Question about Hardware & Accessories
I set the timer both on and off but it did not turn the lights on or off automatically... I have it set on auto... What do I do?
I set up this timer time, date, zone, and each days on and off. I plugged it in but it never turned the lights on automatically. What did I miss?
  • 3,382 Answers
Sounds like it is new, take it back and have them show you how to set it.
Posted on Dec 09, 2014
protek480
  • 1723 Answers
SOURCE: Lights won't automatically turn on BUT will automatically go off
Are you using the red peg for 'on' and black for 'off'?
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jun 27, 2009
  • 207 Answers
SOURCE: T101 Intermatic Timer will not turn lights on or off
You have a weak timer motor. The T101 is notorious for it. I have 6 on my property and have had that problem numerous times. You need to replace the guts of the timer.
Posted on Jul 08, 2009
SOURCE: grasslin plug in timer T25/16FMB problem
The Grasslin analog timer works same as GE 15070
http://waterheatertimer.org/GE-timers-and-manuals.html#15070
You can also download Grasslin manual:
http://www.intermatic.com/products/grasslin/electromechanical%20timers%20and%20timer%20modules/in-wall%20timers.aspx
Posted on Mar 29, 2011
SOURCE: SunSmart 15312 - timer has
Sun Smart is new GE timer.
http://waterheatertimer.org/GE-timers-and-manuals.html#15312
There is no repair for defective timer, except buy another at Home Depot and return defect in new package.
When I bought 15312 timer for testing, I found many packages at Home Depot were taped together as if people returned the timer. The large aluminum fin shows that timer is expected to get warm.
When testing the timer, the door stuck, and the timer seemed cheaply made. Intermatic brand timers are more robust at this time.
The instruction manual is not clearly written as could be, and timer requires a lot of button pushes for each setting.
Because the instruction manual is complex, requiring multiple button pushes for each setting, I suggest writing out the steps to make sure nothing is skipped over.
If lights turn on-off with override, then timer should be wired correctly.
Be sure to reset timer before programming.
Press setup button twice to begin programming.
Check programming for conflicts and overlaps that will cause timer not to function as expected.
For example selecting days of week. If program1 ON says turn on at 7:00 pm all days of week, and program1 OFF says off at 9:00 pm Tuesday.
Another point of confusion is Dawn-Dusk-Time. If you want timer to turn ON at 7:00, then select Time.
Posted on Sep 21, 2011
  • 5245 Answers
SOURCE: How to set time on Yardworks two zone water timer
Copy following link to access manuals for each brand of water timer on market 2013:
http://waterheatertimer.org/Woods-timers-and-manuals.html#sprinkler
Yardworks does not have website, manuals or warranty claim procedure.
Instead, yardworks repackages other brands of timer, generally water timers, such as orbit or melnor and raindrip. And sometimes repackages other brands of outdoor timers.
Recommend folks stay away from timer-repackagers such as Yardworks, Timex, First Alert, and buy brand names that have clear customer resources.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Posted on Jun 05, 2013
How do I set automatic timer on AC1 Hozelock watering system?
incorrect operation. 1. Remove screws and back cover. 2. Insert two 1.5V 'C' Alkaline batteries. (Check + and - are correct.). IMPORTANT: Rechargeable batteries must not be used. 3. Replace batteries each season. (max 12 months use) MAINTAINING THE WATERPROOF SEAL 1. Ensure that rubber seal is positioned correctly. 2. Replace back cover and screw down tightly. 3. Repeat each time back cover is removed. HOW TO PROGRAMME THE TIMER There are two watering operations - Automatic and Manual. AUTOMATIC OPERATION Automatic ON 1. Turn dial clockwise to AUTO START at actual desired start time (e.g. To start watering each day at 15H00 you must set your AC1 when the actual time of day is 15H00). The timer has now memorised the auto start time until it is reset and will operate every day at this time. Use of manual ON or OFF does not cancel memory. 2. Turn dial anti-clockwise to: a) Chosen duration for once-a-day operation, or b) Chosen programme for all other watering frequencies (see table). The timer will now automatically run the selected program repeatedly until a new option is selected. GB 2 Automatic OFF Turn dial to Manual ON or OFF. If you wish to return to Automatic watering re-select the desired watering programme. NOTE your auto start time remains memorised until a new one is selected. Changing start time Turn dial clockwise to AUTO START at new chosen start time. Changing watering programme Turn dial to new programme. Do not turn dial to AUTO START unless a new start time is desired. MANUAL OPERATION Manual ON Turn dial anti-clockwise to ON. Water will flow for 60 minutes maximum or until turned to OFF setting. Note: After 60 minutes water shuts off. Knob will still point to ON and needs to be manually set to OFF or to desired number of automatic watering minutes. Manual OFF Turn dial clockwise to OFF. Note: Operation is only audible when valve opens and closes. To check that timer is working, switch to manual ON or OFF to hear valve operate. CONNECTING THE TIMER TO THE TAP Use supplied adapters if required. Tighten to ensure no leaks
Jun 25, 2018 | Hozelock Garden
DO YOU HAVE a manual for a woods e227659 TM-068-2 timer?
Woods TM-068-2
Indoor 7-Day Astronomic Timer
125V ac / 60Hz 15A / 1875W general purpose
8A / 1000W tungsten 500VA electronic ballast
15A / 1875W resistive 120V ac / 60Hz / 8,3A ballast
FEATURES:
• Up to 7 different programmable ON/OFF cycles, cycles repeat weekly.
• Programming fl8xibilify: u8hts fun on/off automatically at sunset/sunrise,
or at any programmed times you choose.
• ln Sunrise/Sunset programming mode, timer will automatically adjust the
programmed ON/OFF cycles to match current sunrise/sunset times.
• Timer automatically adjusts to daylight savings time
WARNING: TIMER IS INTENDED FOR INDOOR USE ONLY!
BEFORE YOU BEGIN PROGRAMMING THE TIMER:
This timer has in internal battery backup to save all programming.
  1. Plug the timer into wall outlet for 30 minutes to charge internal battery.
  2. After 30 minutes, unplug timer and press the RESET button with the tip of a toothpick or similar object to clear the memory.
TO SET THE CLOCK:
  1. Press SET. PRESS +/AUTO or -/RDM to set the current year.
  2. Press SET. PRESS +/AUTO or -/RDM to set the current month from 01 to 12.
  3. Press SET. PRESS +/AUTO or -/RDM to set the current date.
  4. Press SET. Daylight savings mode (DST) will appear on the bottom of the display. PRESS +/AUTO or -/RDM to set mode to either DST AUTO or DST OFF.
  5. Press SET. PRESS +/AUTO or -/RDM to set the current hour. To change between AM and PM, press +/AUTO or -/RDM 12 timers.
  6. Press SET. PRESS +/AUTO or -/RDM to set the current minute from 00 to 59.
  7. Press SET. PRESS +/AUTO or -/RDM to set the Astronomic function to your zone - North (nor), Central (cen), or South (sou).
  8. Press SET to view the sunrise time. To adjust sunrise time press +/AUTO or -/RDM. To go back to the default sunrise timer press ON/OFF.
  9. Press SET to view the sunset time. To adjust the sunset time press +/AUTO or -/RDM. To go back to the default sunrise timer press ON/OFF.
  10. Press and hold SET for 5 seconds to exit clock setting mode.
Note: The timer allows a maximum of 7 programmable ON/OFF cycles.
To program the first ON/OFF cycle: Press SET repeatedly to scroll through setting the clock mode.
  1. Press SET to display ON 1 setting.
  2. Press +/AUTO or -/RDM to select day or group of days you want for cycle 1. Scroll to select either every day, any individual day, weekdays only, or weekends only.
  3. Press SET. Set ON hour by pressing +/AUTO or -/RDM to scroll through and choose hour AM or PM, or Sunrise/Sunset icon for first ON setting. Note: To select Sunset or Sunrise for the ON time, you must scroll through all the AM and PM hours first. If you select Sunrise/Sunset as the programmed ON time, press SET to continue programming OFF setting.
  4. Press SET. Press +/AUTO or -/RDM to set ON minute from 00 to 59.
  5. Press SET to display OFF 1 setting.
Repeat steps 2-4 to program desired OFF time.
To program additional ON/OFF cycles: Repeat steps to create additional ON/OFF cycles (ON 2-OFF 2, ON 3-OFF 3, etc.) up to a maximum of 7 different ON/OFF cycles.
Press and hold SET for 5 seconds to exit programming mode. Note: During programming, if no button is pushed for 30 seconds, the timer will automatically return to standby mode. Press ON/OFF to cancel any setting.
Sun tracking technology: Timer adjusts automatically to changing sunrise and sunset times in sunrise/sunset mode is chosen for any programmed ON or OFF time. For example, if you program a cycle to turn ON at sunset and OFF at 10:00 pm, the timer will automatically adjust ON (sunset) time as sunset time changes throughout the year (and will always turn off at 10:00 pm as programmed).
IMPORTANT! REVIEW PROGRAMMED ON/OFF CYCLES: Press SET to advance through all programmed ON and OFF settings. Make sure there are no overlapping ON or OFF times. Stop at any programmed setting you want to change.
To operate timer: Press +/AUTO until AUTO appears in display. Timer must be in AUTO mode for programmed settings to operate. Plug appliance (such as lamp) into timer and plug timer into wall receptacle.
IMPORTANT: Appliance must be turned ON or be in the ON position before plugging it into timer.
SECURITY (RANDOM) MODE: To operate a plugged-in appliance (such as a lamp) in a random pattern while you are away, to simulate actual use: press -/RDM until RDM appears in display. In Random mode, plugged-in appliance will turn on and off at random, approx. +/- 30 minutes from the programmed settings.
To cancel Random mode, press ON/OFF until RND disappears from display. Timer will now function using your previously programmed settings.
DAYLIGHT SAVINGS (DST) MODE: If timer is in DST AUTO mode, clock time (and sunrise and sunset time) will automatically increase 1 hour on the second Sunday in March at 02:00 am and decrease 1 hour on the first Sunday in November at 02:00 am.
TO OVERRIDE THE TIMER: Press ON/OFF until desired mode is displayed:
ON: Programmed settings will be overridden; the plugged-in appliance will remain on
OFF: Programmed settings will be overridden; the plugged-in appliance will remain off
AUTO ON: Turns plugged-in appliance on immediately until the next programmed OFF time. Press ON/OFF until ON displays on the screen, then press +/AUTO and AUTO will display on the screen.
AUTO OFF: Turns plugged-in appliance off immediately until the next programmed ON time. Press ON/OFF until OFF displays on the screen, then press +/AUTO and AUTO will display on the screen.
RDM ON (Random ON): Turns plugged-in appliance on immediately until the next random off. Press ON/OFF until ON displays on the screen, then press -/RDM and RDM will display on the screen.
RDM OFF (Random OFF): Turns plugged-in appliance off immediately until the next random on time. On/Off times will vary +/- 30 minutes from the programmed settings. Press ON/OFF until OFF displays on the screen, then press -/RDM and RDM will display on the screen.
Consumer Support (800) 561-4321
www.colemancable.com
Dec 12, 2017 | Woods Hardware & Accessories
After I set my #055671 2-outlet timer to my turn on and turn off times, I cannot get the my lamp to turn on automatically. What setting should the timer be set on ?? Auto off, Auto on? or what?
There is no repair for defective timer.
I suggest setting timer programs, and then press clock button and timer returns to current time.
At this point the timer is operational, and then do not mess with manual override button.
http://waterheatertimer.org/How-to-program-Utilitec-0155671.html
Correct setting is either AUTO ON -or- AUTO OFF setting.
Auto ON, means lamp turns ON immediately and programming resumes at next set point.
Auto OFF, means lamp turns OFF immediately and programming resumes at next set point.
So you have to wait for time to arrive at set point to see if timer is working.
Troubleshoot from link above:
Check that correct time is set.
Check programming for conflicts and overlaps.
For example ON 8:00 pm Tuesday and OFF 10:00 pm All-days-of-week will cause timer not to operate as expected.
Test outlet with cheap circuit analyzer to ensure that electrical problems are not causing problem.
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Aug 29, 2011 | Hardware & Accessories
For GE- 15117, Mode acts as a controller called "an On or Off override..." "or sets events to Automatic or random" Random = a +/- program shift (that's understandable). You'd think...
I cannot make precise sense of your question.
However I agree, the manual for GE 17117 is not clear.
1) A number of folks are writing in about this particular timer, with same MODE problem as you.
Some folks, the timer skips over auto.
Some folks the timer just doesn't come on.
Facts are facts, some timers are busted on arrival.
But let's look at the problem from three different directions and see if it helps:
2) Steps from manual:
When you finish programming, press clock button to return to current time.
Next set MODE.
Press MODE button and timer enters override ON-OFF. Override reverses whatever program is operating at that moment.
Press MODE button again and timer enters RDM random mode, and lights turn on-off randomly.
Press MODE button again and timer enters AUTO >>> auto is correct setting that lets programs run.
Here's the trick: after setting MODE to auto, press clock button again and current time displays.
If timer will not perform these steps, then timer is suspect
If timer performs these steps, but programs won't work, the timer is suspect or programming is suspect.
3) Check programming for conflicts and overlaps that cause timer not to function 'as expected.'
Some timers skip over conflicting programs, some timers simply stay on, others stay off.
http://waterheatertimer.org/pdf/GE-15117-Manual.pdf
Example of conflict is event1 ON at 7am TU > but event1 OFF at 11pm All-days. Both event1 ON and OFF events must have consistent days >>> so change TU to All-days.
Another example is event1 ON 7am OFF 11pm TU >> but event2 says opposite, or has overlapping times.
I suggest folks make a schedule of programs before starting.
To review and change programs, start with current time showing in display: Press PROG button and scroll through event1 ON, event1 OFF, event2 ON, event2 OFF, etc.
Write down the events and make a chart.
Look for overlaps, and check for days of operation, and make sure each event ON has corresponding event OFF
4) If events are correct, and timer MODE button functions, but timer still doesn't work, the final suspect before calling the timer busted, is circuit problem. Use circuit analyzer on receptacle. Or plug timer into receptacle on different breaker and see if problem persists.
Dec 11, 2010 | GE Hardware & Accessories
I baught a 3-outlet timer yardstake #15137. why does it blink on all settings except the on at all times?
Your yardstake timer has photo-eye that automatically turns lights on at dusk.
And then lights remain ON until set-time expires, or dawn arrives.
Timer automatically turns off at dawn, no matter which setting, unless timer dial set to ON
Photo-eye has to be turned away from outdoor lights or lights will blink.
That's because outdoor lights cause photo=eye to sense it's dawn, and timer turns OFF >>> a moment later photo-eye senses it's dark, and turns lights ON again.
Thus the timer turns ON-OFF.
Test this by putting black tape over photo-eye, or turning timer toward dark area. Timer should turn ON and follow set-time on dial.
Have the timer set on Auto but lights are not on during the ON period. Also do I need to set times for all 7 periods?
No, you do not need to set all 7 timer events.
When event1 ON and event1 OFF are set, press CLOCK button to exit programming and save programs. Or press PROGRAM button and move to event2 ON and event2 OFF. Exit programming any time by pressing clock button.
http://www.intermatic.com/products/timers/consumer%20outdoor%20timers/digital%20timers/hb88rc.aspx
That being said, if events conflict with each other, timer will not operate.
For example event1 ON FR at 7pm and event1 OFF all-days at 11pm.
The days have to match for on-off times.
Another example event1 ON FR at 7pm and event1 OFF FR 11pm, but event2 ON all days 8pm event2 OFF all days 10pm. This overlap will cause timer to skip programs.
If timer is being used in random mode, timer programs cannot be closer than 1/2 hour apart.
When programming is done, press clock button to display current time.
Timer should be ready to go.
Manual is fuzzy at this point, and does not specifically say, but it appears that you only press MODE button when you want to set another mode beside auto.
I e-mailed Intermatic last week about this unclear spot because several folks are writing in about this timer not going into correct MODE after programs are set.
MODE must be set to automatic
Press MODE button once for manual override function
Press MODE again and RDM displays for random >> this is for lights turning on randomly when on vacation.
Press MODE button third time, and AUTO shows on display >> you want timer in AUTO for timer programs to operate.
Here's the trick ... after setting MODE to auto, press clock button to display current time
If timer will not enter AUTO, then timer is defective.
If Intermatic sends response that is pertinent to your question, I will post again on this thread.
Add a comment any time, and I will respond.
Dec 10, 2010 | Intermatic HB88RC - 7-Day Programmable...
How can we turn off the automatic start of Radio or CD setting?
The activating and deactivating of the 24 hour timer is via a toggle button, labeled "TIMER" on towards the right side of the top console. When the TIMER is activated, you will see a small clock symbol on the LCD display. While the unit is on, tap the TIMER button once. The clock symbol will disappear and the timer is now off.
Reactivating the timer is the same process (remember, the button is a toggle). Tap the TIMER button and you'll see the timer settings show up on the display (time on, time off, source, and volume). The little clock symbol appears again.
If you have lost your manual, you can download another one for free from this location:
http://www.retrevo.com/s/JVC+SD1000
Nov 17, 2008 | JVC FS-SD1000 CD Shelf System
Black and decker coffee maker
what type of coffee maker? does it have a model number?
Dec 11, 2007 | Coffee Makers & Espresso Machines
Honeywell oil radiator
Press the *power button* once to start the heater on high power, continuous run. If left at this setting, the unit will run continuously on high power (1500 watts, 12.5 amps) and will not shut off until the unit is manually turned off.
Press the *power button* again, to change to low power, continuous run, (900 watts, 7.5 amps) and will not shut off until the unit is manually turned off.
Set temperature:
Press the temp/timer button until the temperature icon blinks. Use the up and down arrows to set the desired temperature.
The temperature icon will stop blinking and the current room temperature will reappear after the desired temperature is set.
The heater will turn off and on to achieve the desired temperature.
Set timer: (auto off)
Press the timer/timer button until the timer icon blinks. The hour display will appear. The auto off icon will also appear.
Use the up and down arrow buttons to set the heater operation time between 1 and 10 hours. This function will activate once the timer icon stops blinking. The heater will automatically turn off whn the times runs out.
Set timer: (auto on)
Press the temp/timer button until the timer icon blinks. The hour display will appear. The auto on icon will also appear.
Use the up and down arrow buttons to set the heater start time between 1 and 10 hours. This function will activate once the timer icon stops blinking.
The heater will automatically turn on when time expires.
Hope this helps!
Sep 24, 2007 | Honeywell /KAZ HOME ENVIRONME HZ-705 7Fin...
Hardware & Accessories Logo
57 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
