Question about Internet Computers & Internet
Vodacom 3G card dongle not accessing the internet after installing the drivers
Installing the drivers and running the software that came with the dongle.
    Problem Solver:
  • 7 Answers
Restart the laptop, and see if it still doesnt work, then check device compatibility with your OS, if even then it still doesnt wok it probably needs a software update, even then if it doesnt work you should call up customer service and have them take a look
Posted on Dec 13, 2014
Toshiba satellite pro l500 2011 Tear down access the 3G blue motherboard add a sim card, How to enable its laptop to internet capability mod?
If you want to sacrifice your wireless then technically this could work. The wireless card is generally connected via 2 wires that can be disconnected. If you have a 3G 'card' with the same connector to the motherboard, and also if there is software / drivers to work the card in windows, the this may work. A much easier solution would be to purchase a 3G USB dongle.
Apr 17, 2013 | Computers & Internet
Usb dongle is not working
Step 1:
A Bluetooth dongle is an external Bluetooth device used to enable your PC's Bluetooth connection. Many Bluetooth dongles come without installation disks since the software is pre-programmed into the actual USB stick. These Bluetooth dongles are very useful on netbooks that don't have Bluetooth connection, since netbooks have no CD-Rom drives. Turn on your PC. Insert the USB Bluetooth dongle into the USB port on your desktop tower, or the USB ports located on the perimeter of your laptop. Wait for the program to auto run. Once you connect your dongle, the driver program should launch. Follow the onscreen prompts to install the dongle. A dialogue box should open that says "Installing Drivers" from the taskbar. Allow the driver to install completely before closing the box. Unplug the dongle and restart your PC. Once the PC has been switched on, insert the dongle. Double-click "My Bluetooth Places." This is the Bluetooth icon located in your taskbar, and it should launch the "Initial Bluetooth Configuration Wizard." Click "Next" on the first screen. Next, type in the name of your computer and select your computer type from the drop-down menu, then click "Next." Click "Skip" on the onscreen prompts, then finish. Pairing the Devices Turn on your external Bluetooth device. Double-click "My Bluetooth Places." Select "Find Bluetooth Devices." The name your Bluetooth device should display in the next window. Right click the icon for your Bluetooth device, and scroll down to "Pair Device." Enter the Bluetooth pin code for your external device in the "Bluetooth Pin Code Request" pop-up window. Then click "OK." The default pin code is normally "0000" or "12345." You can find your pin code in your user manual. If you are pairing a cell phone to your PC, you will have to enter the same pin code on your cell phone to establish the Bluetooth connection.
Apr 10, 2013 | Computers & Internet
Hi there, i hav jus got a new netbook of the internet and i have already got a 3g dongle, however when i put my dongle in the netbook it is not comming up with it to install it:/ however the dongle is...
The internet dongle contains the drivers/ software in it and when you connect it with the PC, it automatically runs the setup.exe file and installs it. It its not running the setup automatically, try the following steps: -
Open "MY COMPUTER"
Locate the removable drive
Right-click on it and choose "AUTO RUN"
Else, Open the removable drive (of dingle) and run setup.exe.
This will install the necessary drivers and software for dongle.
Please note that the blinking light of the dingle only indicates that it is connected to the PC and its ready for use. But you cannot use is unless drivers/ software is installed.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 20, 2011 | Computers & Internet
Dear Sir, There is no provision of fixing my laptop to a wireless router.Can anybody advise how to convert this laptop to enable getting wireless connection of internet?
There's a lot of available wifi adapters out there that you can just plug into your laptop's usb port. You can try looking them up online or in computer shops.
Jul 29, 2011 | Computers & Internet
How to access internet connection using your regular sim card
The easiest way to acces 3G networks using your computer is to buy a USB dongle - comparable in size and looks to a regular USB stick, but they allow you to insert your sim card and use software to connect to 3G using the dongle.
Alternatively, you can also connect your cellphone to your computer using the cable supplied with it - this is called "tethering". You won't have to swap your SIM card this way, but not all cellphones support tethering and it can be quite some work to get this to work, depending on the make of your phone.
Mar 01, 2011 | Samsung Computers & Internet
How to connect internet through 3g sim on hcl me laptop
USB dongle from your provider will have a specific SIM card installed for the job. Plug in dongle and as a rule, most install software automatically - job done.
Mar 02, 2010 | Computers & Internet
How do i install a 3G dongle to my mine pc when it
It needs a driver. Go to the manufacturer's (or seller's) site and download the one for your dongle and your OS.
Oct 27, 2009 | Computers & Internet
Where can i download ethernet drivers for acer aspire model 3680
you can download drivers for laptop on acer site go trou suport menu select laptop and so on
Oct 07, 2009 | Acer Aspire 3680 Laptop
Wireless internet
The 3G mobile internet adapter is a small dongle that you need to plug into a computer.
The software setup is often automatic, and software will be installed by the dongle itself.
After installing you will need to pay for internet traffic, either with a contract and monthly fee, or with a pay as you go contract.
Fees vary depending on your country and on companies.
Here is an example of 3g adapter for UK MOBILE BROADBAND MODEM HUAWEI DONGLE 3G USB MODEM.
Better to buy adapter, sim card, and eventually cotract all from same company at a shop.
Feb 10, 2009 | Gateway Wireless-G PC Card (6002547)
Dongle on 3 net work
You did not give enough info for a detailed answer.
Error 619 is a non-specific error and can be caused by a number of things. Possible causes include:
  1. The incorrect profile is selected in the 3G device software.
  2. The SIM card is dirty.
  3. The SIM card has been inserted incorrectly.
  4. You have reached your limit for the month.
  5. The 3G device software has not installed correctly or has developed a fault.
  6. The USB driver has not installed correctly or has developed a fault.
  7. You are out of range of the network.
  8. The network is down.
  9. The USB 3G device has developed a fault.
I hope this helps you determine your problem.
Oct 20, 2008 | Computers & Internet
Computers & Internet Logo
Tejodhar Atreya...
Tejodhar Atreya...
vojvodabudva
