Question about Winter Sports
My 2007 ski doo summit ptek 800r adrenaline has throttle dead spot when u first whick on the throttle it all most dies but IF u feather the throttle it will rev right out untill u let off, then u half to feather or again, if u just hammer it it bogs untill u let off and feather it? New stator clutch new dess.
  • 460 Answers
Carbs need to be cleaned and boots between carbs and block might have rips in it. Sucking to much air. Also check reed valves for ware
Posted on Jan 10, 2015
5 Suggested Answers
  • 3567 Answers
SOURCE: bike bogs for second then revs when throttling
Pull the slide out of the carb then remove the jet needle and move the clip one notch lower on the needle.
Posted on Apr 11, 2009
cbgarner
  • 138 Answers
SOURCE: Suzuki 2009 DR-Z 250 won't rev past half throttle
I would have it checked out. I know that it has limitors on it but it shouldn't be half throttle. It should rev as soon as you start twisting the trottle.
Posted on May 21, 2009
  • 99 Answers
SOURCE: yz 150f bogs when you give full throttle all at once
ok, assuming you replaced the carb header and stator with aftermarket parts, then I would say you definitely have a jetting issue. that flat spot is coming from your engine starving for fuel. its taking the gas too long to get from the carb to the engine. you would fix this by adjusting the idle mixture on the carb. the first thing I would do is look for the fuel mixture screw on the carb. im not familiar with your specific model. but the screw is usually found facing down on the bottom of the carb, directly in front of the bowl. when you find it, turn it counter clockwise about 1/2 turn at a time until that flat spot fades away. if that doesnt work, then you will need to up the size of the pilot jet inside the carb. maybe 1 or 2 sizes would be enough. if you replaced the carb with a bigger carb, then you may not be able to fix this problem. in my experience, larger carbs will increase power, but usually throttle response, especially low end, suffers considerably. the reason for this is lower intake velocity and vacuum. basically, with a bigger carb it takes a second longer for the fuel to be drawn from the carb and properly atomize with the air. hope this helps.if I overlooked anything let me know! some more info on the engine/modifications and carb/jet sizes would help too. good luck.
Posted on Sep 06, 2009
  • 17 Answers
SOURCE: my bike is bogging at low revs when trying to
sounds like you need to adjust you carb' its running rich it sounds like.
Posted on Sep 19, 2010
Im installing a new motor in a 2011 ski-doo summit 800r powertek, and have 3 plugs coming out of the stator only could find where two go is the 3rd for nothing or am i missing something
You are missing something. It's been a year or so since I've done this but all three of those plug back into the main stator connector that is on the right side of the machine behind the exhaust if it was installed. I thought they were all the same color though. Reply here If you haven't solved this and I'll take some pics to help you out.
Feb 13, 2015 | Ski-Doo 2011 Summit Everest 154 800R Power...
2bpsbd7b37vooo163
You have provided the VIN Number, for a 2007 Ski Doo. What is your Question?
Jul 19, 2014 | Winter Sports
Chain adjustment
The Chain is adjusted by way of an Internal Chain Tensioner located inside the Chain Case. Be careful it is full of oil....
Jan 04, 2014 | Ski-Doo 2009 Summit X 154 800R Power T.E.K
2009 SUMMIT SKI DOO WILL NOT START
Ski Doo's are known to have BAD KILL SWITCHES
DPM going bad
Dec 24, 2013 | Ski-Doo 2009 Summit Everest 146 800R Power...
04 summit adrenaline dies every time i put it in reverse what could cause this to happen
This happens with my 800 HO, I replaced the Plugs and Viola... Problem is now gone
Mar 23, 2013 | Ski-Doo 2004 Summit Adrenaline 600 H.O
My 04 skidoo summit 600 HO dies every time i try to put it in reverse what would cause this to happen
my 800 Summit does this also, it is my sign that I need to change my Plugs. and EVERY TIME, it works...
I have a 2009 Ski doo Summit, the motor is a Rotax 800R powertek. i had fouled a set of plugs on it and was changing them out when i notice that the on spark plug cap broke off way up inside the rubber, (...
I don't know specifically if you can twist the wire on or not. I would just go to the dealer and buy a new one. Your dealer might be able to tell you for sure if it will twist on or not.
Dec 12, 2010 | Honda CR 250 R Motorcycles
Winter Sports Logo
347 people viewed this question
Top Winter Sports Experts
Arnie Burke
Arnie Burke
Todd Arndt
Todd Arndt
Are you a Winter Sport Expert? Answer questions, earn points and help others
