Door does not open when the latch tries to release it??
  • 720 Answers
Child lock activated.switch off machine , wait fir a couple of minutes then switch on machine and hold start button for 30 seconds.you should hear a click.then switch off and wait one minute.door should then release.
Posted on Dec 08, 2014
How can I open the left rear door if the latch won't release?
Its the child safety on, you can try disengaging the child safety if partially open, black latch
Feb 01, 2016 | Jeep 2004 Liberty Limited Edition
Unlock the right side door. The door is open but the latch is in the locked poisition
open the latch by unlocking and operating the door release handle and if it does not unlatch then use a tool like a screwdiver to pull the latch open when the door release is activated
Oct 18, 2014 | Ford Explorer Cars & Trucks
Door stuck closed
The door has the child safety on possibly try opening from outside with a little leverage if not successful remove door panel to unlatch from inside with a small screwdriver on the latchy
Jul 22, 2014 | 2002 Jaguar X-Type
Oven door latch will not release so that I can open the door
Try jiggling the door by the handle. Jiggle it hard, both sideways, in/out and up/down. The little piece in there that releases the door may just be stuck, and didn't move quite far enough to let the door open. These things happen.
Nov 28, 2013 | GE Profile JTP18 Electric Single Oven
1989 chevy cavalier - somehow safety door lock engaged and now I can't close the driver door. How do I unlock it?
  1. This is what probably occured
  2. While the door was open the latch on the door was closed
  3. If the spring inside the latch is broken, Working the inner or outer door release handles will not open the latch.
  4. place a screwdriver in the opening of the latch where the door striker would be if the door was closed.
  5. apply pressure to the latch paw while operating door release.
  6. latch should open.
  7. replacement of the latch will keep this from happening again
Sep 07, 2010 | 1989 Chevrolet Cavalier
Gas cap door will not open when release latch is
You might try having a friend bump the gas cover with the heel of their hand while you **** briskly on the release. Have done this a couple of times and once opened, you can use a little lubricant on the exposed parts. Sometimes that is enough.
Jan 09, 2010 | 1994 Honda Accord
RR window on my 02 Lib fell and now that door won't open!
As a last resort, I might try something like that, but remember that the door is heavy and that hanging it from the latch assembly will not do good things to the latch. If you try that, I'd first open the window and tie the door off to the roof rack to keep the door weight off the latch. Likely the latch will not release by removing the hinge bolts, but it may give you more room to get the inside panel removed.
Jul 19, 2009 | 2006 Jeep Liberty
When i try to open the door it wont move the bottom latch releases but the top wont and i cna get to it to try to remove it
Section 501-14A: Handles, Locks, Latches and Mechanisms 1997 F-150, F-250 Workshop Manual REMOVAL AND INSTALLATION Latch, Rear Door — Upper Removal
  1. Remove the rear door trim panel; refer to Section 501-05 .
  1. Remove the rear door radio speaker.
    1. Remove the four radio speaker screws.
    1. Disconnect the electrical connector.
  1. Carefully peel off the rear door watershield.
  1. Disconnect the upper rear door latch cable.
    1. Lift the clip.
    1. Pull to release the cable from its seated position.
  1. Remove the upper rear door latch.
    1. Remove the three screws.
    1. Pull the upper rear door latch and the cable up through the door latch opening.
Apr 14, 2009 | 1997 Ford F150 Regular Cab
The power sliding passenger door will not open even manually. At first it didn't want to close, but after I slammed it shut it didn't want to open. A few days later I was trying to get the door panel off...
I think you have a latch issue or a latch release issue, pull the door panel and try and release the door latch, pull the latch and try to see what if anything is wrong with it, also make sure the linkage going to the latch from the release handle is hooked up or not otherwise damaged.
Oct 22, 2008 | 1998 Oldsmobile Silhouette
Dishwasher door will not open.tried running it another cycle and still nothing.It is a GE profile with the latch that you just push in. The latch/handle seems stiff.
The plastic latch release inside the door handle is broken. Most likely one of the pins holding it in place has broken.
First go to your local dishwasher supplier and look at a similar brand (GE Profile in my case) and see how the mechanism works. Next, get a thin pair of siccors, pull the dishwasher handle down and slid the siccors into the opening above the handel and push the tab holding the door closed up so it will release.
Once the door is open, remove the inside of the door to get to the latch. Remove the plastic latch release and order a new one.
Sep 28, 2008 | Dishwashers
Washing Machines Logo
Top Washing Machines Experts
