Question about Refrigerators
Frig will cool but not stay cold
Adjust temperature and unplug and replug in frig.
    Novelist:
  • 187 Answers
Check the condensing coil under the back side of the refrigerator. If the condensing coil gets dirty, the refrigerant does not condense at the proper temperature and carries unshed heat with it back to the evaporator. This excess heat reduces the ability of the refrigerant to cool because it did not lose the correct amount in the condenser. The condensing coil and it associated fan is located behind the cardboard cover on back side of the refrigerator.
The condensing coil should be cleaned at least yearly. People with pets such as shedding cats and dogs may have to clean it more often.
On your temperature control, a setting of 5 for both freezer and fresh foods section is the normal value.
Another thing to check is the air flow blockage in the freezer for the evaporator and product stored there. If the fan inside of the evaporator can not circulate air then improper cooling will occur. Make sure there is space between shelves and between product so air can circulate.
Hope this helps
Posted on Dec 14, 2014
fridgetech
  • 473 Answers
SOURCE: Samsung side-by-side refrig is not staying cold
Look for signs of frost build up on back freezer panel. If there is build up then it has a defrost problem. I haven't had much experience with samsung but I beleive it has a fuse in the defrost circuit on the evaporator and that may be the defrost problem.
Posted on Oct 06, 2007
  • 3 Answers
SOURCE: Active Smart Temperature Control Panel - Red Light
it is possible that it is the cooling regulator that is having a fault. The F&P customer service centre will / should be able to help diagnose this over the phone and give you a much better idea what u should do.
Posted on Jan 08, 2008
  • 117 Answers
SOURCE: I have a Kenmore coldspot side by side- not cooling properly
Setting it to 5 is what the manufacturer recommends. If you set it to 1 and the frig is still not cold, then you probably have a faulty cold control (thermostat)
http://tclaundryrepair.com/home
Posted on Feb 19, 2009
praky16
  • 744 Answers
SOURCE: Frig stopped cooling, unplugged & replugging worked - now what?
hi try out the following settings....
Check your temperature setting.
- Check if no ice present in the evaporator, try the defrosting
- Check vents if air is present if no then check your blower if running or icing evaporator.
- Check your vents if not obstructed with stocks, or the unit is not overloaded with stocks.
- Check if compressor is running continues, if not then you need a qualified technician.
i think after checking this it will work out for u.!!!
thank u
rate me!!
Posted on Apr 10, 2009
EllaWatson25
  • 725 Answers
SOURCE: kenmore coldspot - freezer stays cold, but frig isn't
If this model is a frost free, you probably have a bad defrost system. That would make the unit freeze up and cold air can not get through to cool the unit properly.
We have parts and supplies, so please contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
We look forward to working with you.
Posted on Nov 06, 2009
Refrigerator freezes
Sounds like might be the Temperature Control Thermostat or some sensor in the circuitry telling the compressor and cooling parts to keep running because it thinks it isn't cold enough. There is probably a circulation fan to blow the cold air through the damper and it may not shut off either, conveying too much cold thermal conduction through ducting and all frig parts, regardless of damper being closed or open. With the temperature set on low, do the compressor and fans ever shut off once cold temperatures are attained? Freezer should be 0 or lower, frig 35-40.
check this video at RepairClinic.comhttp://www.youtube.com/watch?v=5vA8Ksv5kVY&feature=player_embedded
Apr 07, 2013 | Electrolux Refrigerators
Cools but constantly runs
you hit the nail on the head there,,,its the thermostat its dead!
change it they often stick in the on poshion when they stop working to save any food inside of the fridge
Jul 12, 2010 | Haier HSB03 Compact Refrigerator
I have a Jenn-Air side by side frig. The freezer side cools too cold, the frig side not enough. 2 weeks ago I took all the food out of freezer and noticed ice build up on back. I unplugged unit, let it...
If the freezer is staying cold it sounds like a defrost system problem. A bad timer, heater or thermostat can cause frost to build up on the coils and block air flow to the refrig side. Check out ACMEHowTo.com for troubleshooting the defroster problem.
There is a small duct between the freezer and refrigerator side if this is blocked the frig side won't cool.
Jan 09, 2010 | Jenn-Air JCD2389G Side by Side...
Freezer works, frig doesn't
there is a fan on many newer units that blows cold air from the freezer side to the frig. If that fan is not working, the frig will be cool, but not 34° like you want it.
Nov 25, 2009 | Frigidaire Refrigerators
Kenmore coldspot - freezer stays cold, but frig isn't
Nov 05, 2009 | Refrigerators
Fridge not staying cold
First make sure that ur frig.is level. Then checx the cooling coils in the back. Make sure that all the vents,frig. and frezzer, are clear. Ur moisture control could be another factor.
Sep 13, 2009 | Refrigerators
Keeps running after shutting off-does not react to temperature co
it is normal for the system to run on its own without being turned on...the compressor motor needs to cool down and will run in an unloaded state. feel the back of the unit while its running and you will notice the amount of heat the motor generates. let it run.
Jun 18, 2009 | Heating & Cooling
thank u
rate me!!
Apr 10, 2009 | Kenmore Refrigerators
Freezer to cold refrigerator not cold enough
sounds like your defrost timer is not working properly . Most fridge/freezers the fridge gets cooled from the cool air from the freezer . But when the defrost timer is not working properly the section between the fridge and freezer freezes up and hence doesnt allow the flow of cool air into the fridge. The defrost timer can be easily replaced.
Jan 28, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Refrigerator won't get cold
hi!, if you did not turn on the thermostat by turning it clockwise and set on highier setting, it will not getting cold. 1hr is enough to test if the unit is in good condition.
Nov 19, 2007 | Samsung RF265AA Bottom Freezer French Door...
Refrigerators Logo
48 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
