Question about Measuring Tools & Sensors
Rc sensor outside will not transmit 4-ld3091-t
New battes
    New Friend:
  • 4 Answers
Try physically taking your inside unit outside, and replacing the inside unit batteries as close as possible near the outside unit. Once the transmitter has found the signal, it should lock on and continue to work. Good luck.
Posted on Dec 22, 2014
The indoor temp on my acurite model 02086 weather stn. constantely reads 26c how do I get it to read the correct indoor temp?
The manual of unit will tell you how to change reading from Centigrade to Fahrenheit. Read it carefully for details.
Oct 02, 2016 | Measuring Tools & Sensors
Why is there a red blinking light on outside sensor? This is only 2 weeks old and new batteries were put in then.
The red blinking light, I believe is indicating the outside sensor is transmitting the outside temperature data to main weather station unit.
Jun 19, 2015 | Measuring Tools & Sensors
Full battery, but car loses power after just a few seconds
maybe your batts are crapping out, have you tried a new batt? sometimes the speed controler boxes get burnt out also
Mar 23, 2013 | Exceed-RC 1/10 Scale Exceed-Rc SunFire...
Auriol 4-LD3091 weather station will not pick up sensor
I had the same problem and gave up on the unit for a while, then I had another attempt and found this worked for me. Take the batteries out of both units (receiver and outside sender) then reinsert the batteries BUT put the batteries into the outside sender unit FIRST, this seems to make the difference as when you then put the batteries into the indoor base-station it detects the outside temperature signal immediately as it starts to set itself up .
Aug 18, 2012 | Measuring Tools & Sensors
Have an old chorotherm III and a new T8601D2019 chornotherm IV, wire designation for the first is W,G,R,RC and Ywith R/RC jumper, wire designation for the new one is C,OT,OT,R,B,W,Y,O,G, OT goes to outside...
Hi, all you need to connect are Y to yellow for cooling, w to white for heating, G for green is fan, R to red for hot. If you don't have RH and RC to jumper on the new stat, don't worry, just connect R to red. B and O would be used on a heat pump reversing valve, C is for common back for 24 volts which you did not use before, and OT's are all for out side temperature sensors if you had them. Best of luck,
Shastalaker7
Apr 10, 2010 | Honeywell Electronic Programmable...
I tring to change thermosat I can not remeber what color go where
Typical Thermostat Wiring for 4 or 5 wire Heat/Cool Thermostat (not heat pumps)
4 Wire Termostat
R = Red One Side of 24 volt Transformer
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
with one transformer for both units
Rc One Side of 24 volt Transformer
Rh Jumper Rc to Rh
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
With 2 transformers one for indoor unit
And one for outdoor unit
Rc = Red One Side of (outside) 24 volt (outside transformer)
G = Green Blower (outside transformer)
Y = Yellow Cool (outside transformer)
Rh = Blue One side of (inside) 24 volt (inside transformer)
W = White Heat (inside transformer)
COOLING ONLY Thermostat
G = Green Blower
Y = Yellow Cool
HEATING ONLY
R or Rh One Side of 24 volt Transformer
W = White Heat
Feb 09, 2010 | Heating & Cooling
How do you wire a honeywell round mechanical thermostat
What are you trying to wire up?
4 Wire Termostat
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
Rh Jumper Rc to Rh
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
G = Green Blower
Y = Yellow Cool
HEATING ONLY
W = White Heat
Feb 09, 2010 | Honeywell CT87B ROUND HEATING&COOLING...
Trying to figure out thermostat wiring diagham on a split system
4 Wire Termostat
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
Rh Jumper Rc to Rh
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
G = Green Blower
Y = Yellow Cool
HEATING ONLY
W = White Heat
Jan 05, 2010 | Heating & Cooling
Outside a/c unit hasnt powered on yet and I want to make sure my RH and RC wires are correct.
Connect the red to RH
Go down to the furnace and look at the circuit board and note what color's go where. Most units only use 4 wires.
Should be
RED to RH
YELLOW to Y
WHITE to W
GREEN to G
Then from there two wires go to condenser outside. And they connect to Y and C on the board. Most of the time Red and White from outside. Don't get confused with Red coming from thermostat. Let me know Ken
Apr 26, 2009 | Heating & Cooling
Measuring Tools & Sensors Logo
252 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
