Question about Garden
How do i keep it running after starting will not excellerate
  • 1,169 Answers
Without the make and model numbers it is a guess but either you have a clogged spark arrestor or the carburetor need tuning.
Posted on Dec 08, 2014
Have 3.0 24 valve engine has intermitten rough Idle and during driving at excelleration
What are the trouble codes set? Get them read for free at most auto parts stores.
Dec 10, 2014 | Cars & Trucks
Starting, idleing problems
Auto idle module may be bad or the idle valve on the engine may need to be cleaned.
Jan 30, 2018 | 1995 Jeep Grand Cherokee
94 jeep grand cherokee. starts,idle. throw warmup. as soon as I touch the excellerator let up the rpm drop & engine stalls.
Most low idle speed problems on these engines are due to a faulty idle air control valve but since you state the idle will go up and return to idle then i would say it is working properly i think you have a throttle body coking problem ( dirt and grit accumulates around the butterfly valve in the throttlebody ) to fix this simply remove the fresh air hose from the throttlebody and open the throttle all the way up use a clen rag and wipe clean you may use a solvent such as B12 on the rag but dont use too much 1_4_2013_4_54_06_am.jpg
Jan 04, 2013 | 1994 Jeep Grand Cherokee
2003 gmc 2500hd duramax loss of excelleration/throttle
Diesels only need basically 3 things to run.
1. Air
2. Fuel
3. Compression.
If one of the 3 is lacking performance would suffer or completely keep the truck from starting.
Oct 01, 2011 | Cars & Trucks
My kia is not running after it is started up and it shuts down to the point that if u keep starting it, eventually the battery goes dead. weeks before it started this it would take time to pick up speed...
check the sparkling plugs and also the ignition starter, should be one of these,
you can actually see if the sparkling plugs are generating any sparkles.
Feb 28, 2011 | 2004 Kia Sedona
Transmission surges win it shifts When you take off it runs fine, until it shifts gears and then it starts jerking will bad. Let of the gas and excellerate again it run fine.
Hi , you need to change the oil filter in the auto drive and use a good type oil ie elf matic If the oil is black or very dark exspect to have a rebild, the oil should be changed every 12 monthes to keep the box in tip top condition.
Regards Andy
Sep 03, 2009 | Pontiac Grand Prix Cars & Trucks
1981 650 poor excelleration
not enough to go on, but these were not slow bikes. try plugs, mucky carbs, carb jets, air filter.... take out plugs, any dirty black while others are clean or white? start bike from cold, run very short while and turn off. carefully feel exhaust pipes at top, are thay all same temp? one or two not getting warm? watch you don't burn your hands....will tell you if all cyliders firing ok.
Aug 06, 2009 | 1981 Yamaha XJ 650
Problems excellerating and hesitates then engine light starts flashing but keeps running
Could possiblty be an o2 sensor, or if it has the 3.8 engine in it make sure there isnt a crack in any of the coils.
Aug 06, 2008 | 1999 Oldsmobile Alero
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
