I NEED IGNITER PART NUMBER
FURNACE ABOUT 15 YEARS OLD, HAVING TROUBLE FINDING THE IGNITER PART NUMBER
    Novelist:
  • 170 Answers
Bring it in to the heating and air-conditioning wholesaler and show it to them ----they should be able to match it up ---also go to your search browser and type in "igniter"---it should show you all types of them so you could match it up then check to see what it fits-- after matching it up it should list your heater as one of the heaters it fits----good luck
Posted on Dec 08, 2014
Tip
Home Heating Repair - How to Change Your Gas Furnace Igniter
You have run all the tests and they all point to your igniter being bad in your gas furnace.
Your purge blower runs, the power comes on to the igniter, but you get no glow from that little wonder. How can it be changed?
Changing the igniter on your gas furnace really is not all that hard. But it may require a bit of patience and some tools that can get into some very tight quarters. Some furnace manufacturers have design their units to make this job very easy. Some other engineers obviously have never got away from their desk and picked up a screw driver. Hopefully you are lucky enough to have one of the easy ones.
The higher the efficiency of your furnace the harder this job will be. Usually the 90+ furnaces will have the burner compartment sealed. You will have to get the covers off of the burner compartment to get to the igniter. On the 80%er’s the igniter will usually be somewhere on the burner nearest the center of all the burners. Make sure that you remove all power to your furnace before you attempt to remove the igniter. It runs on 110V power and will give you a good jolt if you touch it with power going to it.
Once you have located the igniter, you will need to find the screw or screws that hold the igniter in place. Remove or in some cases just loosen the screw and remove the igniter. Take careful note of the location and position of the old igniter so that you can reinstall the new one in the exact position as the old one. In most cases the wiring will just be a Molex plug that you can just unplug the old igniter and then plug your new igniter back into it.
Carefully position the new igniter into the same location and tighten the screw(s) that hold it in place. Plug the new igniter into the plug and replace the covers on the burner compartment if there is one.
Now you can turn the power back on to your furnace and try for ignition. Hopefully you get the glow and ultimately fire in from the burners. This will give you heat and make everyone happy!
http://www.fixya.com/support/r4015846-furnace_ignitor_care_home_furnace
on Dec 06, 2009 | Heating & Cooling
Having problem with lennox furnace Model ML193DF090P48C-02.Furnace has been working but now and getting worse furnace will kick on 20 seconds or so but nothing.Igniter does not come on.When it finally
Usually when your flame sensor gets dirty, the igniter and burner come on for approx.15 seconds, then shuts down. After 3 tries it will lock the furnace out. You have to shut the power off to the furnace then turn it back on to reset it. You need to turn all the power off to the furnace and remove the flame sensor, clean it with some very fine steel wool and put it back in. Be careful not to handle the Sensor (metal) part with your fingers. Turn the power on and set your thermostat so that it will call for Heat. That should fix, it if not you may need a new flame sensor.
Mar 16, 2014 | Heating & Cooling
Igniter isnt lighting
IF YOU LOST POWER WHEN FURNACE WAS RUNNING IT TRIPPED ROLLOUT SWITCHES AND POSSIBLY THE HIGH LIMIT . IN CENTER OF ROLLOUT SWITCHES IS A LITTLE RED BUTTON THAT YOU RESET . YOU CAN ALSO TRY FINDING HIGH LIMIT WITH POWER SHUT OFF TO FURNACE PULL BOTH WIRES OFF HIGH LIMIT AND USE PAPER CLIP TO JUMP BETWEEN THE TWO WIRES MAKE SURE YOU DONT SHORT OUT AGAINST ANY METAL WHEN YOU TURN BACK ON IF IT WORKS YOU NEED A NEW HIGH LIMIT SWITCH.
Jan 08, 2014 | Coleman 7990-319p Evcon Gas Furnace...
I have a honeywell furnace about 14 years old. The igniter just stopped working. Where do I find a igniter?
Hello, you can purchase a igniter at any heating and cooling store. they usually range between 20= 30 dollars.
Feb 03, 2011 | Honeywell Heating & Cooling
I have a GMNT080 4B furnace this is the third season of use.I have had to replace the igniter 2 years ago.Now on start ups new this season it always has a noticeable explosion.Can be heard thruout the...
The modern boiler or furnace requires the exhaust fan to start first and then the igniter and the gas. As a boiler ages it seems to develop a "late" igniter though this usually results in a whoomph sort of noise that causes no trouble.
If the igniter is so late it causes an explosion it cannot be good and is potentially dangerous and probably damaging to the boiler.. It might help to move the igniter closer to the gas jets but it would be better to entrust this most important and safety sensitive adjustment to a qualified engineer who would be properly insured and who would have to take responsibility for the quality of the repair.
Sep 30, 2017 | Heating & Cooling
Ignition problem with furnace
hi igniter could be in the wrong postion or its not heating up all the way down or its got a crack in it
Jan 22, 2010 | Heating & Cooling
Heating & Cooling Logo
44 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
