Question about Tracrac 2003 Chevy Silverado - Standard bed approx. 6 1/2 ft. - T-Rac Truck Bed Rack
My 2003 chevy Silverado oil pressure gadge went to 0 when I was driven could I have blown the motor. it did stop running and died on the highway!!! thanks for any advise.
    Sergeant:
  • 248 Answers
Oh yes. unfortunately it does not take long for the engine to lock after the oil pump stops working. did you notice how long it was since the gauge dialed zero until the truck died?
Posted on Dec 19, 2014
Done an alt. change after doing a tune up truck ran than just shut down now will not start
Truck ' DIY Forums
www.diyforums.net/truck-2418/
My 2003 chevy Silverado V6 truck turns over but will not start..it acts lik. ... iS IT HARD TO REMOVE AN OIL PAN ON A 4.3 VORTEC S-10 PICK UP TRUCK ...silverado 1500 ext. cab. my problem is while driving on the highway my truck ... mytruck then took off the terminal to see if the alternator was work and now i have no .
Chevy Silverado and GMC Sierra Stalling Problem - Car Forums at ...
forums.edmunds.com > GMC > GMC Sierra 1500
Apr 4, 2008 - 30 posts - ‎22 authors
I can feel the truck hesitate or bump while changing lanes on the highway (70-80 MPH) if it ... Now it idles ... My truck has a 4.3 with automatic. trucks runs great after about a hour it .... It will idle and drive just fine, but will simply shut down. ... the not firing problem, but shuts off after it finally decides to start. Chevy Silverado and GMC Sierra Gasoline Engine ...
Jun 14, 2010
Chevy Blazer Fuel Pump and Pressure Regulator Problems
Mar 10, 2010
Chevy S10 - GMC S15 and Sonoma Stalling/Dying ...
Dec 14, 2007
Silverado starting problem...
Nov 15, 2007
More results from forums.edmunds.com
Dec 26, 2015 | 2004 Chevrolet Chevrolet Silverado 1500...
Location of oil pressure switch on 2003 Chevy silverado 4.3 liter
The sensor should be near the distributor on the back of the intake.
Feb 17, 2014 | 2003 Chevrolet Silverado 1500
2001 Chevy Silverado, 5.3 had only 5 pounds oil pressure, replaced sensor, still 5 lbs of pressure, replace crank driven oil pump, 0 pounds pressure, pickup tube good, o-ring installed correctly on pickup...
remove the pump and the cover off the gears
fill the spaces of the gear teeth with Vaseline or clean grease
this is priming the pump so that a vacuum is created to suck up the oil
new pumps will not be primed
the grease /Vaseline will dissolve in the oil and will not cause any problems
Jan 28, 2018 | Chevrolet Silverado 1500 Cars & Trucks
03 Tahoe oil pressure gague went from 80+ to 0 but runs fine
Oil pressure guage is generally for the engine instead of the transmission. Probably a bad sending unit or gauge. Most commonly it is a bad sending unit or broken connection between the dash and the sending unit mounted on the engine.
Mar 01, 2013 | 2003 Chevrolet Tahoe
1993 chevy pickup z 71 driving down interstate and check gauge light came on and oil presure dropped to 0. Truck died and cant start again
It could be the oil pressure sending unit, or the engine could really have no oil pressure.
If the oil pressure dropped to zero at highway speed, I would expect the engine to lock up or at least make alot of noise.
You may have to tow it home and check the oil pressure with a mechanical gauge, or replace the sending unit to see if the gauge on the dash reads pressure.
The fuel pump gets power from the pump relay at startup, then runs off power from that oil sending unit when the engine is running.
Dec 19, 2012 | Cars & Trucks
Just started up my 2003 chevy and my oil gauge went to 80
the oil sending unit could be out or the pressure guage is malfunctioning is the service engine light on?
Jan 11, 2010 | 2003 Chevrolet Silverado 1500
Changed oil pressure switch,still no oil pressure
The fuel pump on that model runs through the oil pressure switch so that if the truck looses oil pressure,It kills power to the fuel pump to prevent engine damage.you need to find the cause of the low oil pressure reading(possibly a bad oil switch).That would be the cheapest place to start,or have it checked with a mechanical gauge.Good luck,
ChevRev
Mar 30, 2009 | 1999 Chevrolet Silverado 1500
I have a 2005 chevy silverado 1500 2wd 5.3. my
Check the wire behind the guage.If not tight it will make the hand bounce.
Mar 18, 2009 | 2003 Chevrolet Silverado 1500
Tracrac 2003 Chevy Silverado - Standard bed approx. 6 1/2 ft. - T-Rac Truck Bed Rack Logo
117 people viewed this question
Top Tracrac Boating Experts
Lawrence Oravetz
Mike
Are you a Tracrac Boating Expert? Answer questions, earn points and help others
