Question about Microwave Ovens
Hi my whirpool akp 206/lx fan oven reads ---c and won't turn on cant find this error code anywhere ? and whirpool want me to pay 130 as just outside warranty only 15 month old. Would appreciate any advice )
3 Suggested Answers
walesarumi
  • 6993 Answers
SOURCE: My microwave oven isn't heating my food.
Investigate these three areas if your microwave won't heat
Power Diode
A diode is an electronic component that readily passes current in one direction only and blocks the flow of current in the opposing direction. If your microwave's diode has become defective, your microwave will not heat. Test the diode to determine if this is the cause of your problem. Replace it if it is defective.
Testing a diode
NOTE: Before you test your diode, make sure your microwave is unplugged, and that you discharge the microwave's capacitor.
Whether it is shorted or open, a defective diode will most likely show some sign of defect. Defective diodes will usually emit an electrical burning smell, signifying its defectiveness. Also, it may have split in two, or it may exhibit a burned crack, or possibly even a blistered spot.
A shorted diode is indicated by a loud humming noise from the high voltage transformer, and no heat produced when a cook cycle is initiated. Whereas little or no heat produced in your microwave, with an absence of a humming noise is indicative of an open diode. In either case, the diode has to be replaced.
With your microwave unplugged, and your capacitor discharged, use extreme caution to remove the lead that leads to the capacitor. You can leave the ground connection attached. The side of the diode that goes to the ground is usually marked with a dot, stripe, or arrow. Set your ohmmeter to R x 10,000 or higher. Touch the positive meter probe to the anode and the negative meter probe to the cathode to measure the resistance across the diode terminals. Remember that the cathode is on the side that goes to the ground, which is often marked by a dot, stripe, or an arrow.
A normal diode, that is a non-defective diode, will read anywhere from 50,000 to 200,000 ohms. Differences in microwave make and model account for this large range in resistance readings.
Reverse the meter probes and measure resistance while touching the positive probe to the cathode and the negative probe to the anode. Reversing the probes like this should result in a reading of infinity. Unless a bleeder resistor is present. The presence of a bleeder resistor would produce a reading of the value of the resistor.
High Voltage Capacitor
A capacitor is an electrical device which stores electricity. A defective capacitor may be why your microwave is not heating. The capacitor will have to be tested to determine if this is the cause of your problem. A defective capacitor will have to be replaced before your microwave will work again. Make sure you discharge the capacitor before you test it, though.
Magnetron
A defective magnetron is the third possible cause of why your microwave is not heating. Test your microwave's magnetron. Replace it if it is defective.
Testing a magnetron
NOTE: Before you test this component, make sure your microwave is unplugged, and that you have discharged the capacitor.
There are two tests to conduct in order to determine whether or not a magnetron has become defective. If you receive results other than what are detailed below, you will have to replace your microwave's magnetron. Each test is described for you here:
TEST 1: Locate your magnetron and label each of the wires attached to it so that you know which wires are to be replaced where. Set your ohmmeter to the lowest resistance scale. Take a resistance measurement between each of the magnetron's terminals by touching each probe to one terminal each. Reverse the probes and take a second resistance measurement. Each measurement should read less than one ohm.
TEST 2: Set your ohmmeter to its highest resistance scale. Touch one of the meter's probes to a magnetron terminal. Touch the other probe to the metal magnetron housing. Take special caution to not touch the two probes together. This could result in an inaccurate reading. This test should produce a reading of infinity - indicating an open circuit.
Read the tips on the below links on how to replace your microwave oven's diode and how to discharge the capacitor.
http://www.fixya.com/support/r7088355-replace_microwave_ovens_diode
http://www.fixya.com/support/r7088317-discharge_microwave_ovens_capacitor
I hope the above is helpful.
Regards.
Posted on Nov 11, 2011
SOURCE: Model #
Make and model will usually be on a label plate on the back of the unit.
With the age of the unit and unlikely availability of spares you may be better to look for a new unit. Cheers, Dan
Posted on May 08, 2012
Whirpool microwave start when the door is closed. Replaced the damaged interlocks and tested the door switches
Chances are you have a shorted cook relay, especially if you get error code "F6."
If you're in the US or Canada, I regularly repair and upgrade these with the aim of correcting and preventing such errors.
For details, please feel free to contact me via my site below.
Always include your FULL model number*, FCC ID number*, and detailed symptom information. * from the tag in the cooking cavity or elsewhere on the oven (or send a clear photo of tag)
William E. Miller
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Jan 20, 2017 | Whirlpool Microwave Ovens
Runs 20 sec stops reads F1E5
Error Code/Message - Oven - F1 Error Code - F1 E5
Control displaying F1 E5:
There may be a problem with the Oven Control, or the associated wiring.
Power unit down by turning off the circuit breaker(s) for one (1) minute.
Power unit up by turning on the circuit breaker(s).
Monitor the oven for one (1) minute to ensure the error code does not display again.
Verify oven operation.
Oct 23, 2015 | KitchenAid KEMS309BSS Combination...
Hi all need some help with my whirlpool akp 206/lx oven. Soon as I turn it on it says ---c and wont come on cant find this error code anywhere and whirlpool want 130 as outside warranty so appreciate any...
You might want to unplug the unit to allow thr processor to reset itself. If this doesn't work, you may wish to contact Repair Clinic.com. They have been helpful answering my microwave questions in the past.
Dec 08, 2014 | Microwave Ovens
My whirpool microwave model wmh2175xvb1 Won't Heat
The problem is caused by the magnetron,"heart of the microwave oven" or the inverter board, if 7 years or less.
Apr 16, 2012 | Microwave Ovens
Fan turned on by self, won't turn off
The unit has a temperature sensing device that turns on the fan if it gets too hot...if it is very hot in your house it could turn this on...
If it is not overly hot then the thermistor or the main control board have gone bad and are reading an incorrect temperature...
heatman101
Aug 06, 2011 | Maytag Appliances Over-the-Range Microwave...
When microwave is turned on the light in the kitchen gets really bright, but the light in the dining room goes dime, and also have a fan in dining room area plugged in recept and it slow down almost to a...
Main power ground some where between the outside line and the meter.
Have a electrician to check for you if you are not familiar with millimeter and electricity. Danger !!!!
Not all electrician are smart. Some might ask you to replace this and that...?
Good luck
Mai Lor
May 11, 2017 | Samsung MW5351G Microwave Oven
My whirpool oven is working but does not seem to be heating as it should I wonder if the fan is not working
magnetron do get week over time even more so if you do a lot of short time food reheat, the fan normally is used to cool the magnetron wave guide and if it stops working the over temp safety will trip and stop the magnetron from working
Apr 27, 2010 | Whirlpool MH1150XM Convection/Microwave...
Light bulb burned out in microwave oven
Most likely you're going to have to dismount the microwave and remove the outside cover to get to the bulb. This is a fair amount of work but is not rocket science. I'm not famliar with your particular microwave, but it's probably that way. If it's any comfort to you, light bulbs are usually not covered by warranties or service contracts.
It won't hurt to run the microwave without a bulb.
Feb 03, 2009 | Whirlpool GH7145XF Microwave Oven
MMV4205 doesnt heat up
If not a separate fuse, then the hi-voltage inverter or magnatron have likely failed. The first can be $130. The second $45.
Jan 30, 2008 | Maytag MMV4205 Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
