Microwave Ovens Logo
T
Tim Austin Posted on Dec 08, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Mute beeps How do I mute beeps? Particularly the ones that beep after the oven shuts off until the door is opened.
Dave
Level 2:
Novelist:
  • Expert 171 Answers
  • Posted on Dec 08, 2014
Dave
Expert
Level 2:
Novelist:
Answers
171
Questions
11
Helped
67361
Points
432
Don't know if it's inherit or not to that model --you could check your manual and check with MFG on line or you could take a hammer to it---good luck
1helpful
2answers
My Miel oven 387b-2 is beeping. Any thoughts as to why?
Please ensure that your over door is properly closed. You can also clean the oven and check whether the beeping goes away. Lastly, you can retrace your actions with the oven and think to the last time that it wasn't beeping (or just before it started) and remember what you had done to the oven. Otherwise, checking the product manual troubleshooting section would be the next step to take.
Thank you.
2answers
Can I disable the beeping/tones on my Kitchenaid microwave?
I'm not familiar with that particular model, but with many of their models (and many other manufacturer models as well), unfortunately the beep cannot be turned off.
2answers
My Avanti microwave keeps beeping nonstop.
Hi.
To mute your microwave, start by checking the control panel. Look closely. The mute function may be labeled as a secondary function of one of the standard buttons. Check these things first:
  • Look for a Sound button. Seriously. It may have been there all along, begging you to press it.
  • Press and hold either 1 or 0. Sometimes manufacturers give these keys hidden, secondary functions.
  • Press and hold the Stop or Cancel button. Like 1 or 0, this key might have a hidden function when held.
Often, pressing and holding 1, 0, Stop or Cancel will either result in turning off the beeping sounds or activating a child lock feature. (Child lock doesn't actually lock the door, but instead locks the control panel so no buttons can be pressed until the lock is removed by holding the button for around three seconds again.)
If none of these work, it's probably best to consult the manual. Even if you don't have a Sound button, there is no Mute function denoted as a secondary function or holding a button doesn't do anything, there is still a chance a mute function exists. It could be a button combination or, like on some microwaves, be buried in a submenu that's not at all obvious how to activate.
If you've tossed the owner's manual to your microwave, check the manufacturer's website. They will often provide a digital version of the manual as a PDF for more recent models. For an older model, you may need to do some digging, but a great start is to just do a Google search for "[microwave brand and model number] manual."
Once you have the PDF version of the manual, press Ctrl + F on Windows or Command + F on Mac to search the PDF for "mute," "sound" or "beep."
Good luck.
My GE stainless steel 1100 watt microwave starts beeping out of the blue and the display panel shuts off and when I open the door it resets itself and then starts to beep when I close the door again.
Try removing the power cord for about a minute, push all the touch pad 'buttons' and then plug it back in. If this doesn't work it sounds like you may have a bad door interlock switch or a bad PCM .. Good luck !
How to change the beep.
Unless that option is mentioned in the owner's manual, no.
Whirlpool X2-20ES
If it's possible to mute or turn down the volume, the owner's manual will cover it.
If not, you may want to take extreme measures, as shown in the video.
1helpful
Our Microwave (JEM25GY/WY) finishes its program, shuts off and beeps; when I open the door to take out the food, the fan starts up again and doesn't stop until I close the door. Serious? Can it be...
Yes! this should be checked right away to make sure the magnetron is not running with the fan when the door is open , it may be a problem with one of the door switches going bad, left unchecked it probably blow the fuse in the microwave killing all power, but it is quite repairable. But please do not use until it has been checked out by a professional for safety reasons.
1helpful
2answers
How to stop it beeping
Is it beeping as the normal end of cycle beeping or Continuous faulty beeping? If you know a bit about electronics, you could locate the beeper and by using a soldering iron, remove it. Or to mute the sound by quite a bit, place a strip of thick insulation tape over the beeper. Otherwise if faulty, you could buy a new board.
JVM1490 IS BEEPING EVERY 4-5 MIN ONE BEEP
The manual states that it will beep once a minute after food cooks until you open the door or press stop. Other than that, it sounds like an error condition. But you might contact the GE Answer Center at 1-800-626-2005 Monday 6 a.m. ET through Saturday midnight ET. The owner's manual is available here: http://www.geappliances.com/service_and_support/literature/
Top Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a Microwave Oven Expert? Answer questions, earn points and help others
