What is the meaning of code e-01 on riso tr1510
Cleaned all sensors
    Top Expert:
  • Office Equip... Master
  • 14,161 Answers
This is a common error among riso machines. this has something to do with the main motor. main motor is a minor factor of this trouble. mostly the problem is *ssociated with main drive itself, like probolem with the clamper area. when the clamper falls, the tendency is to block the rotationm of the drum thus the error.
also please note that any obstruction on the rotation of the drum will likely cause this trouble.
good luck.
Posted on Dec 08, 2014
Riso EZ 200E model gives error message A-01 -211
A-01-211 basically means there is master material under the position sensor while in standby. Referring to the manual open the master drawer and clamp rewind the master material back on it roll and close the lid/clamp. This allows the master unit to reset or to say "return home" action. Now open and re-insert the master material in its proper place. This is similar to A-34-218 code.
Nov 07, 2013 | Riso RZ220 Duplicator
Somebody that speak Spanish? Riso RZ 220 UI have a code that say P18 531. What is the problem?
P18-531 means: Print drum lock sensor is still ON even after 100 milliseconds after the print drum lock solenoid is activated.
Mar 16, 2011 | Riso RZ220 Duplicator
Where can i download free service manual for RISO TR1510?
I found one here.
http://code.google.com/p/rjournal/source/browse/branches/agpk/manual/RISO%2BTR1510%252C%2BTR1530%2BParts%2BList%252C%2BTechnical%2BManual%2BService%2BManual.zip?spec=svn185&r=185
Mar 10, 2010 | Riso Office Equipment & Supplies
Need manual for riso tr1510
I doubt these exist in an electronic form. Best bet is to contact RISO directly at 800.942.RISO for assistance.
Jul 17, 2009 | Sweet Beginnings Cabana Stripes Crib
What does the error code E 01 stand for?risograph 4050
If its CR or TR, E-01 is main motor lock. turn off machine and hold reset button in while you turn the machine on again. Make sure your master removal unit and master feed unit are closed corectly.
Apr 07, 2009 | Riso RZ220 Duplicator
Paper feeding problems Riso TR1510
refix your ink cartrdige also check there is not any paepr jam issue.
also some times printer neeed servicing creates this type of issue.
Mar 28, 2009 | Riso Office Equipment & Supplies
Rsio TR1510 Error Code E01
Yes Easy. Get out the Sylinder drum, switch off the machine: open a back cover' on a board press reset then switch on the machine while the drum is out; then insert the Sylinder Drum. the error should be gone.
CHIMUNTU
Mar 21, 2009 | Riso RZ220 Duplicator
first try paper feed clutch.. make sure nothing is blocking paper path...
Feb 03, 2009 | Riso RZ220 Duplicator
Riso ks800
e4-ink over flow. solution-clean ink sensor.
e3-clamp motor locked. solution-use code 64
Sep 21, 2008 | Office Equipment & Supplies
Risograph TR1510
lol.. there's no thermal head on a Riso..lol..
Ok..Print a big black square and run the machine maybe 300 prints until it starts pushing ink through, set the machine on darkest setting.. The ink in the screens is just old and sticky.. If you go through a case of paper (5000 sheets) and it still isn't getting better then take off the master and use some varsol and a lint free cloth (LINT FREE!) to dab and clean the whole screen to loosen up the clogged ink.. If that's not working then you really have to take the screen off and clean it first with varsol,, then some soap and water.. You have to be really clean about this because lint or any thing will cause white dots on your print. (hey this happened to me) If you've cleaned it really well you should take a clean scraper and prime the screen area with some fresh ink.. this is messy.. but it will get you going for good..
Jun 30, 2008 | Sweet Beginnings Cabana Stripes Crib
59 people viewed this question
jasbo
jasbo
