Question about JVC Televison & Video
My JVC DD8 starts, no sound, and the unit does not switch to an other source.
The powersupply is OK. I think a malfunction on the control board.
    Top Expert:
  • JVC Master
  • 73,647 Answers
If the standby light is ON, and the set does not start up. the main board to it is faulty. anyway; try a reset to this set, before replacing the main board. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Posted on Dec 08, 2014
Testimonial: "Hello, it is not a television it's a multimedia system. Main module and 5 speakers. I've seen on the schematics of the mainmodule that there is a standard reset system. But the drawing is a bit different from what I have."
Dryer will not start the led light are off
Hi maike, this is AP!
Often when a product does not start I would recommend starting with the power source such as the breaker feeding power to the dryer. There are two house fuses that supply voltage to the dryer circuit in your fuse box. Check and replace the fuse in the fuse box if necessary. If the house has circuit breakers, there may be two breakers with switches that supply voltage to the dryer and if one is tripped the dryer may turn but will not heat.
For your particular Frigidaire dryer, model FARE1011MW, if the power source is not the culprit the control board could be defective. Another source of the malfunction could be the door switch, however I would think you would have power to the control panel if that was the case. If your appliance is still in warranty, you may want to check with the manufacturer to determine any warranty coverage, or if there are any professionals in your area who will not only be able to ensure this is the appropriate fix, but may actually save you some cost if is something simpler to repair. I hope this information helps to some degree.
Thanks,
Apr 02, 2014 | Frigidaire FARE1011MW Affinity High...
Unit starts automatically when door is closed
please review this and fix it. God bless you
  1. Interlock switchIf your microwave is turning itself on, the first thing to check is the interlock switch. This is usually the first thing to malfunction that could cause this issue. If the interlock switch is bad then it will need to be replaced.
  2. Main control boardIf your microwave is turning itself on and the interlock switch is still working, the probable cause is the main control board. If the control board is defective it will need to be replaced.
Nov 18, 2013 | GE PSA2200RBB Microwave Oven
Control panel looks ok but dryer wont start
Sounds like an electronic problem on the timer circuit board.
Aug 11, 2009 | Siemens WT79020EU Electric Dryer
Radio wiring
The JVC unit has a RED wire, it sounds like this is connected to a power source that is ON with ignition...this is OK. Your unit also has a YELLOW wire, and it sounds like this also connected to a power source that is ON with ignition.....NOT OK....this wire needs to be connected to a power source that is On all the time.
Mar 12, 2009 | Car Audio & Video
Looking for replacement cable for jvc home theatre.. the only thing i have is the cable with me now awm e225738 style 2464 vw -1sc
Ask JVC for part number QAM0381-002 (this is normaly for DD8 or DD3 models. It is 5 m. long). JVC France Customer Service
Nov 24, 2008 | JVC Audio Players & Recorders
JVC KD-G340 Power Problem
I had this same problem...you probably have the wires wrong. Double check your connections for the red and yellow wires from the headunit. Make sure that your red wire is going to a 12 volt source that only switches on with the ignition.
Jul 04, 2008 | Car Audio & Video
Epson ELP-3300 powers up bulb light is green but...
Ah ok , so it doesn't start up at all.
Is there any power at all on the unit , like LED's lighting up ?
If there is then it would be your Ballast ( lamp's powersupply ) that need replacement.
If there isn't - then you should check on the Powersupply Board ( where your AC inlet sits in ) if the fuse is blown and if not , then you will have to replace the Powersupply Board.
Apr 22, 2008 | Office Equipment & Supplies
Okidata 395ML
Hi ,
make sure the cables to the main logic board are plugged into the correct places???
Dezzi
Jan 09, 2008 | OKI MICROLINE ML-395 Matrix Printer
Televison & Video Logo
Top JVC Televison & Video Experts
Jaime Hernandez
easy alberta
easy alberta
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
