Question about Twin-Star International Inc Beverly Media Electric Premium Oak-Finish Fireplace - -
I hear a clicking noise coming from my electric fireplace when the fire light is on. What causes this, and how can I fix it?
I don't have the manual so I haven't tried anything so far. It is a Twin Star International Electric fireplace Model # 23EF010GAA. Heater and all seem to work just fine, and there is just that noise when light is on.
The fireplace no longer produces a flame, i do not have the manual to trouble shoot and fix it
Gas Fireplace Manual - Gas Fireplace Instructions: Mendota ...
mendotahearth.com/gas-fireplace-stove-owners-manual.php
Mendota gas fireplace manuals and gas fireplace instructions for Mendota ...Mendota Gas Fireplace Insert FullView Model FV33i PF2 - Installation Manual
[PDF]FIREPLACE HEATER - Crane
crane-usa.com/assets/.../Fireplace_Heater_2013.pdf
by C Care - ‎Cited by 2 - ‎Related articles
your fireplace heater, please contact Crane. Customer ... This instruction manualapplies to the following models of the Fireplace Heaters product line: Color.
Nov 29, 2015 | Heating & Cooling
Tip
Flame Electric Fireplace Electric Fireplace Heat
Fireplaces have become the heart of the home, a warm place to gather with friends and family. Fireplaces turn any blank wall into a gorgeous focal point. A fireplace fits any decor and is a stylish addition to any room. Electric fireplace logs have improved greatly over the past few years and now days can look so good that they can fool people into believing that they are looking at a real fire, something which is especially true when you have crackling effect of fireplace logs, which aim to imitate the sound of a real fire.
Even though electric fireplaces do not generate flame, most provide the effect of a fire, which ranges from an orange light shined through plastic logs to simulate the appearance of coals burning, to an elaborate flame projection on the doors of some of the free-standing models. If you need a fireplace to heat your home you may want to consider a gas fireplace for better efficiency. If you need a fireplace for more decorative purposes a cheap electric burning unit might better suit your needs. The electric fireplace has experienced a quantum leap from those electric logs with reflective tin foil drums that adorned the hearth while the lava lamps were in vogue. An electric fireplace can add a great deal to a home, in terms of both form and function, and are also very effective at heating up a room.
Electric fireplace heaters simulate the look of a fireplace, but don't actually burn gas or wood like a traditional fireplace. Electric fireplace inserts simply fit into existing fireplaces and provide an artificial fire that creates the warmth and ambiance you want with just a flip of a switch. A modern electric fireplace insert does not require any type of venting system and many units are portable.
Even though these fireplaces do not generate flame, most provide the effect of a fire, which ranges from an orange light shined through plastic logs to simulate the appearance of coals burning, to an elaborate flame projection on the doors of some of the free-standing models. They plug into the wall, and can run on a "flame only" setting, or can be used as a heater, typically with 4,500–5,000 BTU (4,700–5,300 kJ), that can heat a 400 sq ft (37 m2) room. Since there is no real flame or combustion taking place, electric fireplace heaters release no toxic fumes or dangerous gases.
Everyone knows that a fireplace is about more than heat, especially when you're looking at a real fire, when one of the most entrancing things about it is the fact that you can see real flames. Most electric logs use a standard 110 volt power source, and come with various levels of flame of brightness. By choosing a really good set of electric fireplace logs, and particularly those which have a crackling effect and real flames, you can be assured that your fireplace will not be simply a unit in the room to make the room feel warm, but will be something that you enjoy looking at as well.
Electric fireside inserts are also a good option if there are issues with your hearth which make them a hazard with wood burning fires. Electric fireplace log inserts typically include an electric fireplace log set and an ember bed, and inserts are incredibly easy to install. Electric fireplace inserts are safe and clean. Most importantly whether you choose a modern electric fireplace or any other type make sure it will be most cost effective and suitable for its purpose in your home.
http://www.fixya.com/support/r3710316-portable_heat_flame_electric_fireplace
on Dec 24, 2009 | Heating & Cooling
Can I burn wood in a gas fireplace if the gas is not on?
No, the gas liner is not adequate for solid fuel, it won't draft properly,
Dec 08, 2014 | Home
Flame effect electric fire loud clicking noise
You need a new synchronous motor. This is the small motor which turns the flame effect rod. They are notorious for becoming noisy.
Nov 06, 2012 | ACE Dimplex (r) Compact Electric Fireplace...
My dimplex fireplace is too noisy. It's been that way from day one. We should have sent it back, I guess. Everything else is great about it but it sounds like a 747 jet!
I have been dealing with electric fireplace/heaters for several years, now. And for the life of me, I can not think of a thing that would cause a noise like a 747 jet plane. Could you be a little more specific as to which function of the fireplace cause this noise?
Look forward to hearing from you.
Apr 05, 2011 | Dimplex DGWH4031 Heater
We purchased a home with an electric start/gas fireplace...no owners manual...we turned on the gas with the key, flipped the switches on the wall and the fireplace unit...we see the ignitor clicking and a...
Not for sure what you have, but if you just purchased the house, there might be air in the gas lines. If it sat vacant and the gas was off, or if they has swapped meters/worked on gas lines? Try cycling the fireplace several times. Or look around for a small door opening or if it's mounted to the exterior wall, look outside for the supply line in. If you do find a valve in the closed position, be aware of the fact that it may be off due to a reason, and you may want a plumber/fire place tech to service it.
Oct 19, 2017 | Leisure HOMEPRIDE Electric Fireplace...
Rewiring Fireplace Electrical Insert
I looked up regular electral diagram for the different elements.
Dec 15, 2008 | Leisure HOMEPRIDE Electric Fireplace...
Chicagao electric fireplace heater doesn't work
MY HEATER NOT WORKING,BLOWER AND LIGHT COME ON NO HEAT
Oct 25, 2008 | Heating & Cooling
Electric fireplace 39EB364GRS
do a search on the web for model of fire place.
Oct 10, 2008 | Leisure HOMEPRIDE Electric Fireplace...
Twin-Star International Inc Beverly Media Electric Premium Oak-Finish Fireplace - - Logo
Top Twin-Star International Inc Home Experts
Donni Steen
Tom Chichester
Are you a Twin-Star International Inc Home Expert? Answer questions, earn points and help others
