Question about Frigidaire ATF6000ES Front Load Washer
Frigidaire affinity front end washer shows E61 code. The washer stops mid cycle and my or may not restart
Replacing the circuit breaker because in the past after the circuit breaker is off a couple days, the washer will cycle correctly
    Genius:
  • Frigidaire Master
  • 1,585 Answers
Check pump
Posted on Mar 02, 2015
4 Suggested Answers
esbee0522
SOURCE: Frigidaire Affinity ATF6000ES frozen
IF there is an E attached to the 45, it is your control board and the control board would need to be replaced. This is per the "Washer Tech Data Sheet"Hope that helps...
Posted on Jun 19, 2008
rabbitbrains
  • 575 Answers
SOURCE: my frigidaire affinity front load washer stopped spinning
Your door lock switch assembly has gone bad. It is an easy fix.
Posted on Sep 27, 2011
goodwinpeg
  • 744 Answers
SOURCE: Error code E61 shows on my Frigidair Affinity washer. Do you know what E61 Means?
Hello Murray;
My name is Peter. I am a retired field service appliance technician.
Hi E61 means that the control board is sensing an incorrect/abnormal voltage present at its input.
1.) Unplug the unit for 5 minutes. If the error comes back -
2.) Lets check your power cord:
a.) Unplug the machine. Is the middle connector on your power cord connected to 'N'?
b.) Tighten all the connectors. Make sure you have a good ground.
c.) Check the voltage. Between 'L2' & 'N' = 110V, 'L1' & 'N' = 110V, 'L2' & 'L3' = 240V.
3.) Lets check your control board for shorts:
a.) The following link will show you how to access. Ground yourself by rubbing your hands on bare metal. Static electricity will knock out a board.
b.) Check all of the connections, push in on the wires at the connectors.
c.) Reassemble and try to start
http://www.applianceblog.com/manuals/5995413084_Washer_2004.pdf
4.) Well, if none of the above solved the problem, you have to replace the control panel.
Part #: 134523106 - Cost: $168.00
Posted on Dec 08, 2014
How do I fix an Affinity front loading washer that stops mid cycle and my or my not restart?
Hello Murray Munger, thank you for your post!
I see that you are having difficulty with your Frigidaire washer stopping mid cycle and possibly not starting back up. From what you have described it sounds like a faulty control panel or wiring harness. You may want to have a technician come out and diagnosis your washer because he will have the appropriate tools to check and assure that the voltage going into each component is correct and if needed be exchange the faulty part. Hope this is helpful. -Matt
Dec 08, 2014 | Frigidaire Washing Machines
The dryer stopped and showed code E61.
Hello Friend, this is Z. Thank you for allowing me to assist you!
If you are receiving an error code E61 on your Electrolux dryer, it usually means that your dryer is experiencing an issue with the heater relay. A qualified technician would pinpoint the problem by checking the wiring for both open and short circuit across heater relay(s). If the wiring isn't the issue, he/she would need to determine whether the problem rest with the main control board. It really could be a hit or miss calculation in parts so I would personally reach out to an experienced tech that will be able to identify the precise reason. Best regards!
Sep 01, 2014 | Frigidaire FAQE7072LA Affinity Series...
Why is my Frigidaire affinity showing code E68?
Good Morning Gary,
I understand you are receiving an E68 code on your Frigidaire Affinity washer, model# ATF7000E. The E68 code states that there is a current leak to the ground on the heater or there is a fuse open. This could also be a false error code. I suggest resetting your appliance, by either unplugging it or shutting the power off at the circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 19, 2014 | Frigidaire Affinity ATF7000E Front Load...
Affinity washer flashing EFO
Good Morning Friend,
I understand that your Frigidaire Affinity washer, model# ATF7000E, is flashing an EFO code. I do not show an EFO code for your appliance.
I do show an EF1 code, which means the drain pump is clogged. In this instance you would unclog the drain pump.
I also show an EF2 code, which means too much soap was used. All you would do for this would be to try using less soap.
It could also be a false error code. I suggest resetting your washer, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. When you restore power, start any cycle on your washer. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 15, 2014 | Frigidaire Affinity ATF7000E Front Load...
Dryer wont heat up
Good Afternoon Friend,
I understand that you are having trouble with your Frigidaire Affinity dryer not heating up. There are some things that you are able to try. First check to make sure that the lint filter, the ducting, and the outside vent, are clear of lint and not constricted in any way. Second, reset your appliance by either unplugging it or shutting the power off at your homes circuit breaker for 3-5 minutes. Once power has been restored, run any cycle. If you are still noticing that your dryer is not heating, I suggest contacting your local authorized technician for further assistance. They should be able to diagnose your dryer and determine why your appliance is not heating. Hope this is helpful.
-Best Regards-
WP
May 12, 2014 | Frigidaire Affinity ATF7000E Front Load...
My frigidaire affinity front load washer buzzes and will not cycle what wouldcause that?
I see that your Frigidaire Affinity washer, model# ATF7000E, is buzzing and will not cycle. Some possible causes of this could be:
-Your washer is overloaded with clothes. Try taking some clothes out and restarting.
-There could be an article of clothing that might have slipped in between the gasket and the drum that might be stopping the drum from spinning. Check to see if there are any clothes that might be missing and possibly stuck between the drum and gasket.
If you have tried the above solutions and are still having trouble, I suggest giving your washer a hard reset. You will do this by either unplugging it or shutting the power off at your home's circuit breaker for 2-3 minutes. After the time has passed, restore power and start a cycle. If your appliance is still buzzing and not spinning, I suggest that you contact your local authorized technician for further assistance. They will be able to diagnose your washer and determine the cause of the buzzing and why it is not spinning. Hope this is helpful.
-Best Regards-
WP
May 05, 2014 | Frigidaire Affinity ATF7000E Front Load...
My frigidare affinity shuts down mid cycle , and has to be restarted many times in order to finish a load of clothes
Remove top of washer by removing screws in back of top. You should see the tech sheet. Use this to retrieve any error codes.
A common problem with these is a bad door switch. (The part the strike goes into. If this is the case you should come up with error code for it.
Mar 11, 2014 | Frigidaire Affinity ATF7000E Front Load...
My Frigidaire Affinity washer stopped working in middle of cycle and shows E41 code.
Hello Shawn Smith - Typically error code E41 indicates that washer has detected that the main control board thinks the door switch is open. Try reprogramming the washer by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If it proves to be ineffective, contact a professional to move forward accurately and properly assist with the repairs.
Mar 03, 2013 | Frigidaire Affinity ATF7000E Front Load...
My Frigidaire Affinity is brand new. Just did our first load of laundry and mid cycle it stopped and the PAU is lighting up intermittent with the time left. I have tried everything I can think of and it...
Hello Mary Fortner - It means that the washer has been paused; the cycle has been interrupted. Either the "Pause/Cancel" button or "Start/Pause" button has been pressed. To resume wash - press "Pause/Cancel" or "Start/Pause" once. If this does not prove to be successful please turn the breaker to the unit off for 5 minutes. Then turn the breaker back on to the unit, and retry the cycle setting again.
Dec 11, 2012 | Frigidaire Affinity ATF7000E Front Load...
Mar 19, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
145 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
