Question about Admiral Washing Machines
I don't have a tech sheet for my admiral washer model number atw4676bq. i was washing a blanket and got off center. now my washer knob isn't moving to each cycle. please help
I don't have tech sheet to complete the diagnostic testing
  • Admiral Master
  • 5,323 Answers
Sounds like the tteeth on knob are broken or stripped?
Posted on Mar 09, 2015
  • 641 Answers
SOURCE: 417.4405200 not spinning at the end of wash cycles
Does the washer was loaded when you make the diagnnostic test ?
Posted on Jul 20, 2007
  • 41 Answers
SOURCE: Kenmore 417. 4405200 Front Load Washer error code E43
It's a bad wax motor inside the door latch. The diagnostics are buggy and do not test it properly. It should measure about 1.5K ohms, and when 120 VAC is applied to it, it should extend in about a minute. Part number 12002535 is $10 to $15.
Posted on May 14, 2009
  • 119 Answers
SOURCE: Kenmore washing machine model 110 wash cycle stops
DOES IT DO THIS ON EVERY WASH OR SOMETIMES? IF SOMETIMES, CHECK LID SWITCH( THERE'S A LITTLE HOLE WHEN YOU OPEN THE LID, ON THE LID SHOULD HAVE A LITTLE PLASTIC PIECE THAT GOES IN THAT HOLE. THE SWITCH IS UNDER, INSIDE THAT HOLE. YOU CAN GET A PEN OR KEY TO SEE IF IT'S BROKEN.)
BOYNISMO@YAHOO.COM
Posted on Aug 21, 2009
  • 713 Answers
SOURCE: I have a Fisher Paykel Model GWL 11 washing
Yes I can help.Starting from left to right on the line that the lights are lit the fault code values of each are , Starting from the far left they go 1st=128 2nd=64 3rd=32 4th=16 5th=8 6th=4 7th=2 and 8th=1.Add up the lights that are lit on your machine and reply back and I will let you know what part is faulty.
Posted on Jun 05, 2010
dcramer531
  • 1654 Answers
SOURCE: Model # 110.22064101 Kenmore calypso elite washer
The motor coupling is about to completly go out on you and then it will not spin at all. This is common on these machines. the repair should be under $100.00. The motor brake may also be dragging.
Posted on Nov 10, 2010
LID LOCK SWITH ON ADMIRAL ATW4676BQ BROKEN, WHAT HAPPENS IF SWITCH IS BY PASSED BY CONNECTING WIRES SO ITS ON ALL THE TIME?
If its a micro switch it will not lock lid when running so machine will continue to run when lid is raised if it is bypassed.Most locks on washing machines are anti-child devices so might not be good idea if you have children.Machine will run and switch off when program finishes.
Feb 21, 2015 | Admiral Washing Machines
Admiral washer leaking water from bottom
What is the model number of the unit?
Nov 24, 2012 | Admiral Washing Machines
I have an Admiral top-load washing machine (Model AK44000) which now leaves some items (especially kitchen/tea towels and bathroom towels of all sizes) with a 'funky' smell (like bad body odour)...
How old is this machine? Older machines' gaskets loose their property of remaining intact & melt like semisolid due to use of detergents, which are likely causes for the foul smell.
Sep 18, 2011 | Admiral Washing Machines
In which function shall i wash blankets and bed sheets
Hi 'tigist wondi' from retired Englishman in SW France,
Couple of suggestions- first I think that you need a manual for now and later-
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
Then-
Blankets and bed sheets
Wash separately!
Also I would expect them each to have a washing advice 'tag' to show you at what temperature and for how long. Blankets will be a cooler, shorter wash than sheets and sheets will depend upon whether they are coloured or white but mostly much hotter and dependant on how often they are changed.
If these have assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Jul 28, 2011 | LG Washing Machines
Crosley washer (caw12444xwo) is not filling up all the way and is not spining out all the way, just got it today and just tryed to wash a blanket?!
Contact the vendor before doing anything else, especially if it is new as it will be under guarantee!!! Even if it is not new it should be under some sort of guarantee. Washing a blanket as a first try is possibly not the best thing to do- garments, sheets are not 'heavy' items and should let you get used to a 'new' machine ;-0)
Do you have a manual? If not you will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
If this has assisted you please consider a 4 thumbs up for the rating.
John C.
Jun 16, 2011 | Crosley Washing Machines
I own a kenmore top loading machine model number 110 10 amp 60 hertz 120 volts the machine gets power and runs but the big control knob that controls the diffrent cycles is running only about 20 seconds...
sounds like you should replace timer (big control) timer motor is part of timer. Is timer knob speeding thru cycle that fast or just start/stop.
110 is manufacturer code for whirlpool, number after decimal is model number. tech sheet avail inside console by unsnapping left and right console covers and removing hidden screw at front bottom corners, pull forward slightly then fold console back (hinged at rear top).
Apr 26, 2009 | Kenmore 22642 Top Load Washer
Washing Machines Logo
100 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
