Question about Bosch Ovens
Need troubleshoot on model HSB745256A bosch
Running off trying it reset clock seems to be working but lights not functioning no het
Bosch single oven has clock function but when I reset it goes to military time
Never heard of Military Time unless you mean 24hour clock in which when the power is interrupted or the clock is reset, that is the default setting.
Jun 18, 2017 | Bosch Ovens
When we reset the clock after a power outage, the clock runs fast now almost a minute in 30 seconds. Bosch HBL5750
Advise manufacturer; may give you a warranty on this part even after it has expired because of nature of the problem.
Mar 08, 2015 | Bosch HBL5750UC Electric Oven
I have a Bosch built in oven and don't know how to set the time on it
turn the oven off at mains for a few secs. When you turn it on the display should flash 0.00 or 12.00. Press the clock button once ( don't hold it in) use the + or - to set time. Once time selected don't press anything else after a few secs the oven will register and hold you selection.
Apr 03, 2013 | Bosch "27"" Single Wall Oven 500 Series -...
My bosch oven - HBA 13B250B is not displaying the clock real time any more. The oven still works. I can't find my instruction manual. Any ideas how to reset the clock
To change time on your Bosch oven, please do the following:
1. Press the clock icon (above the MINUS (-) button repeatedly until the clock icon on the display illuminates.
Please note: There are 4 illuminated icons on the display above the time. There are 3 which have clocks on them. You need to make sure the 4th icon (on the far right) is illuminated on the display.
2. Use the "+" and "-" buttons to set the clock to the correct time.
Once you have set the correct time, the oven will return the displaying the time and the illuminated clock icon will disappear. You do not need to press anything to confirm the time is set.
If you are still having difficulty, please post back for further assistance.
Regards,
BElectric
Dec 31, 2010 | Bosch Ovens
Oven cuts out as soon as it reaches temperature
not expert on bosch but sounds like cooling fan not working, either fan defective or cut in themostat not working.
Jul 22, 2010 | Bosch Ovens
Bulb blown and now fan is not working
When you changed the bulb did you turn the power off at the mains if so then you need to reset the clock on the front panel the fan will not work but all other functions will look in book it will tell you clock reset.Hope I helped.
Good Luck.
May 07, 2010 | Bosch HBN 730520B / 730560B Electric...
Dacor ecs230 clock button is not working
there may be a backup battery built in to this unit to keep the clock running in case the power goes out. depending on the age of the unit, it may need to be replaced. the battery size and number as well as it's location should be in the owner's manual.
Aug 25, 2009 | Dacor ECS230 Epicure Electric Double Oven
Bosch oven HBT346 - how do I reset the clock?
Hi after a power cut my Bosch cooker clock is flashing but I cannot reset it as have no instructions - any ideas? Thx
Apr 15, 2008 | Bosch HBN 442 / HBN446 Electric Single...
Dacor ECS230 Wall Oven Control Panel Time functions not working
Try turning the power off at the breaker for 12 hours.
I had the same problem, tried turning the power off for a few minutes but that did not fix the problem.
Leaving the power off overnight seems to have fixed it.
Nov 09, 2007 | Dacor Millennia MOV130 Electric Single...
Retractable function selector knob stuck
facia panel most probably need removed, not to bad a job, but oven need to come out... go to bosch, web site...search parts finder with your model , and you will see an exploded diagram, this may help yet you get an idea on how it comes apart.. failing that call an engineer...
Jul 02, 2007 | Bosch HBN 560570B / 560550B Electric...
Ovens Logo
87 people viewed this question
Top Bosch Ovens Experts
ashburton
Oloyede Monsuru
Are you a Bosch Oven Expert? Answer questions, earn points and help others
