Question about Kuppersbusch Ovens
My Kuppersbusch oven fills with steam during cooking a joint and roast potatoes come out soggy . What am I doing wrong?
I'm cooking on the Fan setting - should I be using top and bottom heat instead?
  • 236 Answers
SOURCE: Fan assist wont heat oven
the ring element may have blown. if it works ok with the top and bottom elements, (the convection oven) then it is likely the element surrounding the oven fan.
Posted on Jun 25, 2007
  • 236 Answers
SOURCE: smeg oven suk92mfx5
ring element has burnt out.
Posted on Feb 16, 2008
freetek
  • 5568 Answers
SOURCE: electrolux oven wont heat up after power cut
It may be necessary to actually pull the AC plug out and let it stew for a while.
Many electronic controls lock up with a loss, then return, of power.
Posted on Aug 03, 2008
  • 8 Answers
SOURCE: Kuppersbusch EEB9800.0 oven - thermostat sensor defective
you need part number 165047 cable harness and part number 161629 thermostat pt1000 call currys partmaster and get a quote on the parts
Posted on Jun 27, 2009
  • 13 Answers
SOURCE: Neff U1721 bottom oven not heating fan & light are ok
Yes it will need a new element, if the fan runs and temperature light comes on then the element is gone.
Posted on Jul 29, 2009
How long do I cook a 2kg leg roast in a fan forced oven for?
Plenty of opinions online if you search - try this link.
https://www.google.co.uk/search?q=meat+cooking+times+and+temperatures&rlz=1C1CAFB_enGB673GB676&oq=meat+cooking+times%3F&aqs=chrome.1.69i57j0l5.13677j0j8&sourceid=chrome&ie=UTF-8
Rule of thumb cooking time for a joint is 20 mins per pound plus 20 minutes for a standard oven with times reduced by around 30% for a fan oven.
Ovens do vary and it is important for every good cook to "know" their own oven - and the learning process usually includes some culinary disasters...
Feb 01, 2018 | Ovens
How to defrost a roast lamb in a vario stream oven
Have a read of this. I am a chef and would advise the traditional way.
Cooking a Frozen Roast Without Thawing - Cooking - eGullet Forums
https://forums.egullet.org/topic/112634-cooking-a-frozen-roast-without-thawing/
Feb 5, 2008 - 25 posts - ‎15 authors
So now there's a 10 or 11 lb. beef shoulder in the oven. ..... roasts with additional water added as required were put into a large steam kettle to ... This works with any meat Pork, Lamb, Beef or even Frozen Turkeys especially at ...
defrost roast lamb in vario stream oven Google Search
Apr 30, 2017 | Ovens
How do i clean the inside glass of a kuppersbusch oven ?
Hello, Make sure the oven is warm, not hot. Open the door and spray the glass with vinegar and water and wipe with newspaper.
Dec 11, 2014 | Kuppersbusch Ovens
Technika bellissimo oven
Have a Bellisimo Technika free standing oven. Cannot get oven to heat on fan force setting but it works on all others. Please help
May 19, 2013 | Ovens
Why is mu beko cooker building up steam in the over and making food all soggy comet have told me not to cook food with any water in but thats impossible
You do not normally cook with water inside the oven, ovens are for dry cooking only, rings are for boiling water and used for cooking this style
Jul 12, 2011 | Ovens
Seams to be a lot of steam/ vapour in main oven. when you open door cluds of steam escape. This is the 4000 twinline all electric model.
I have an electric oven and the same problem: loads of steam when I open the door. Plus roasting is a problem, the pan fills up with water and needs to be drained so things are stewing and not roasting. Have spent ages trying to to find a solution so would also appreciate any advice.
Oct 17, 2010 | Ovens
How best to cook turkey. What setting?
hi friend,
step 1
Preheat oven to 325 degrees F.
  • Step 2 Remove turkey from its wrapping and remove neck and giblets from inside the cavity. Set aside to make gravy later (see Related eHows).
  • Step 3 Rinse turkey inside and out with cold water. Pat dry with paper towels.
  • Step 4 Put oven rack on lowest level of oven.
  • Step 5 Place turkey, breast side up, on a roasting rack in a roasting pan.
  • Step 6roast1s.jpg Rub the outside of the turkey with olive oil.
  • Step 7roast2s.jpg Salt and pepper the turkey's body and cavity.
  • Step 8roast3s.jpg Roast turkey about 3 hours, or until a meat thermometer inserted in the thickest part of the thigh registers 175 to 180 degrees F.
  • jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); Tips & Warnings
    • In general, a turkey should be roasted 10 to 12 minutes per pound if it is not stuffed and 12 to 15 minutes per pound if it is stuffed.
    • In general, you shouldn't cover a roasting turkey (or any roasting meat); you want the skin to get a nice, deep brown all over, and you don't want it to steam in its own juices. However, if the turkey begins to brown too quickly, well before it's likely to be done, you can cover the brown parts loosely with aluminum foil. (This is likely to happen with larger birds.) Try to cover as little of the turkey as possible so you don't create steam.
    • Be sure to check out other eHow turkey recipes - search the site for "turkey."
    Who Can Help Sponsored
    • How to Lose 30+lbs Guaranteed. Try it Free.
    hope this helps u
    please rate me..........................
    thank u for using fixya
    regards
    sivaranjini
    Nov 26, 2009 | Viking Ovens
    Cannot get vegetables & potatoes to roast & crisp up properly
    Use fanbake and crank the heat up to 250 Par boiling the veges will help
    May 18, 2009 | Fisher and Paykel OS302SS, Stainless Steel...
    Aug 26, 2008 | Kuppersbusch EEB 6800.0 JX Electric Single...
    Ovens Logo
    55 people viewed this question
    Top Kuppersbusch Ovens Experts
    ashburton
    Angel Joseph Jr.
    Angel Joseph Jr.
    Tom Chichester
    Are you a Kuppersbusch Oven Expert? Answer questions, earn points and help others
