Question about Toys
Need the 4.5 AC adapter for the electronic pet feeder.
Looked for the order info sheet that came in the box
I need to know the relay order on the ac drivers side. What numbers on the fuse go into what. Space?
You want a picture of fuse box?
I need your year--make--model to try to look up info?
Sometimes, your fuse box cover will have that info, if not, try your owners manual.
May 18, 2016 | AC Cars & Trucks
Need 4.5 AC adapter for pet feeder
THE BEST PLACE TO GET AC ADAPTERS IS RADIO SHACK. TAKE THE INFORMATION YOU GOT AND THE PRODUCT YOU GOT AND GO TO A RADIO SHACK AND SPEAK WITH A MANAGER. GOOD LUCK.
Dec 08, 2014 | Pets - Others
What is the correct AC adaptor for this model ?
Been looking all over for mine and found no help online. Just found the adapter in a box so heres my info:
Output: 9.0V 0.5A
On the connector itself, outside is positive, inside is negative.
Model Number of adapter is SCF0900050A1BA
Hope this helps somebody in the future... Or at least I find this page again next time I misplace the adapter
Jun 21, 2014 | Dmi Sports 30-E800ARA Cricket Pro 800...
Why would someone use a heated pet bowl?
Heated bowls are ideal for outdoor pets. In order to keep your dog/cats water from freezing in cold temperatures, heated bowls are the only way to go. Make sure to look for one with a "anti-chew" cord protector to further ensure your pets safety.
Aug 26, 2012 | Alessi Pets - Others
I lost my ac charger and need to know where to order a new one
I think the DVD Player was made for Target, you might be able to go there and find one and get the info off the power supply (charger) and take the unit and the info to Radio Shack for a replacement. If they can not help try calling MCM Electronics at 1-800-543-4330
Feb 16, 2009 | Curtis DVD8017 Portable DVD Player
What does umax astra 3400 scanner power adapter looks like/
who cares if it is the proper voltage,amps and plug. . you need a wall wart , the plastic box with two flat blades sticking out that 12volts DC center positive ,700 milliampsfor the non negatine scanner and 1 amp(1000 milliamps) for thr negative scanneer model an AC/DC adapter look around at 2nd hand stores they usually have a selestion or order online from electronics supplier
Jan 13, 2009 | Umax Astra 3400 Flatbed Scanner
Not feeding
Have you still getting the problem, have you done cleaning of Cartridge, its nozzle and Contact strip.. then cleaning of Printer roller or carriage rack.. Do a Service of it or get it done by Technician.
Also check the feeder tray.. to grab paper one by one by printer.. Manually
Take all updates for printer and OS.
Oct 31, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Toys Logo
41 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
