Question about Neff Ovens
NEFF B4562 Oven LED display just stopped working during use yesterday. Oven still works but have to guess what programme I am using. any ideas on fixing it without the Neff 100pounds call out fee and that's before parts
    Top Expert:
  • Neff Master
  • 14,161 Answers
Preparing the units - Fig. 1
? The safe operation of this appliance can only be guaranteed if
it has been installed to a professional standard in accordance
with these installation instructions. The installer is liable for
damage incurred as a result of incorrect installation.
? Fitted units must be heat-resistant up to 90 °C, and
neighbouring unit fronts up to 70 °C.
? Cut-out work on the units and worktop should be performed
before fitting the appliances. Remove any shavings or the
function of the electrical components may be impaired.
? Caution during installation. Parts that are accessible during
installation may have sharp edges. Wear protective gloves to
prevent cuts
? The power socket for the appliance must either be located in
the hatched area B or else away from the installation space.
? A gap of 5 mm is required between the appliance and
surrounding unit fronts.
? Secure freestanding units to the wall using a standard bracket
C.
Appliance under the worktop - Fig. 1
There must be a ventilation cut-out made in the intermediate
floor of the surround unit.
Secure the worktop to the fitted units.
If a fitted oven is to be built in under a hob, pay attention to the
hob installation instructions.
Appliance in a tall unit - Fig. 2
The appliance may also be installed in a tall unit.
There must be a gap between the intermediate floors and the
mounting wall of approx. 20 mm in order to provide ventilation
to the oven.
Only fit the appliance at a height where removing baking trays
does not present a problem.
Corner installation ­ Fig. 3
To ensure that the appliance door can be opened in the case of
corner installation, take account of dimension D. Dimension E is
dependent on the thickness of the unit front under the handle.
Connecting the appliance to the power supply
Only allow a licenced professional to connect the appliance.
National regulations apply as well as those of the local electricity
supplier.
The appliance must be disconnected from the power supply for
all installation work.
The appliance corresponds to protection class I and may only
be operated with a protective earth connection.
Power cord: Type H05 VV­F or higher rated. The yellow/green
wire for the PE connection must be 10 mm longer than the other
wires on the appliance side.
During installation, an all-pole isolating switch with a contact gap
of at least 3 mm must be present, or the appliance must be
connected via a three-pin earthed plug. This must be accessible
after installation.
Contact protection must be ensured by the installation.
Identify the phase and neutral conductors in the socket.
Incorrect connection may cause damage to the appliance.
Only connect as per the connection diagram. See the rating
plate for the voltage.
Position the appliance in front of the units in readiness for
connection. The connecting cable must be sufficiently long.
Securing the appliance ­ Fig. 4
? Fully insert the appliance and centre it.
? Screw the appliance into place.
? The gap between the worktop and the appliance must not be
closed by additional battens.
Removal
Disconnect the appliance from the power supply. Undo the
securing screws. Raise the appliance slightly and pull it out
completely
the only contact info that I found is the info below:
http://www.neff.co.uk/contact-us.html
Posted on Dec 08, 2014
Testimonial: "Not an installation issue - has been installed for more than 4 years"
  • David Payne
    David Payne Dec 09, 2014
    that is why I put the contact link near the bottom as well. tech support for the unit.
Neff H5972N0GB combination oven. Its a new item that was panel damaged at the back. On plugging it in, the panel on the right does not light up to show the settings - normally red back light. With a...
most likely the backlight bulb is broken. It depends on the type of display if it is a easy fix or not. All models after 2010 have LED backlight. But who knows maybe there is only a connector dislodged. I who say disconnect the mains and open up the frontpanel.
Feb 01, 2015 | Neff Ovens
I have a Candy TCP21x oven and the bottom fan oven has stopped working as well as the digital display, the top oven still works. Any ideas?
problem with the board.. is it under warranty? Have tech get replacement if it is. May have to pay labor.
Nov 19, 2014 | Candy Ovens
Neff oven element glows white
It sounds like the wrong replacement element for the power it is getting. If you are using a 220Volt stove, the element MUST be for that voltage and NOT for 110 Volts.
Jan 23, 2013 | Neff U1721 Double circotherm Electric Oven
Neff B4562
Engineer is a solution.
The other solution is;
Switch 3 times between rotisserie and pyrolysis or bread baking setting and pyrolysis.
As acknowledgement the displays are actuated.
At each change of operating modes switch immediately stops the current test step and the next step of the test enabled. The oven light should according to the mode ON or OFF; that is, at pyrolysis OFF otherwise ON.
Jul 01, 2012 | Ovens
My Neff U1721 bottom oven has just stopped working - the fan still works, although is a bit noisy - what could be the problem/
Sound like the element has burnt out but if your fan is also noisy it is probley running slow which may have caused the element to overheat and burn out so it would be a good idea to replace the element and the fan motor
Regards
Ian
Apr 20, 2011 | Neff U1721 Double circotherm Electric Oven
We had a power cut yesterday and today my neff electric oven just shut down completely. The clock has also stopped working.
if you have power to oven but the clock is not working it sounds like overvoltage has damaged the clock if clock will reset and you can set the time oven will work.
Jun 03, 2010 | Neff B1421 Electric Single Oven
NEFF U1271 Oven overheating
Hi it could well be the thermosat has stopped working
Jan 24, 2010 | Neff U1721 Double circotherm Electric Oven
Neff B4562 Pyrolytic Cleaning Not Working
You need to remove the rack side supports too. Its not clear in the book as it just says shelves and racks but everything needs to come out the oven.
May 01, 2009 | Neff B1476 Pyrolytic Stainless Steel...
LED display stopped working
Hi!!! your clock or control board has malfuction.You can get access from the back of the unit pull the unit out and look at the back remove the screws..Your control board clock board went bad..Good luck..
Jan 04, 2009 | Belling XOU252 Electric Single Oven
Neff single oven
fan heating heating element gone replace it ;Ire close bye
Sep 04, 2007 | Neff U1721 Double circotherm Electric Oven
Ovens Logo
106 people viewed this question
Top Neff Ovens Experts
ashburton
Samyfam
Samyfam
xxxxxx xxx
Are you a Neff Oven Expert? Answer questions, earn points and help others
