Question about Home Security
Model S0500 wont open using factory code, gets 5 beeps all the time, what should i do?
Putting on the 5digit factory codes
SOURCE: Sentry Model 1610 Won't Open
I am a Safe Specialist i have been reading some of your problems and this should help there is no code if you have lost yours only the default code for the model 1610 the default code is: 77,22,09,11,64 try that if you havent changed it and with this problem with people not getting the handle open with the green light happening i suspect this is a issue with the lock mechanism i have had many of the same problems with people bringing them in when you get you safe open it and where the lock is put some lubricate on the lock regulary as the lock sticks and wont open if you havent done this then you cannot get it open see you local safe specialist and tell them what i have said and they may or may not be able to get your safe open i hope this has helped Rob Safe Specialist World.
Posted on Aug 21, 2008
SOURCE: factory code will not open model # DA3831 safe
i am a locksmith that has worked on several of these. The safe is manufactuered with three types of lock mechanisms 1. combo dial 2. digital 3. advanced digital the advanced digital is what you have there are no green lights on it. look at the manual carefully there are 2 seperate sections on the digital key pads yours will be the second.
Posted on Dec 18, 2009
  • 76 Answers
SOURCE: Need factory code for Sentry Safe Model 1610 -
If you need your lost combination, you must send a notarized letter stating you are the owner of the safe. The link below will tell you everything that you will need to get your combination back:
http://www.sentrysafeshop.com/Lost-Combination-Sentry-Safe-Combination-p/lost%20combination.htm
Posted on Jul 06, 2010
loxmith
  • 21 Answers
here is the customer service phone number for you. I am sure they will be able to help you. 800-828-1438
Posted on Jul 24, 2010
SOURCE: sentry safe, enter codes and nothing
These safe are easily opened by a good locksmith. So if you have items in the safe you need to get out a safe and vault tech could drill it open and repair it for a small fee. I really don't think it is the chip probably just a stuck solinoid.
Posted on Aug 08, 2010
I have bought a used red head safe. It's open but I can't get it to close. Also, I don't have a combination for it and I'd like to make up my own. Can you help me?
Most likely it will not close because the lock has been activated while the door was open. Probably need to take it to a locksmith.
Jan 03, 2017 | Home Security
How do I reset the keyless entry pad to unlock the doors on my 2006 ford five hundred
You can't reset it. They all come with a factory code (RKE Code). If you have the factory code you can add a second and third code of your own. If you have lost the factory code you can retrieve it by going to the Ford dealer. Secondly you can do it this way:
Location for key pad entery code; 2006 Ford 500. Need to pull panel off below steering wheel (I used a 9/32 socket) Then look for 3 10mm nuts, 2 @ top 1 on the bottom. if you are having trouble locating this box, its part of your fuse box (says pull on the cover) and your fuses are behind the cover. Once you have removed the 3 10mm nuts, look on the back of the box (CAREFUL NOT TO PULL ON WIRES TO MUCH) and you will see the 5digit code! Watch this you tube video.
https://www.youtube.com/watch?v=F8F_XFmNF00
I hope this helps.
Jul 12, 2015 | 2006 Ford Five Hundred
I need to reset my combination to my mesa safe
This safe was shipped with a factory Master Code of 1-2-3-4-5-6-7-8.
If you changed the Master Code you will need to use the code you changed it to.
Deleting your current User Codes:
Input * - * lock will beep twice
input 6-6-6-# lock will beep twice
Input current Master Code - # lock will beep twice
Input user number - # lock will beep twice (not user code, user number is which user number you want to delete 1,2,3,4 or 5)
Re-input user number - # light stays green for 3 seconds
Example: * - * - 6 - 6 - 6 - # Master Code - # - 5 - # - 5 #
This will delete user 5
Unsuccessful code change: five beeps, repeat the steps.
Changing User Codes: Code length can be 3 to 8 digits long
Input 4 - 4 - 4 - # lock will beep twice
Input Current User Code - # lock will beep twice
Input User Number - #
Input New User Code - # lock will beep twice
Re-input New User Code - # light stays green for 3 seconds
Example: * - * - 3 - 3 - 3 -# - User Code 2 - # - 2 - # -New User Code - # - New User Code - #
That example will change user code 2.
Unsuccessful Code Change: five beeps, repeat the steps.
There are other things you can do with the MSL-500 lock that comes on the MFL-2014E. You can change the master code, activate user codes, change user codes, delete user codes, set single user or dual user modes (dual user modes requires two user codes to be entered each time you want to open the safe, set the time delay.
The Mesa safe company has a website which does have the operating instructions for the MSL-500 electronic lock. A Google search of "Mesa MSL-500 Operating Instructions" would get you there quickly.
Oct 18, 2013 | Mesa Safes MFL2014E Safe Depository Safe...
My radio (clio) wont accept the code..it is right code...help...it allows u to enter code but still doesnt work
on many cars to unlock radio, you have to go or call dealership to find out how to put in correct code.if its the factory model. good-day !
Mar 09, 2012 | Cars & Trucks
Just put new batterys in safe . but safe will not stop bleeping what is the problem
Please follow these steps
Programming a user code
There are two ways to program a user code.
A 1. Press the Program key.
2. Enter the Factory Code. The green LED remains ON
while you enter the 5-digit user code of your choice.
After 5 digits are entered the green LED turns OFF.
(To enter a new User Code, repeat these steps.)
B 1. Press the red button inside the safe. The lock will
beep and the green LED will come on.
2. Enter a 5-digit user code.
Keep your new user code secure.
For your records, please copy it here:
____ ____ ____ ____ ____
Programming a password
2. Press it a second time.
3. Enter your 5-digit User Code. The green LED remains ON.
4. Enter the 5-digit Password of your choice (any combination
except 00000.) After 5 digits are entered, the green LED
turns OFF.
(To enter a new Password, repeat these steps. To erase the
Password, press Program twice, enter your User Code and then
enter 00000.)
Battery replacement
Below When old batteries are removed for replacement, your Password will be voided; only Factory and User Codes will work. To
reestablish your Password, follow the directions above under
Programming a Password.
Key override
If your electronic lock fails or you do not have any codes
available, you may use a key override to access this unit.
1. Remove the battery cover, disconnect and remove the
battery holder.
2. Insert the skeleton key (second set of keys provided)
into the key hole inside the opening for the battery.
3. Turn the key to the right.
4. Turn the four bit key to the right.
5. Open the door.
Signals
Your electronic-lock safe communicates by means of several
audio/visual signals.
Red (Error) LED + three beeps indicates
one of the following:
1. You have pressed Program key out of sequence
2. You have entered an invalid code or password.
3. You have let 5 seconds or more elapse between key entries.
Green (Proceed) LED + single beep occurs
1. After entering each digit of Factory or User Code, or
Password
2. After pressing Clear key
3. After pressing Program key
Green LED only
1. Comes on after you enter a valid code/password and
remains lit during the 4-second period in which the safe
can be opened.
2. Comes ON in the Program User Code mode after you enter
the Factory Code and remains lit until you have finished
entering a 5-digit User Code.
3. Comes ON in the Program Password mode after you have
entered your User Code and remains ON until you have
entered a 5-digit password.
Yellow LED
Indicates low battery and will typically not turn ON until
battery has been in use approximately two years or longer.
Your electronic lock automatically performs a low battery test
during each lock use.
If a �low battery� condition is detected the Yellow LED will
come ON and remain ON during each subsequent lock
operation. (The lock will continue to function in a Low Battery
state, until battery failure.) The Yellow LED will turn OFF only
after three consecutive Good Battery readings or after the low
batteries are replaced. (Note: If the new batteries are installed
in less than 60 seconds the Yellow LED may come ON and stay
ON during the first lock operation before it returns to OFF.)
NOTE: It is recommended you replace the batteries after two
years, or when the yellow LED remains on.
Jan 09, 2011 | Safe International Electronic Digital Safe...
Csw3607 sentry safe will not open. when i use my 5 digit code the red light beeps 5 times. when i use the factory code it does the same thing. Sentry has told me to take it to a locksmith and have them cut...
I hate to tell you, I just had this same problem on a brand new safe (x-mas present) and ended up having to crack it open. Unfortunately, from my extensive research on this problem on Sentry Safes it turns out that they use an encoded IC chip on the solenoid and if either a serial wire breaks going to the board or the IC chip fails, you get the 5 beep-of-death error. Needless to say, I'm thoroughly disappointed in Sentry and will discourage anyone from purchasing their products!
Dec 10, 2010 | Sentry Fire Safe - Safe - DS3607
Showing f90 code
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 08, 2008 | Frigidaire FEF352 Electric Kitchen Range
Home Security Logo
61 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
