Question about PANDIGITAL PhotoLink PANSCN06
Add on to my question. When I scan the pictures and I load them on my computer they all are coming out half the picture. I've checked and it's not my computer nor the chip. It looks li
The scanner DOES travel all the way through the machine it just cuts off half the picture. I don't however have the cleaner anymore, but it's not a dirty think it seems it's a (not scanning) thing.
    Top Expert:
  • PANDIGITAL Master
  • 14,162 Answers
Scanners are VERY CHEAP. However her is the customer support info for the company:
  • Phone Number
    800-211-7262
  • Talk to a Human
    Press 0 at each prompt, ignoring messages.
Posted on Dec 08, 2014
  • Debra Wilson
    Debra Wilson Dec 08, 2014
    Thank you for the number however what would you call very cheap and where?
  • David Payne
    David Payne Dec 08, 2014
    I HAVE SEEN THEM AS LOW AS $30.00 FOR A ALL IN ONE AT WAL-MART AND KMART. I HAVE EVEN SEEN THEM AT YARD SALES FOR LESS THAN THAT. THEY MAKE THE MONEY UP ON THE INK.
Do you need software to have slide show on frame
What make and model digital picture frame?
Jul 05, 2013 | Photography
I have a 55 inch television that dosenot show a picture but the power button comes on green but turns red
Check the INPUT's make sure you are using the live one, for example it will be the CABLE or the DVD or what ever you set it up for.
Jul 24, 2012 | Sony Televison & Video
I have a Canon Rebel XT. After taking a picture, the viewer shows the shot upside down and when I down load to my computer they come in all upside or sideways. Just started doing this and I've had
The EOS cameras have some sort of sensor built in to tell the camera which way the shot should be orientated on screen and when they are transferred to the computer.
It sounds like the sensor is jammed or broken and sensing (for some reason) that the camera is upside down when the shot is taken.
If you don't want to pay to have it repaired you can use a program to rotate them or turn of the image rotate option in the menu. I believe this ignores the sensor information.
Jun 24, 2012 | Canon Cameras
46in Vizio LCD HDTV distorted black picture when tv is turned on
Hi There are three things that can cause this problem. Your lcd screen, t-con board or the signal board. Most likelly in your case since you say it's only half the screen it's going to be your t-con board. You can try removing it and cleaning all the contacts and replacing it see if that helps. If that doesn't help then replace it. If that does not solve it then it's going to be your screen.
You can get parts at www.interliquidparts.com
Nov 28, 2011 | Vizio VW46LFHDTV10A 46 in. LCD TV
I need to scan something from printer to computer an don't know how to do it. Can you help me please?
Hi:
It's real easy, all you need to do is load the software that comes with your printer in your computer, once it's loaded. Put the picture facing down and go to your start button (left hand bottom side) click on it, go to programs, go to lexmark and click on Lexmark All-in-one Center. Once the window is open go to your right upper side and click on Preview Now. Your printer/scanner should be scanning the picture and this one will appear on the blank space, once it finished you can crop the picture as you desire and then click on the Scan Now button. That's it!
More easy: On the left hand side of your printer there are three buttons; power, copy and scan. Press Scan and the all in one Lexmark program will open and you will see the picture in your computer, crop it and press Scan.
Sep 15, 2011 | Lexmark X2350 All-In-One InkJet Printer
My color picture is coming out black and white. I can't figure out how to fix that. I've scanned color pictures before...
You might be selected print in grey scale only.
Go the printer properties> printing preferences >color remove check mark then try it..
Sep 14, 2011 | HP OfficeJet 4215 All-In-One InkJet...
The screen only shows the bottom half of the picture. I have a RCA TruFlat 27" TV and it has a horizontal line in the middle & only shows the lower half of the picture. I've smacked it a...
The problem of your tv is only a loosed solder.Remove the back cover of your tv but be sure to unplug it then try to look the solder part of your tv look for some loosed solder then try to resolder it using a soldering iron but be sure not to connect separated pin in the pcb.
Jul 05, 2011 | RCA TruFlat 27F520T 27" TV
I need to send my picture to another country;I have my scanner how can i also send it through my computer ?
1. Scan the picture.
2. Save the scanned picture.
3. Upload it to a website like http://imageshack.us/ or http://photobucket.com/
Once you've uploaded the picture, you can share the link to your friend or to someone from another country.
Jun 03, 2011 | Office Equipment & Supplies
I've had kodak easy share on my computer for years. Recently I tried to access the pictures and got "can not process your request..(error code 9477068x301x94770168x) I have called them &...
Forget easy share, just take out the memory card (SD card) from your camera and buy a SD card reader. Put this memory card in the card reader and plug the card reader in your computer USB. It will work like a normal pen drive and you will find all your pictures inside DCIM folder of your memory card. Copy all pictures in your computer HDD to be on safe side.
May 07, 2011 | Computers & Internet
PANDIGITAL PhotoLink PANSCN06 Logo
Top PANDIGITAL Office Equipment & Supplies Experts
Mike
LP
Are you a PANDIGITAL Office Equipment and Supply Expert? Answer questions, earn points and help others
