Question about Watches
How to set the time on Ingersoll Gandhi IN2700WH
Ingersoll Gandhi IN2700WH-automatic
Replace the battery in an ingersoll japan movement
I expect the battery will be where it is to be found in most other watches. Remove the back of the case and the battery should be fairly simple to access.
Oct 21, 2017 | The Watches
How do i manually wind my ingersoll automatic watch. It stopped after wo days of not wearing the watch
Shake it. It winds from the movement of your arm. A few good shakes should restart it.
Jul 07, 2016 | Watches
Resendly purshased a casio 4772 watch. diplay time and city. trying to get it set for dst. read manual and cant get button (A) to flash. can u help
Hi ...
your watch supports Time Zones , Automatic time Updates, Automatic adjustments of DST.
First Verify Correct Home City Is Selected
1. In Time Keeping Mode (That is The Digital Display shows time and Day of week)
2. Press Button (A) long enough to country code start to flash on digital display.nightflare_4.png
3. Press Button (B) or Button (D) to change Country code to current one.
4. After Selecting Desired Country, Press button (A) TWICE.
Now Country Code will be saved on watch.
Supported Country codes are:-
To Activate DST (Daylight Saving Time).
2. Press Button (A) long enough to Digital Display start to flash.
3. Press Button (C) TWICE to Display DST Settings.
4. Press Button (D) repeatly to cycle through three DST Options:-
A --> DST is set on Automatic Mode. If Your country uses DST, the watch will Adjust DST Accordingly.
OFF --> DST is set to disabled. No DST is applied to Main Time Settings
ON --> DST is Set to On. DST is applied even if your country doesnot follow DST.
5. Press Button (A) TWICE to save Selected Option.
Default values (Factory Settings) when you bought this watch is
This way you can set DST
Mar 13, 2011 | Watches
How to set or restart the fossil automatic ME 1030? Because the problem now is when the time turn at 12 at midnight, the date din turn..
sometimes during time set, the hands are set to change date at day time.
check it your date turns during 12 noon, if yes move the hands clockwise until you set your time and date on sync.
say you want to set your watch date:10th and time:10:15am
adjust your date at 9th
then move your hands clockwise until the date turns to 10th at the 12 thats the 12 midnight.
then continue moving your hands clockwise until you reach 10:15am
Dec 14, 2010 | Fossil MultiFunction Automatic ME1030...
How do you reset the second hand so it sits at the 12 o clock position on an Ingersoll diamond automatic chronograph watch
I don't know if it's the same, but I just solved this problem on a Victorinox (Swiss Army) Chrono Classic XLS. The process involves:
1) Pulling the plunger out to position 3 2) Holding both buttons down for 2 seconds 3) When the hands stop moving press the top button. Each time it's pressed it will advance the second hand one tick. Keep tapping the top button until the second hand is in the 12 position. 4) Push the plunger in.
Oct 26, 2010 | Watches
I have lost the instructions and cant set the time
Try Googling (pod)(548)(manual) without parens.
Aug 04, 2017 | Watches
How do you set the time
This watch has the time set automatically by a radio signal. Leave the watch in a windowsill overnight whichever direction would face Denver Colorado. At 2am, and again at 3am, it will attempt to make radio contact and automatically set your watch! All you'll have to do is to set the correct time zone. Good luck, and let us know if this worked for you.
Aug 02, 2009 | Casio Wave Ceptor with Analog Black Dial...
Sector adv 1000 setting alarm
key for setting time can be pulled fully (to set time) or shortly (only 0.5-1 mm) for setting alarm. then you should turn it and watch how it moves (automatic, without your turning). when it comes to desired time just push key in. the watch will automatically rewind to present time and it will re-start running.
Apr 14, 2008 | Watches
Casio Wave ceptor
Check to see if the watch is set up to get its time from another country. You may find that the fault started with a battery change or an all reset of the watch. The default location for many of these models is for North America or Asia. In some models the location is not active until it is set. In different parts of the world, they are using different time set protocols. There are some technical reasons for this.
Check the instructions about setting the time zone for the watch. Pay particular attention to the time zone setting, location setting, and that the feature is turned on in the first place.
Jerry G.
Apr 08, 2008 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
My Aquaracer Automatic doesn't keep exact time
you bought a automatic watch, they are a quality time piece, not an acurate time piece. if you want acuacy buy a cheap quartz watch.
Apr 07, 2008 | Tag Heuer WAF2110.BA0806 Aquaracer...
Watches Logo
37 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
