Configure the 3COM to direct all incoming 3389/TCP traffic to 3389/TCP on the "private" IP-address (192.168.xx.yy) of your server.
Configure your server to "allow" Remote Desktop connections, and add the ID/password details that will be allowed to login to your server.
If you are using AtomicTime and an IP Filter like Peer Block make sure that you allow the IP address 132.163.4.103 for the default NIST time server http://www.nirsoft.net/ - Freeware Utilities from Nir Sofer including my personal favourites USBDeview and RegFromApp
This problem "cannot connect to your server" generally comes when the content your are querying for is either already deleted or u r not allowed to view that content.you can not view the other contents on the same link. this problem also occur when there is no server running at that time u r querying.
You just need to report this problem to the site administrator . this will surely help your question.
Allowing multiple access to a server desktop is a large security issue !
Port 80 is a common port used for a variety of applications so common access would be possible from multiple clients.
However games have a different set of ports that are required. Using port 80 for games is asking for problems.
You should set the security policy for the ports your game actually requires.
The firewall will also have to be configured.
Router configuration is another key area for running any form of game server again with the correct port forwarding set up for the game in question
I have a WHS server fo rbackup and media streaming and an SBS 2003 regular server for games (Halo) I followed the guide that came with the server component of the game to fully understand what was required for the ports etc.
Ideally you should also be on a fixed IP from your ISP too.
If your ISP does not allow servers you may find that high traffic is throttled by the ISP end.
With a 5mb x 800k high speed connection I can sustain 8 computers internal and another 10 external before lag issues kick in. My ISP does support servers and I am on a fixed IP with COGENT pipe as primary
Note also that I have to ensure than none of the internal computers are running bandwidth intensive apps such as torrents toolbars etc. All internal machines are also CLEAN with regular security scans and such as any machine having a security issue could be prone to extra bandwidth usage.
As you are running a server the info above should not be too confusing and easy to follow.
According to this site http://www.argecy.com/xtnd100s.html it it supports the use of HP's JetAdmin/Web JetAdmin utility which will allow you to configure the IP address as well as other features.
"Features such as full support for HP JetAdmin/Web JetAdmin"
Utility located here: http://h20338.www2.hp.com/Hpsub/cache/332262-0-0-225-121.html
That same site also has this information about the ExtendView utility which may help you as well.
TROY LAN Administration Tools
ExtendView - 32-bit utility allowing most versatility and functionality
available in network printing. Ability to view and configure print servers
from unlimited number of views and quick and easy Windows IP address assignment
are 2 key benefits. Features such as bulk configuration allow configuration
changes for multiple print servers with simple steps. Save and restore
feature allows a standard configuration to be saved and later recalled
to restore same configuration
WebView - web based configuration tool allows complete status and configuration
changes simply by typing the print server's IP address into a standard
web browser
NetworkAlert - specialized Windows printer error utility providing proactive
notification of printer problems through the use of SNMP traps
ExtendNet Connect - serverless (peer-to-peer) printing for Windows 95/98.
Excellent tool for small businesses and remote offices
ExtendNet Connect NT - performance enhanced port monitor helps to improve
the speed of data flow to the printer
well it seems like you're not allowed to view pics from some websites due to command given to your server. you will need to check with your administrator.
You either hold the go button until the lights flash and it will give a printout or just press the start a couple times for a printout that also gives the print count.
Here is Apple's definition of the error."kLSServerCommunicationErr -10822 There is a problem communicating with the server process that maintains the Launch >Services database.". Have you repaired permissions? Are you sure this software is Mac compatible for your Mac be it Intel or Power?
Check the settings on your "Pop-up Blocker", they may be set to high. You may two of these running, one in your email server and one in your anti-virus program that is installed on your computer.
