Question about Drive Televison & Video
How do I purchase a hard drive for a DV3 recorder
2 Suggested Answers
SOURCE: problems with a dv3 16000 Nuvico digital recorder
We do not use the dvd recorder that comes with the dvr. We put it on our network and use the software utility to pull off any file footage we need. Though it is in a format does not allow you to play it back on a standard dvr (you must use the file viewer and a pc) it is very easy to get the footage off.
Posted on Aug 08, 2009
Do a recording on my thomson dv3 digital terestrial recorder
The Thomson DV3 is now called Top Up TV. The manuals for the product are here: http://www.topuptv.co.uk/help+centre/downloads
This site also gives the codes to make the Top Up TV box control your TV volume. Hope this helps.
Sep 16, 2014 | Televison & Video
Ferguson HDD DV3, message pops up stating hard drive initialisation failed recording and playback function disabled, I have completed an installation and retune but still getting the same message, can I...
that is the hard drive and it has failed. what you need to do is replace the hard drive. you will need it to be formated in FAT32. so you will need to do this first before installing the new drive. you can buy hard drive readers off e-bay that will read the hard drive on a usb lead. then down download HP USB Disk Storage Format Tool it is a free tool that will format sata drive or idle hard drive to FAT32. you can buy good hard drives also on the choose the size you want up to 1TB as that is the max you can put on this model. hope this help you
Feb 25, 2014 | Televison & Video
Zinwell DV3 i retuned before transmission resumed and now cannot access the menu options or recorded programmes is there a factory reset i just want to retune it now transmission has resumed.
This sounds as if analog tranmisions have now been switch off at your location. Does your set have a digitall tuner fitted if so select dvt from remote go to install menu and do a full scan > If your set does not have a digatil tuner fitted the you will have to connect a digatil box to your tv.
Regars Derrick
May 07, 2012 | Televison & Video
I cannot wake up my HP Pavilion dv3. blue power led flashes on and off and orange connection led too.
The display driver could have crashed, try holding the power button until the lights go off, and the hard drive powers down (you can hear the spinning stop) then try to power it back on. If that doesn't work, do a hard reset, which would be unplugging it from any AC power, and removing the battery and then reconnecting the battery before powering it on. Should this not work, i would say it's safe to assume the backlight is non functioning and a replacement would have to be ordered.
May 05, 2011 | HP Pavilion Dv3-1075us Notebook
Laptop fan has a noisy and pc is shutdown after some time ..so can I replace the fan ? pavilion dv3-2175ee
How to Replace a HP Pavilion dv3 Fan?
1. Follow your laptop owner's manual and assembly guide carefully you can download this from HP web site as you disassemble the laptop. Touch something metal periodically to remove static charge, and work on a large table with a bright light source.
2. Turn off the laptop and unplug it. Remove the main battery, CD/DVD drive and the hard drive. The hard drive is usually located in a slot on one side of the laptop. Remove the screw that holds the cover in place, then pull out the hard drive sled.
3. Turn the laptop over and remove the screws on the bottom that hold the keyboard in place. Flip the laptop over, open it, then lift the keyboard up and out. Unplug the flexible ribbon cable that connects the keyboard to the motherboard.
4. Remove the screws that hold the keyboard bezel and palm rest in place. Carefully pry loose any plastic snaps on the sides, then lift the bezel and palm rest up and out.
5. Unplug the HP Pavilion dv3 Fan Cooling Fan. Remove the screws that hold the heat sink and fan in place, then remove the entire unit from the laptop. Remove any thermal compound residue from the bottom of the heat sink and the CPU.
6. Apply a thin layer of thermal compound on the CPU, then replace the heat sink and fan. Replace the screws, plug the HP Pavilion dv3 Fan back in, then reassemble the laptop.
7. Plug the laptop in and turn it on. After you use it for a few minutes, you should hear the new fan running and feel warm air blowing from the vent on the side of the laptop. A HP Pavilion dv3 Fan does not run continuously, so don't be concerned if the HP Pavilion dv3 Fan shuts off periodically.
Jan 10, 2011 | Computers & Internet
No Instructions with DV3-T TV,
Sep 29, 2009 | Televison & Video
Problems with a dv3 16000 Nuvico digital recorder
did u try using a cd cleaner the dvr only accepts cdr not dvd try using the usb port with a thumb drive to see what happens
Jul 05, 2009 | Nuvico NVDV3-16000N
Tevion DV3 stuck on Channel 9 have replaced remote controller batt.
The Hard drive has failed.
Disconnecting the Hard drive will get the tuner going again, but the hard drive will need replacing if you want to record channels.
Apr 20, 2008 | Televison & Video
Thomson DV3 digital terrestrial recorder
this recorder is constantly getting bad reviews, I think it is unfair because mine does the job, however this problem occured heres what you do.
turn off at the mains and wait 20secs turn back on and hold the standby button untill a light appears.
in sequence up down left right menu ok press the buttons on the front of the box wait 60 seconds and the normal red light will appear turn on box and there you go.
Good Luck further issues visit www.topuptv.com WARNING- doing this procedure will swipe your library but i think it is the only solution
Mar 31, 2008 | Televison & Video
Televison & Video Logo
70 people viewed this question
Top Drive Televison & Video Experts
Vernon Taylor
Are you a Drive Televison and Video Expert? Answer questions, earn points and help others
