Question about Canon Office Equipment & Supplies
What is the error code 1571 on a Varioprint 110
I am getting this code after initializing machine
    New Friend:
    Problem Solver:
  • 5 Answers
About what laser scannet you are talking about? This machime has no laser unit. I had the same error code while intallation of vp 110. And didn't find description of this code in service manual or up to date technical letters.
Posted on Dec 29, 2016
    Sergeant:
  • Canon Expert
  • 224 Answers
The scanner fails to reach the target speed of rotation 10 sec after the laser scanner motor reaches constant speed state. Causes - The laser scanner motor is faulty. The DC controller PCB is faulty. Remedy 1. Laser scanner unit, DC controller PCB Try replacing the laser scanner unit. Is the problem corrected? YES: End. NO: Replace the DC controller PCB.
Posted on Dec 10, 2014
Serial number need to be enterened KONICA C650
Notes:
1. When replacing the NVRAM or the EEPROM board, if the parts are replaced with used parts, the License Management error condition cannot be resolved by performing the repair operation.
In this scenario, Initialization would then be necessary and support must be contacted.
Additionally, if both the NVRAM and the EEPROM board are replaced, Initialization will be necessary.
IMPORTANT: Perform the Repair Procedure first, then the Initialize procedure. If initialization is required, collect the following information before calling support:
  • If i-Option was ever licensed on the MFP and if the additional 512MB of memory was ever installed at any time
  • The firmware level prior to the machine being upgraded to version 88 (bizhub C353 and bizhub C650 series models only)
  • If the machine ever had firmware version 85 or 86
  • A history of recent NVRAM or EEPROM board replacement
  • Obtain a machine Management List and have it ready to attach to the ticket.
  • A screenshot of the message returned from the LMS if "Repair" was unsuccessful
  • A "Request Code" from the MFP and the S/N must be obtained in order to start the "Initialization" procedure (see attached "Obtain Request Code" and "Initialize")
2. Make sure to enter the MFP Serial Number, Repair Demand Code and the Request Code in uppercase letters when entering data in License Management Server online.
3. Version 88 firmware refers to the bizhub C353 and bizhub C650 series models. Other models have the correct firmware from factory.
4. To view a PDF, you may need to download a free copy of Adobe Reader®.
Aug 19, 2017 | Konica Office Equipment & Supplies
Toshiba E studio 182 power initialization problem
On startup, if the machine shows a wrench-icon, press down "8" and "clear/stop" key simultaneously to show the exact error-codes. A list of detailed error-codes can be found here: http://officeimagingsystems.com/id175.html
Jun 27, 2014 | Toshiba E-Studio 182 Copy Machine
Error code c4
It's either the micro-switch that trigger the needle positioning gear is jammed, and or the plastic gear probably missing some tooth that fails to triggers the micro switch to initialize when you turn on the unit.
Mar 18, 2014 | Singer 5500 Fashion Mate Sewing Machine...
I have a problem Taskalfa 250ci eror code c0640 I think at Hdd problem. But I don't know how to hdd format
Maintenance
item No.
U021
Memory initializing
Description
Initializes all settings, except those pertinent to the type of machine, namely each counter, service call history
and mode setting. Also initializes backup RAM according to region specification selected in maintenance item
U252 Setting the destination.
Refer to *1 of the maintenance mode item list about the item initialized.
Purpose
To return the machine settings to their factory default.
Method
1. Press the start key.
2. Press [EXECUTE] on the touch panel.
3. Press the start key. All data other than that for adjustments due to variations between machines is initial-
ized based on the destination setting.
4. Turn the main power switch off and on.
For errors occurred, turn main power switch off then on, and execute initialization.
Error codes
U024
HDD formatting
Description
Initializes the hard disk.
In addition, the following settings are also initialized by initializing the hard disk.
System menu (user login administration, job accounting, address book, one-touch keys and document box
etc.), shortcuts and panel programs
Purpose
To initialize the hard disk when replacing the hard disk after shipping.
Method
3. Press the start key to initialize the hard disk.
Description
Codes Description
01 Configuration initialization error
02 Counter initialization error
20 Engine initialization error
40 Scanner initialization error
2JZ/2JX/2JV/2H7-5
1-3-23
Apr 15, 2013 | Kyocera Taskalfa 250ci Color Copier...
Code to initialize ami rowe jukebox
For full initialization, in service mode, press 3 to enter init. sub menu, type 0 for full initialization. Press popular, then put switch in normal position and initialization will begin. You can still select and play discs while initialization is in progress, providing you select from cd's already finished. The machine will continue initialization after selections are finished playing.
Feb 02, 2013 | Wurlitzer Jukebox CD Player
When recevie fax their is nothing document but error code coming 242
This link covers all error codes. http://h10025.www1.hp.com/ewfrf/wc/document?docname=buu02549&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN#Error232
Error Code: 242 Definition
The remote fax machine is attempting to receive instead of send. Both machines have attempted to start a reception at the same time. On many fax machines, it is possible to accidentally initiate a fax reception in the following cases:
  • There is no paper in the machine.
  • The paper is not correctly loaded and the document sensor cannot sense it.
Solution
Contact the sender to make sure that a document is ready and correctly loaded in the sending fax machine. Also make sure that the remote machine is attempting to initiate a transmission and not a reception.
Feb 28, 2011 | HP Computers & Internet
I have a te-2200 but cannot get past the initialization. Machine initialization procedure. I keep getting a e004 error
Which MAC code are you typing in? Have you used the table in the dealer manual to work out the correct code for your country and programming needs? If you need the dealer programming manual, there is one here: http://the-checkout-tech.com/manuals/cashregisters/Casio_TE-2200_and_TE-2400_dealers_manual.html
Jan 10, 2011 | Casio Parts Cash Register PC Desktop
Delet code
It's an calibration error caused in the optics section. Make sure there is nothing on the scanner glass but the cover itself. Turn the power off, wait 30 seconds and turn the power back on again.
Do you hear any grinding noises when the machine is initializing?
Aug 08, 2008 | Sharp AR-5316 Advanced Digital Imager...
C118 FUSER NOT INITIALIZING/COME 0N
ummm fuser don't get initialized in these machines they either come on or they don't if it doesn't come on it usually means that 1. the bulbs blew
2. the thermistor or thermostat are bad
3. the connector to the machine has bad contacts
so your best bet is to just get another one
regards, Nick NCXI.com
Oct 15, 2007 | Xerox CopyCentre C118 Copier
361 people viewed this question
old marine
old marine
