had it charging so the battery should be full is there something I can do?
try to hard reset or soft reset, for this procedure search on gogle.com how to reset tablet, that will be helpful.
Jul 02, 2012 | Coby Kyros 716829701508 Tablet PC
My galaxy tablet just went dark. No screen or power. It was more than 50% charged last I looked an hour before. It has been plugged in for 20 minutes now and it won't turn on. What happened??
it depends.. check the battery pack maybe this cause a over charge and check first if your galaxy tablet is still part of the warranty this will help you a lot.
Dec 09, 2011 | Samsung Galaxy Tab Tablet PC
AC adapter/charger is attached, but the battery will not charge. it doesnt even show that the battery is there
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jun 21, 2011 | Toshiba Portege M200-S838 Tablet PC
I just purchase Pandigital multimedia novel 7"
It sounds like your in sleep mode. Hold the power button till the display says power off and tap the power off on the display, the charging light will come on and the charging light will change color when it is fully charged. Here is the link to the pdf quick start guide:
http://www.pandigital.net/userfiles/file/Downloads/QSG_%20PRD07T-1_v2.2_09-08-10.pdf
Hope this helps thanks for using FixYa
May 13, 2011 | PANDIGITAL Digital Book 843967071153...
Kocaso M M9100 9-Inch 8 GB Tablet Logo
93 people viewed this question
Top Kocaso Tablets & eReaders Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Lawrence Oravetz
Rick Ostrowski
Are you a Kocaso Tablet and eReader Expert? Answer questions, earn points and help others
