Question about Plumbing
Altech condensate pump - turns on ok but when it turns off there is a harsh metalic rattling sound. any ideas what the problem could be?
Nothing, i am not experienced with this
  • 1,920 Answers
I am wondering if the impeller is loose on the pump shaft. or the bearings are shot. When it starts up there is enough pressure so it stays solid on its shaft but when it shuts down it has no running pressure so it rattles. The only way I know of getting into it would be to remove the pump and possibly removing the housing to get to the pump shaft. It may run like this for a while but sooner or later will just seize up or fly apart. I just replaced one that was six months old and the pump was under warrentee so they replaced it.
The bearings were shot.
Posted on Jan 24, 2015
2 Suggested Answers
GM Elec
  • 1000 Answers
SOURCE: Electric Maytag Neptune Dryer - rattling noise
Your probably going to have to remove the rear panel and take a look to see what is causing the noise.
Disconnect the power cord and exhaust tube, remove the rear panel and check for anything loose.
You can also pop the lid and fold it back to inspect the top of the tub and belt. Roll the drum all the way around and inspect the belt for "chunks" missing.
If you include your model number, I can send you a web site that will show you an exploded view of the dryer.
Regards,
Posted on Aug 14, 2009
Have a 2006 titan; noticed excess condensation and some white smoke after it was warm; also went I accelerate it sounds like a "metal rattle"(?) doesn't make that sound when at an idle...any suggestions?...
The condensation and white smoke could just be excess moisture that can build up in the muffler when the vehicles isn't used for a while or has been doing only short runs (less than 25-30 miles).. Keep an eye on the coolant level, and if it stays good then there isn't much to worry form that. As far as the "metal rattle" on acceleration, this could be what is known as "octane ping". It means that the engine is knocking a bit from fuel that isn't giving it enough octane. Cheap gas and occasional blending errors can cause this. Try running a tankful of mid-grade fuel next time. IF the noise goes away, you've found the culprit. Octane ping doesn't really hurt the engine, but it is annoying. You may be able to still use regular grade fuel, but might have to change the brand to find one that the truck likes better.
Mar 22, 2015 | 2006 Nissan Titan
My 1998 sebring 6cyl makes a metal on metal noise on the side of my engine by the belts i tried greaseing all the pullys and i used belt noise sparay but it becomes lower and then it becomes higher ???...
sounds to me from the brief description like you have either a water pump rattling, or a timing chain coming slack. Is the noise coming from the alternator? Never grease pulleys, ever. also the stop squeak spray is bad for your belts. Don't know why they even sell it. If you listen carefully you may be able to pin point the rattle. Is this a tick tick tick, or a rattle rattle rattle? Does sound like a water pump rattle or timing chain slap though. Hope this helps
Jan 14, 2013 | Cars & Trucks
My 2004 Prius has a rattling metallic sound on acceleration. It is coming from the top of the engine on the passenger side. Does anyone know what this can be?
Does the car make this sound when the car has just been turned off and engine is still hot? Lightly push the car back and forth while it's in park. Does it still make that sound?
Sep 23, 2012 | Cars & Trucks
2001 isuzu first startup rattling metallic sound under cars front
You didn't say which model or engine.
Check for loose heat shields, broken engine or transmission mounts.
Aug 18, 2009 | 2006 Pontiac G6
Regards,
Aug 14, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Clunking/vibration/squeling noise under the front end
sounds like u need front brake pads and rotors i would check brakes first if ok then i would check front wheel bearings but cv joints make a clicking sound usauly when turning
Mar 29, 2009 | 1997 Chevrolet Cavalier
Metal to metal rattle
check the bolt on the hood hinge. That sound drove me nuts until my brother told me to check it. He has a lot of GM tech friends and owns 7 Jimmy/Blazers
Jan 03, 2009 | 1998 Chevrolet Blazer
96 Mazda Protege 1.5 L Rattles When Accellerating
possibly the cat itself broken up and rattling in side the silencer especially if more noticeable when engine warmed up.
Dec 12, 2008 | 1996 Mazda Protege
Washing machine makes a loud rattling sound
Hi.k.
Even though you have cleaned filter, there could still be something in the pump, you need to remove the pump and check there is nothing in it.
Hope this helps.
Good luck.
Please leave feedback
Nov 30, 2008 | Kenmore 98702 Stacked Washer/Dryer
Fridge model c373 is rattling. Has been repaired twice to no avail.Sounds like bottles rattling but have removed all items from fridge. Was sent away for repair and when given back had a rattle.
there are two things that come to mind from what you are describing one is the evaporator fan is mialignet and hitting its caseing in the freezer or the condenser fan behind the unit where the compressor is is doing the same thing pull the unit out and check it first as its metal and would give a closer sound as your describing
Jul 22, 2008 | Refrigerators
Plumbing Logo
65 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
