Question about Coffee Makers & Espresso Machines
How to fix home right steam machine - Coffee Makers & Espresso Machines
  • 691 Answers
Please add more detail about what is wrong with the machine
Posted on Dec 14, 2014
My Titanium leaking water. Under it
The steam valve assembly that the steam knob on the right hand side connects into is probably faulty. When you're steaming if you hear hissing coming from behind the knob then this indicates the connections into this assembly are leaking steam, and also hot water, which is why you're getting puddles under the machine. You can get a replacement steam valve assembly that fixes some issues with the original (part code SVM-17, available from www.partsguru.com) and will prevent the leakage, or you could simply try opening the top of the coffee machine and removing the tube that runs from the boiler into the steam valve. It has two o-rings that provide the seal where it connects into the steam valve assembly, and if you lubricate these with a food grade silicon lubricant it may fix the problem. My Gaggia is 7 years old so I decided to replace the whole assembly which costs about $50 and that solved the problem completely.
Apr 04, 2011 | Gaggia Titanium Espresso Machine
The steam nozzle has broken
Yes you can but it is very hard to get inside the front of the machine if the tube has come off in the front panel, if it has come off one of the solinoids in the right hand side of the machine it is easy to put back on also check that the steam nozzle is not blocked with old milk it will cause the pressure to blow off the tubes
Jun 26, 2010 | Jura Capresso Impressa S9 Coffee...
Problem with Cimbali M29 steaming wands
Check the water level, if you remove the top panel you will notice that the steam valve are connected at different heights on the boiler. If the machine has the silver probe remove it and clean.
Aug 04, 2009 | Coffee Makers & Espresso Machines
Saeco Odeo Giro Plus dripping steam wand
I don't know any of the suppliers in the UK, but yes the problem can be fixed at home, it is very easy to replace the steam valve, just make sure that you get the complete valve(body and tap rod). Try this site they might ship the parts to you (saecoparts.com)
Jun 09, 2009 | Coffee Makers & Espresso Machines
Saeco Magic Comfort Plus still producing steam in "off" position.
This may be something you can fix. It depends on your comfort level with mechanical repairs. You probably need to replace some o-rings in the steam valve. Don't keep trying to brew or steam because leaking water or steam inside may cause an electrical short. Decide if you want to delve into the repair, or locate a repair center near you. I could put you in touch with some.
Mar 18, 2009 | Saeco Magic Comfort Plus Espresso Machine
Water leaking from the group
You can buy a service kit for your machine at www.theespressoshop.co.uk and that contains all replacable gaskets and washers and gives you an exploded diagram and sachet of grease and descaler to get your machine back in as new working order. The service kit you require is the "old group service kit" and is about £20. If you go to the website above and click on the la pavoni machine on the right hand side of the home page it will give you the full parts list.
All the best
LaPavoniBoy
Feb 18, 2009 | La Pavoni PC-16 Espresso Machine
Water from steam nozzle
I purchased a Talea Ring in February this year and have exactly the same problem
Jun 05, 2008 | Saeco Talea Giro Espresso Machine
Krups 867 boiler steam leak
Save yourself the trouble, buy a $1.99 frother at Ikea.  Makes the cleaning process easy - that's what I use at home, never used the steam wand on my machine.
To use the frother, just heat up the milk and froth away.  Pretty easy.
Nov 20, 2007 | Krups Caffe Bistro 867 Espresso & Coffee...
PUFF OF STEAM,CONDENSATION,GRINDS LONGER
The steam and leaking in the upper right corner turned out to be a leaky valve. I may have been able to fix it by just replacing the O-rings. However, the only place I found to get the right rings was in the kit to replace the steam valve assembly.
Aug 31, 2007 | Saeco Vienna De Luxe Espresso Machine
Coffee Makers & Espresso Machines Logo
37 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
