Http://www.useandcaremanuals.com/pdf/lm500-lm950138.pdf
Not sure what windows or operating system you have but when you pull up the link in the lower right you will see print download / save when you put your mouse over the lower right corner
I would recommend adding a small amount of the new litter in with the older product. Slowly you can start adding more and more newer product to the litter box until your cat receives the change without any problems.
SOURCE: Where can I buy a self-cleaning litter box for my cat?
Self-cleaning litter boxes are increasing in popularity and
are available at most local pet supply stores in your area or online. Here are a few places for you to search and
compare. http://www.petco.com/product/100832/ScoopFree-Automatic-Self-Cleaning-Litter-Box.aspx
I would recommend you check out the LitterMaid litter box. It has two sensors on either side of the box that detect when a cat uses it. After 10 minutes, a rake automatically comes and scoops clumps of solid and liquid waste into a disposable container at the end of the litter box. Keep in mind that this does not eliminate you cleaning the box.
SOURCE: If I buy a self-cleaning litter box does that mean that I am off the hook for cleaning?
Sorry to break the news to you but just because you bought a self-cleaning litter box does not mean that you do not need to clean it. While they keep themselves cleaner than other litter boxes, self-cleaning litter boxes still require an amount of sanitary maintenance. They necessitate regular washing and litter replacement. You should also keep an eye out for any waste that the self-cleaning system may have missed.
SOURCE: When should I refill the litter in my cat's litter box?
It is recommended to completely empty and clean the litter
box once a week, and then refills it with new litter.
compare.
