Question about Generac Electrical Supplies
Gas is not getting to cylinder
Cleaned carbururetor-vacuum line ok-changed plug
  • Eugene Rounds Dec 08, 2014
    Hi walter gobert, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    How did you clean the carburetor if was just by spraying carb cleaner then you haven't got it clean yet.
  • 242 Answers
SOURCE: can't start snowblower--- good gas flow to
sounds like head gasket has blown
Posted on Dec 23, 2009
  • 326 Answers
SOURCE: engine misses on#5 cylinder i have already changed
not uncommon to have bad injector plugs can fire all day but if #5 injector doesnt give it anything to fire you will have a miss but first i can,t stress the importance of using die electric grease on those coil packs and booties i have found alot of problematic misses to end up being repaired by a little die electric grease
Posted on Jul 13, 2010
SOURCE: My fifth ave hessitates and bucks on acceleration
How is the EGR Valve?
What is causing the issue, is the higher vacuum
signal when you get on the gas.
Use that and theory to figure it out.
Posted on Nov 25, 2010
  • 437 Answers
SOURCE: im think if doing a
easy way just add it to the fuel tank sme results much easier
Posted on Feb 10, 2011
  • 440 Answers
SOURCE: I have a 1985 Yamaha maxim that hasn't been ran
Spray starter into the carb intake with no choke, if she runs for a few seconds then you know its fuel starvation
clean jets & airways & blow through with compressed air
Posted on Jan 07, 2012
2004 chevy cavalier wont start.
You must scan the system with a code reader.
Jul 17, 2013 | 2004 Chevrolet Cavalier
Low rpm at idel
Sounds like there is a vacuum leak. I's there a check engine light on? If so is there any lean codes?
Jul 13, 2013 | 2003 Ford Taurus
1993 Ducati M900. On cold start up low power. Feels like dropped cylinder. After a few minutes returns to normal. My thoughts, one of the coils. Spark plugs appear ok.
if the plugs look ok and don't indicate a fuel mixture problem, it could be from a weak spark. You can check the resitance on your coil and plug wires with an ohm meter to see if they are within factory specs. Also, check for a possible vacuum leak around the carb & cylinder head on the cylinder that is missfiring. You can do this with some carb cleaner, spray it around the carb mount and vacuum lines---if the RPM's change it sucked some in. Hope this helps.
Jul 12, 2011 | 1993 Ducati Monster 900
Just will not start
You have most likely done this but lets go back to the basics.
Do you have spark at the plug?
Check to see if the plug is fouled - pull the plug connect to the plug wire- ground the metal part of the plug to the metal body of the engine - as you turn the engine over it should fire cleanly from the center to the electrode, if it fires off to the side or has an orange colored spark it is fouled - replace it.
Once we have spark check for gas is it getting to the carb?
90+ % of all small engines not running are due to the fuel line or in tank screen being plugged with garbage. Remove the fuel line from the carb, point it down and using a small container to catch the gas it should flow freely.
If you have good gas flow reconnect the fuel line to the carb and put about 1 CC of gas in the plug hole reinstall the plug and fire it - almost all small engines use a bit of vacuum to pull the fuel from the carb into the cylinder, jump starting them with a very small amount of gas directly in to the cylinder can help them get going.
A VERY SMALL AMOUNT OF GAS AND CLEAN UP ANY SPILLS BEFORE YOU TRY TO START !!
Burning down the house will upset the other half
Mar 08, 2010 | Briggs & Stratton Garden
Craftsman gas leaf blower will not start. Spark and gas lines ok. Not getting gas to plug even after prime and several pulls. How do I find gas supply problem. Diaphram in carb looks ok .It actually...
Basics to check:
1) Spark plug - brown or dark brown - OK
a) is it carbon or fuel fouled
b) is there spark
2) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
3) Check cylinder compression
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Nov 25, 2009 | Craftsman Garden
My weedeater leaf blower never gets up to its' old speed. Runs about 1/2 the power. Tried a new spark plug and air filter. New gas didn't help.
Basics to check:
- aluminum or silver - piston/cylinder scored
b) is there spark
2) Compression - 125 to 150 psi
3) Muffler remove for inspection
1) spark plug
Remove Carburetor
5) replace gaskets/diaphragms
b) use a spray carb cleaner to clean jets, holes, and body of carb
Nov 11, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
5.3 L Missing and Rough Idle Intermittently
i have a 2001 chevy z-71 5.3L. I keep getting a random/multiple misfire code for cylinder 1 . I have replaced plugs, wires, coil pack(only on #1 cylinder)., and fuel pump. I still keep getting the cylinder 1 misfire code. I put truck on a scanner and watched the cylinders. # 1 misfires at idle but quickly stops misfiring at around 1000 rpms. you can here the engine miss at idle but truck runs great on road . anyone else ever had this problem?
May 05, 2009 | 1999 Chevrolet Silverado 1500
Electrical Supplies Logo
15 people viewed this question
Top Generac Electrical Supplies Experts
 Kenneth
Kenneth
Ottoniel
JOHN LAPIER
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
