Question about Jenn-Air Kitchen Ranges
How do I test whether timer #12200028 is good
Fridgefreezer running but not cooling/freezing
This can be caused by a defective defrost timer. As to whether this is your issue I would need to plug one in, there is no way to really test them except by symptoms, such as the one you have.
Jul 15, 2016 | Refrigerators
Freezer was not working this morning and the air does not seem to be as cold as normal that is coming out of vents from inside. Wasn't sure if door was left cracked open, but it hasn't seemed to...
Test Defrost Timer # 9 in this download http://www.appliancepartspros.com/partsearch/frame_diagram.aspx?diagram_id=28327585&pkw_=basket&model_id=5167318&NewWindow=1
The defrost timer is usually found in the temperature control console.
To test whether the defrost timer is simply failing to advance, locate the advance screw and turn it clockwise until you hear it click. This advances it to the next mode.The freezer fan motor should have stopped now in defrost mode. Simply wait about 35 minutes and check whether it has moved out of defrost mode and has resumed cooling (listen for the compressor and freezer fan motor). If it does not advance, the timer motor is probably bad and the entire timer needs to be replaced. If it advances as it should, then you can follow the steps below to test the switch electrically.
The timer is usually held in place with one or more screws. Remove the screws and gently pull the timer out far enough to disconnect the wiring connector. The connector can be removed by firmly pulling and rocking it left and right. It is not necessary to note the position of the wires because the connector plug is keyed so that it can be replaced in only one way.
Test the timer for continuity using a multimeter. Set the multimeter to the ohms setting X1. The timer has four terminals. Locate the common terminal, it should be labeled "3" or "C". If the terminals are not labeled, determine which terminal coincides with the white wire in the connector plug.
Once you have located the common terminal, touch one probe to it. Touch the other probe to each of the three remaining terminals. The multimeter should display a reading of zero or near to zero ohms (which indicates continuity) for one pair of the terminals and possibly two pairs. The third pair of terminals should show no continuity (infinity).
Sep 18, 2011 | Amana ACD2232HR Side by Side Refrigerator
Top of Freezer and Fridge not freezing/cold. The bottom drawer froze the fruit however. There is frost on the back wall of the freezer, and the bottom of freezer is still freezing. Could it be freezer...
Try Checking the Defrost Timer
The defrost timer is usually found behind the front grill "toe kick" of the refrigerator. It may also be found behind a cover plate inside the refrigerator or freezer, in the temperature control console, or behind the refrigerator near the compressor.
To test whether the defrost timer is simply failing to advance, locate the advance screw and turn it clockwise until you hear it click. This advances it to the next mode. If it was cooling before, it is now in defrost mode. Simply wait about 35 minutes and check whether it has left defrost mode and has resumed cooling (listen for the compressor). If it does not advance, the timer motor is probably bad and the entire timer needs to be replaced. If it advances as it should, then you can follow the steps below to test the switch electrically.
The timer is usually held in place with one or more screws. Remove the screws and gently pull the timer out far enough to disconnect the wiring connector. The connector can be removed by firmly pulling and rocking it left and right. It is not necessary to note the position of the wires because the connector plug is keyed so that it can be replaced in only one way.bobicehouse_26.jpg
Jul 12, 2011 | Refrigerators
Defrost system not working
A mechanical defrost timer controls the defrost cycle of the freezer. In older models, the timer runs continuously and roughly every six hours, cuts power to the cooling system and sends power to the defrost heater. In newer models the timer advances only while the compressor or defrost cycle is running - an improvement for efficiency. As the timer continues to advance, power to the heating element is cut and power is restored to the cooling system. If the timer does not advance, the appliance will be stuck either in defrost or refrigerate mode, resulting in, respectively, no cooling or frost build-up.
The defrost timer is usually found behind the front grill "toe kick" of the refrigerator. It may also be found behind a cover plate inside the refrigerator or freezer, in the temperature control console, or behind the refrigerator near the compressor. To test whether the defrost timer is simply failing to advance, locate the advance screw and turn it clockwise until you hear it click. This advances it to the next mode. If it was cooling before, it is now in defrost mode. Simply wait about 35 minutes and check whether it has left defrost mode and has resumed cooling (listen for the compressor). If it does not advance, the timer motor is probably bad and the entire timer needs to be replaced. If it advances as it should, then you can follow the steps below to test the switch electrically.
Take care.
Aug 25, 2010 | GE Refrigerators
Machine gets to warm in the box upto 60+ in the fresh food and 10+ in freezer. Does this at least once a week. Has a new control board in the back.
It might not be defrosting! The ice is block air flow to the fresh food section.
Oct 10, 2009 | GE PDS20SCPRSS Bottom Freezer Refrigerator
GE Profile PSC25SGSA Side by side refrigerator No defrost cycle for coils in bottom of fridge side. Completely ices over every 5-7 days and a hairdryer plays the role of defroster. No problem with...
Oct 10, 2009 | GE PSC25PSS Side by Side Refrigerator
Water is leaking from freezer into refridgerator plus there is alot of frost in freezer
Your drain is probably blocked from ice because it isn't defrosting. To make sure the heater hasn't failed try doing the following.
Oct 09, 2009 | Refrigerators
Trying to replace timer 8299771. Can't find my
On the new timer , you have 2 wires comming of the timer motor . The blue wire should go to one of these terminals on the timer itself . The place where there is ONLY a timer motor wire going to , is where it should go .
Sep 04, 2009 | Dryers
Defrost timer
Dear customer,
       The defrost timer is usually found behind the front grill of the freezer. It may also be found behind a cover plate inside the freezer, in the temperature control console, or behind the freezer near the compressor.
Plz rate this solution.. thank you..
Apr 08, 2009 | Jenn-Air JSD2789GES Side by Side...
Warm fridge, cold(er) reeezer
we ll see how u need to check the defrost timer....
Before testing the defrost timer, unplug the freezer to avoid an electrical shock hazard.
A mechanical defrost timer controls the defrost cycle of the appliance. In older models, the timer runs continuously and roughly every six hours, shuts off power to the cooling system and sends power to the defrost heater. In newer models the timer advances only when the compressor or defrost cycle is running - an improvement for efficiency. As the timer advances, power to the heating element shuts off and power is restored to the cooling system. If the timer does not advance, the appliance will be stuck either in defrost or refrigerate mode, resulting in, respectively, no cooling or frost build-up.
Test the timer for continuity using a multitester. Set the multitester to the ohms setting X1. The timer has four terminals. Locate the common terminal, it should be labeled "3" or "C". If the terminals are not labeled, determine which terminal coincides with the common wire in the connector plug; it is usually the white wire.
Once you have located the common terminal, touch one probe to it. Touch the other probe to each of the three remaining terminals. The multitester should display a reading of zero or near to zero ohms (which indicates continuity) for one pair of the terminals and possibly two pairs. The third pair of terminals should show no continuity (infinity).
Locate the timer switch and turn it clockwise until you hear it click. Now retest the timer as you did above. One pair of terminals should indicate continuity (possibly two pairs). At least one pair should give a reading of infinity. Note however, one of the pairs that showed continuity in the first test should now read infinity and one pair that read infinity should now show continuity. If the defrost timer does not pass these tests, it is likely that it should be replaced.
Aug 20, 2008 | Whirlpool GB9SHDXPS Stainless Steel Bottom...
Kitchen Ranges Logo
65 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
