Question about Dyson DC33 Multi-Floor Upright Bagless Vacuum Cleaner
Brush is not rotating
Removed 3 screws and tried to replace belt
    Master:
  • Dyson Master
  • 851 Answers
Hi it's Jim from Crucial Vacuum,
Is the belt on properly? I know you had mentioned trying to replace the belt, but if it's not on properly or is loose then this would affect the rotation of the brush roll.
A general rule would be that you're going to want to replace your belt about every 6 months. Make sure there's tension on the belt.
Are there any noticeable debris or blockages on the roller itself? Remove these, usually with a razor or pair of scissors, and manually rotate the brush roll to uncover any other further clogs.
You can purchase your replacement parts for your Dyson DC33 direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/dyson-dc07-dc14-dc04-dc33-roller-belt-service-kit.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
Posted on Dec 08, 2014
  • Official Brand Answer
  • 2,572 Answers
Hi Barbara, it's Jack at Dyson.
DC33's brush bar will only rotate when the vacuum cleaner is turned on and reclined into the normal vacuuming position, and the brush control is set to 'Carpets':
If the vacuum cleaner is standing upright, or set to 'hard floors', the brush bar will not rotate.
If you're confident the brush control is set correctly, but the brush bar won't rotate when the machine is turned on and reclined, please contact our experts directly so we can talk you through some further troubleshooting checks. If a repair is needed, we can also confirm if this is covered under your Dyson warranty.
You can reach us by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
How do i change the belt on the dirt devil vacume cleaner
Hi there! Below are steps to replacing the belt on your vacuum. I have also included a link to the instruction manual which has illustrations if needed.
1. Lay cleaner flat and flip cleaner to expose nozzle base. Base should lay flat and face up. To remove nozzle guard, use Phillips screwdriver to remove the four (4) screws. Arrows show location of screws.
2. Lift nozzle guard off.
3. Slide belt off motor shaft.
4. Lift and remove brushroll. Dispose of old belt.
5. Place new belt in area of brushroll without bristles.
6. Slide belt onto motorshaft.
7. With new belt in place, pull and slide brushroll into nozzle making sure that the brushroll end caps are in the correct orientation. Rotate brushroll manually to make sure belt is properly aligned.
8. Reattach nozzle guard.
9. Secure by aligning the three (3) tabs in the base slots. Be sure to replace all four (4) screws.
http://bit.ly/1s8GQSX
Hope this helps!
Jul 27, 2014 | Dirt Devil Featherlite Bagless Vacuum...
How do you replace the belt on xl2200 upright oreck vacuum cleanrer
Ok with the front of the vacuum facing you look on the left had side of the power head then follow these steps.
1.Remove the door by removing
the hold down screw located on
side of power head.
2.Slide the door forward by
prying open with a screwdriver
or coin.
3.Remove the belt from the brush
roll pulley and the motor drive
shaft.
4.Loop the new belt over the
motor drive shaft. Place the
opposite end of the belt on the
brush roll pulley.
5.Rotate the brush roll three (3)
complete revolutions to ensure
that no part of the belt is
overhanging the end of the
motor drive shaft.
6.Replace the door by sliding it
into the groove at the bottom of
the housing. Replace the hold
down screw.
Jun 22, 2011 | Vacuums
Belt is broken. Not sure how to replace
1. Get a long screw driver (probably phillips head) a strip of tape.
2. Look around underneath your vac for screws... look carefully because sometimes they are sneaky and hidden in weird areas like under the wheels, etc.
3. Take screws out stick them in order on tape turned upwards. (remember how you took them out.)
4. Gently remove the bottom cover.
5. Clean and remove debris, hair, dust bunnies, rocks... whatever.
6. Determine where the belt goes, disengage the beater bar on that side (may need to unscrew something) Belt on beater bar gears. Other end of belt on motor end... then stretch belt with beater bar until it fits back in it's place and replace any screws, etc.
7. Make sure the belt is seated properly.
8. replace cover, screws... test.**
** sometimes belts require that you put a twist in them so it can transition from the motor's direction to the beater bar's direction... if you twist the wrong way... the beater bar will spit dirt out the front of the vac.. (it's bulldozing it) In that case remove cover and twist the belt the other way.
Good luck.
Mar 12, 2011 | Vacuums
How do you change the belt of the m5088520?
Hi There,
Here's step by step instructions for you on how to replace the belt on your Dirt Devil M088520 Featherlite.
Flip cleaner to expose nozzle base. Base should lay flat and face up. To remove nozzle guard, use Phillips
screwdriver to remove the two screws. Arrows (Diagram 1) show location of screws.
Lift nozzle guard off. Slide belt off motor shaft
(Diagram 2).
Lift and remove brushroll (Diagram 3). Dispose of old belt.
TO REPLACE BELT
1. Place belt on motor shaft, then slip brushroll through belt. Place belt in area of brushroll without bristles (Diagram 4).
2. With belt in place, pull and slide brushroll into nozzle (Diagram 3) making sure that the brushroll end caps are in the correct
orientation (Diagram 3a inset)
IMPORTANT: Rotate brushroll manually to make sure belt is not twisted.
3. Reattach nozzle guard. Secure by locating the 3 tabs in the base slots and replace the screws (Diagram 1).
I really hope that this was helpful to you. If you'd like to download the manual for your vacuum cleaner where I got this information, please see the link below where you may download. If you found this helpful, please be so kind and rate my repair helpful, or leave feedback for me. This is really appreciated by Fixya users.
Thanks so much.
Dirt Devil M088520 Featherlite Vacuum Cleaner
Owners Manual
Chris Jones
GoVacuum.com
May 07, 2010 | Dirt Devil M088520 Featherlite Bagged...
Hoover empower belt need replace
To gain access to the belt: remove 2 screws at the top rear cover, next remove 2 screws at the bottom front cover. This will allow the cover to be removed. Then remove 3 or 4 screws that hold the roller in place (from the top). you will be able to see the belt and replace it.
Apr 18, 2010 | Vacuums
The bottom of the hoover wont work. its not picking anything up and not spinning round.
You most likely will need to replace the belt on this model. There are 4 screws in the corners of the bottom power nozzle. DO NOT remove the 3 that are grouped together (these are the motor screws). once the top is removed then remove 3 roller cover screws. replce belt and reassemble in reverse order.
Oct 28, 2009 | Hoover S3639 WindTunnel Bagged Canister...
Fantom fury vacuum
HOW DO I CHANGE THE BELT ON THE FANTOM® THUNDER® AND FURY®? a.gif fantombeltchange1.jpg
  1. Unplug the machine.
  2. From the front of the machine, remove the collection bin.
  3. Facing the back of your vacuum, remove each of the Philips head screws located above each of the rear wheels. (Figure 1)
  4. To remove the base cover, place your thumbs in the two screw holes in the back of the machine. Push forward and up on the screw holes to disengage the 3 cover locking tabs. Put the cover off to one side, and go to the front of the machine. (Figure 2)
  5. Check the drive arm for any black streaks which indicate residual rubber from the last belt. The drive arm is located on the right side of the motor. The easiest way to remove any residual rubber is with some nail polish remover on a rag or with steel wool.
  6. To attach a new belt, remove the brush from the base of the machine by pulling up straight up with two hands.
  7. Take the new belt and hook it over the steel drive arm. Pull back on the belt slightly, to create some tension.
  8. Put the brush inside the belt loop so that the track for the belt is aligned with the belt itself.
  9. Replace the brush by aligning the metal end so the points face downward. (Figure 3)
  10. Rotate the brush by hand to check that the belt is running freely and easily in its designated space between the bristle.
  11. Replace the cover by placing the nose in first. Once in place fasten with the two cover screws and then replace the collection bin.
May 13, 2008 | Fantom Vacums Lighting Canister Vacuum
Eureka vacuum belt how do i replace on model #4688
How To Replace Brush Roll Belt
NOTE: Turn off the switch and unplug the electrical cord
before replacing belt. Belt pulleys can become
hot during normal use. To prevent injury, avoid
touching the motor shaft when checking the belt.
1. Lower handle to floor to change belt.
2. Loosen, but do not remove, two screws to release hood.
Lift hood to remove.
3. Lift left end of brush roll.
4. Remove and discard belt.
5. Place new belt around motor shaft.
6. Place belt around brush roll pulley.
7. Align left end cap with base. Push end cap
securely into place.
8. Pull right side of brush roll to stretch belt.
Secure right end cap into base.
9. Rotate brush roll to seat belt.
10. Replace the hood. Make sure hood front is
behind furniture guard. Hood should seat
onto self-locating screw tabs.
11. Tighten screws.
You can goto this website enter in the model number 4688 and you can see detailed pictures of how to change the belt as well as print off a new user manual.
http://www.eureka.com/servlet/FindOwnersGuide
Regards
Feb 14, 2008 | Vacuums
Belt
Hi.
If its not all floors machine just turn the three plastic screws under the machine to unlock .
lift off sole plate remove brush roller fit new belt over brush roller then stretch belt over motor drive shaft.
Replace sole plate turn 3 screws to lock position & thats it.
If your machine has a clutch unit & is all floors type this is more harder to do & will need a lot of explaining so try this site for Dyson Service Manuals.
http://dysonmanuals.inc.io/
Chris.
Dec 02, 2007 | Dyson DC14 Animal Bagless Upright Cyclonic...
Kirby G3 - jump - skip problem
Hi, Try logging your post on the Kirby Trading Forum at Kirbydirect.co.uk - you'll be sure to get a reply. John
Jun 12, 2007 | Kirby Generation 3 Bagged Upright Vacuum
Dyson DC33 Multi-Floor Upright Bagless Vacuum Cleaner Logo
368 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
