Question about Proscan 40" Class 1080P LED HDTV - PLED4011A
What is the Comcast remote code
All the codes listed in the Comcast Instruction Paper
  • Proscan Master
  • 1,249 Answers
Comcast has a web page with the newest codes. If the codes listed won't work, the page tells you how to code scan.
start here:
http://customer.comcast.com/remotes/ Comcast Remote Codes Program Your Comcast Remote Control
Posted on Dec 08, 2014
Remote code for rca 50 in lcd 50lb45rq
For Universal Remote Control brands listed below, please use accompanying codes and refer to your Universal Remote Control UserManual for basic Instruction for changing TV code to operate the TV model.
Codes for DIRECTV: 0178, 10178
Codes for Time Warner Cable: 0178, 10178
Codes for Cox Communications: 0178
Codes for Comcast: 10178
Codes for Dish Network: 627
Codes for Fios Verizon: 0205, 0057, 0493, 0775
Jun 30, 2012 | Televison & Video
Need Sansui C-1000 Audio Amplifier Comcast 5-digit remote code.
Hello
Try these linkd to download the code list [5 digits] for Comcast. copy and paste the link into your browsers' address bar and press enter, if you do not get it as a link from here.
digitalnow.comcast.com/Contents/DTARemoteGuide.pdfSimilar
www.comcast.com/.../Digital.../Digital.../remotes/Remote_M1067BX...Similar
http://www.dataentryjobs.us/67948.html
www.ua.edu/.../aux.../trouble-shooting-and-remote-programming.pd...Similar
http://www.dslreports.com/forum/r20052833-Comcast-remote-setup-question
Feb 28, 2012 | Audio Players & Recorders
Comcast Remote Codes for a RCA L32HD31R LCD TV Also Panasonic
Hi Attychase,
Comcast actually has several different remotes for their different set-top boxes and the remote codes aren't always the same. They list all of their current remote devices on the following page. If you click on view manual it will give you a list of remote codes.
http://www.comcast.com/corporate/customers/customer_support/remotes.html
Hope this helps.
Nov 20, 2009 | RCA L32HD31 32 in. LCD HDTV
No Comcast remote code
If you look at the instruction sheet for your remote under 'searching for your code' you will see:
SEARCHING FOR YOUR CODE
If your home entertainment device does
not respond to the remote control after
trying all of the codes listed for your
brand, or if your brand is not listed at all,
try searching for your code.
For example, after trying all of the
codes for your TV, you still cannot get
the remote control to operate your TV,
then:
1. Turn on your TV.
2. On the remote control, press TV
once. Then press and hold Setup
until the TV key blinks twice, then
release Setup.
3. Enter 9 - 9 - 1. The TV key will
blink twice.
4. Aim the remote control at the the
TV and slowly alternate between
pressing Power and TV.
Stop when the TV turns off. A
working code has been found.
NOTE: In the search mode, the
remote control will send IR codes
from its library to the selected device,
starting with the most popular code
first.
5. Press Setup once to lock in the
code.The TV key will blink twice.
6. To search for the codes of another
device, repeat steps 1 to 5, but
substitute the AUX key for the auxiliary
device you are searching for
Nov 03, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Need codes for remote control access to go with Comcast hd adapter remote. Only 2 listed with remote from Comcast: #'s11723, 12066 Comcast remote will not control TV
If you look at the instruction under 'search for your codes' it will tell you how to scan all the code until you find the one that will work. Down load the manual here for your remote:
then:
1. Turn on your TV.
release Setup.
blink twice.
first.
Nov 02, 2009 | TruTech PVS31170S1W 17 in. LCD Television
My grandmother has a 42 inch sylvania lcd tv need remote code for
Usually universal remotes have a auto select option, Check for the remote code online, go to gogle and search for universal remote codes
Jul 12, 2009 | Televison & Video
Remote Codes for Comcast remote
Here is where the comcast remote codes (3 in 1) silver are listed:
http://www.comcast.com/remotes/tvcodes.html
Just to be sure, here are the different Comcast remote devices listed on their website. Click on one of them, and a 2-page PDF will open. It will explain how to load your code, and on the second page, list all the codes for your different electronic equipment.
https://www.comcast.com/corporate/customers/customer_support/remotes.html
Merry Christmas.
SJCounterT
Dec 25, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
Progamming Comcast remote
Go here, it has a viewable manual for the comcast remote and a list of codes. There is also a way to search codes listed. Haven't tried yet, but it can't hurt trying!
http://www.scribd.com/doc/202024/comcast-dvr-remote-manual
Sep 08, 2008 | Sanyo DS20930 20" TV
Need code for my comcast remote
Comcast says that if the codes listed in the instruction brochure provided with the remote (10236 and 10463 for Broksonic) don't work, you should code 991 into the remote and then press the CH+ button repeatedly in order to search through the library of installed IR codes until the TV turns off, then press SET once to lock the code. This worked fine for me, although I must admit I had to press the CH+ button well over 100 times until I came across the proper code in the library to turn the TV off. Unfortunately, there is no way to know what 5 digit code this represents so that if I need to reprogram the remote in the future, I will need to go through the same time-comsuming process all over again.
Feb 20, 2008 | Broksonic CTSGT8118T 13 in. TV/VCR Combo
Comcst remote control code not working
look on the label on the back of your Emerson TV. Read the small print and see if there is a possible different manufacturer that actually made the Emerson TV. Just because it says emerson doesn't mean emerson made it. Also if no luck there try the UL listing code and search that code to the UL listing website. That may help also.
C-Dog
Feb 12, 2008 | Emerson EWF2703 27" TV
Proscan 40" Class 1080P LED HDTV - PLED4011A Logo
463 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
